Engine knocking noise...need help identifying
Please help me identify this engine noise. It started after some hard driving.
There is no knocking noise at idle, but it starts as soon as I accelerate.
Any clues will be appreciated.
Max.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-05-2011, 04:12 PM
silver911rdb's Avatar
I'm not sure but my first thought is timing chain noise? It sounds like the chain slapping in it's housing. It looks like you have a 3.2L engine so I'm guessing you have the pressure fed tensioners. I thought these were less prone to failure so a collapsed tensioner is less probable. Anyone else have an idea?
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 05-05-2011, 05:44 PM
Thanks Rich, in fact its a 3.2 engine, my car is a 1985 3.2L 911.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-05-2011, 06:10 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Place the metal end of a large screwdriver on the chain box and the other end in your ear and rev the engine a little. If it is the chain / tensioners you will know.
Sounds like a valve not getting back out of the way fast enough, look for a broken valve spring.
Bruce
Old 05-05-2011, 07:37 PM
Peter Zimmermann's Avatar
This is a good suggestion that I'd like to take a step further. Choose the longest, thinnest screwdriver in your tool box, and place the screw end against the chain box cover. Put your ear against the end of the handle. Move the screwdriver around gently, side to side, along the raised, horizontal "seam" (sorry, probably not the right word), on the chain cover, you'll find the problem. One side will be noticeably louder than the other.
Keep the Shiny Side UP!
Pete Z.
Old 05-05-2011, 07:42 PM
The correct tool for your investigation.......
If you could borrow a mechanic's stethoscope, this would give you a better sense where the noise is coming from inside the running engine. Even with my bad hearing, the sound/noise it picks up is so sensitive and clear.
Tony
Old 05-05-2011, 08:23 PM
tazzieman's Avatar
Very strong possibility of failed tensioner
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-06-2011, 03:09 AM
I had a failed tensioner on my 88 3.2. The noise went away at about 2000 rpm. I changed both.
They can be changed with the engine in the car.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-06-2011, 04:30 AM
Friend of Warren
Wow, that is the classic "chain drug over a metal trash can" sound of a failed tensioner. You don't want to be driving around until you fix that.
Kurt V
Old 05-06-2011, 05:33 AM
Thanks everybody for your answers.
Looks like that the main suspect is a failed tensioner...in fact, when I tried to identify where the noise was coming from, it seemed to be coming from the center rather from one of the sides (i.e. valve trains).
As suggested by Pete and Tony I'll do the "screwdriver listening test" (or stethoscope if I get hold of one) this afternoon.
I'll post my findings.
Max H.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-06-2011, 07:08 AM
Stethoscope at Autozone for about $12. Good luck, my guess, flat6pac, valve. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 05-06-2011, 08:22 AM
Wash. State
nesslar's Avatar
I gotta say +1 to that.....
Old 05-06-2011, 08:35 AM
Valves, and valve springs will be 2nd thing I'll be looking at.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 05-06-2011, 08:50 AM
Bob Kontak's Avatar
Steve - $3.99 at HFT but maxhofer is in Chile. Screwdriver (without a necktie) in the short term.
Mechanic's Stethoscope.
I have never heard the chain over the garbage can noise. This tapping noise is very distinct and very uniform. I am leaning towards valve as well.
Old 05-06-2011, 08:58 AM
Wash. State
nesslar's Avatar
I had a rather noisy valve at one time, simply re-adjusting cured that. It didn't sound anything like this, though. A broken spring can make that kind of racket? Listening, I'm reminded of one of Scrooge's ghosts walking around dragging his chains.....sounds like one whole side is rattling itself to death. Just $0.02.
Old 05-06-2011, 09:10 AM
Bob Kontak's Avatar
Looking forward to maxhofer's feedback. I though for sure youtube would have a video of a bad tensioner on a running engine but nothing.
Speaking from never hearing the rattle noise I am thinking the tapping noise would be a little less uniform if tensioners but that is simply the layman speaking.
Old 05-06-2011, 09:47 AM
tazzieman's Avatar
Mine , got it fixed ASAP with upgrade kit from PP
YouTube - failing tensioner
Nasty noise!
Old 05-07-2011, 05:36 PM
Bob Kontak's Avatar
Yep - thanks for finding that video for me. It does have a uniform noise.
Old 05-07-2011, 05:52 PM
Member 911 Anonymous
DRACO A5OG's Avatar
What kind of oil are you using or used?
'85 Carrera Targa
PCA/POC
Old 05-08-2011, 11:57 PM
