delkins's Avatar
sparkplug wire set
there are a bunch of spark plug wire sets here which do u recommend, probably need to change mine since they are original ones in my 82sc and one is missing the rubber boot on top without paying for the original porsche wires
1982sc targa blk on blk
va beach va
Old 06-11-2011, 12:50 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I am very happy with the standard Clewett wires I bought two years ago. I did not buy the Magnecor for my 81 but they are highly recommended. About a $75 difference in price with the Magnecor being higher.
Old 06-11-2011, 12:57 PM
2Utes's Avatar
I went with the Magnecor (KV85) wires recommended by Steve Weiner a couple of years ago and have had no problems. I did need to modify the wire guides a bit as they are thicker than the stock wires.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 06-11-2011, 01:10 PM
djcdmv's Avatar
Happy with the Magnecor also.
Dave
Black 1985 911 Carrera M491
Old 06-11-2011, 01:17 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
^+2
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 06-11-2011, 02:03 PM
Are all the above wire sets installed with out the wire mesh grounding jackets or sleeves?
Old 06-11-2011, 05:18 PM
2Utes's Avatar
My Magnecors (KV85) do not have the grounding jacket like the stock wires. When I was doing my original research there were a couple of theories about why teh stock wires were grounded that I no longer remember other than to try and contain RFI noise. I have not had any issues with my installation on a stock 82SC engine.
Jeff
'82SC Pacific Blue
'11 GTS Amethyst
Old 06-11-2011, 08:56 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Magnacors, plus it looks good
'85 Carrera Targa
PCA/POC
Old 06-11-2011, 11:03 PM
delkins's Avatar
ok thanks guess i'll go with the magnecors...........
va beach va
Old 06-12-2011, 04:26 AM
It was more of a failed attempt by the factory to address the issue of airbox explosions due to ignition crossfire which never cured the problem.
Old 06-14-2011, 07:05 AM
