Chain fence eating turbo
Does anyone have a list of parameters regarding ohms, volts, etc., for a C3.2's engine sensors, electrical components, etc.?
I am having to go into warp mode on diagnosing my low-RPM sputtering problem and nothing so far has been definitive. TIA ![]()
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood ![]() Last edited by Tippy; 06-16-2011 at 07:51 AM.. |
--crickets--..........--tumbleweeds--
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood ![]() |
which sensors?
Describe the problem. Rich |
'87 C3.2L bucking when taking off question
I checked the CHT and got 1.082k ohms at cold and a tad higher at hot. I think this maybe it but not 100%. The "track" on the AFS has a very light groove, not as deep as I have seen others.
speed and reference sensors;
between terminals 1&2 @77degrees F 960 ohms +- 96 ohms between terminals 1&3 >100000 ohms between terminals 2&3 >100000 ohms Rotor center to tip of rotor 1K ohms Fuel injector harness 2 - 3 ohms or... this... ![]()
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
It is all in the Bentley manual. A wise investment for do it yourselfers.
Flat Six
![]() HTH
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Easily Confused
What really matters is what the ECU sees. I would check the measurements at the ECU.
A corroded connector can skew the signals significantly.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Very true, although putting ohms (which involves voltage output of the multimeter) through a comptuter terminal can be terminal for the computer, correct?
Easily Confused
The correct plan would be to remove the connector on the ECU and take a resistance reading through the connector. This is what the ECU would "see".
Thread Tools | |
Rate This Thread | |
