installing 935 spring plates
I am in the process of installing 935 spring plates on my 911 and am having interference problems where the threaded barrel on the spring plate rubs on the body. Has anyone had this problem?
Where the bracket bolts to the body, I added three washers to each bolt between the body and the bracket to space it out. That looks to give me enough clearance.
I have not tried to align the wheels yet so it may be that when the alignment is correct, I will not have more clearance and not require the washers.
Thanks in advance for posting any experience you have with installing the 935 spring plates.
cheers,
dan
DJP; 74 911 3.6 Vram in progress
82 911sc 3.6 street/track
76 930 stock garage queen
84 911 Wide Body 225,000 miles!
72 914 3.0 track; 90 C2
Old 06-24-2011, 04:59 PM
anyone?
Old 06-25-2011, 08:31 AM
Max Sluiter
Flieger's Avatar
Where did you get the spring plates? Did you try asking the manufacturer?
Old 06-25-2011, 10:52 AM
abisel's Avatar
Could it be that the threaded barrel is offset and not centered on the spring plate? If so, make sure the majority of the threaded barrel is on the outboard sides of the spring plates. You should not have to add spacer washers to the torsion bar cover/bracket of which the rod end of the spring plate mounts. Show us pictures.
Old 06-25-2011, 12:17 PM
Thanks, it looks like I may have the plate too far extended, in other words not enough toe in. This swings the plate too far into the body.
cheers,
dan
Old 06-26-2011, 06:12 PM
proffighter's Avatar
cheers,
dan
I have 935 spring plates mounted on my 930. Don't think it's a toe proplem. Regardless of the manufacturer, threads are not centered, but more outside the plate. Is it possiblbe you interchanged left and right then...?
Best is, you post a pic, so we can see how yours look
Roland
930 Turbo '81 Too many modifications to list
Old 06-27-2011, 12:28 AM
KTL KTL is online now
Schleprock
KTL's Avatar
The offset of the rod end tube should be facing outboard. I can see how you'd have clearance problems if it's facing inboard. That's why the tube is not centered in the plate- to provide ample clearance from the chassis
Kevin L
'86 Carrera "Larry"
Old 06-27-2011, 06:30 AM
What I said
Roland
Old 06-27-2011, 07:34 AM
Schleprock
KTL's Avatar
Yep. Just wanted to reinforce what you said and add some pictures to what we're describing
Kevin L
'86 Carrera "Larry"
Old 06-27-2011, 07:37 AM
Thanks for the photos.
I did have them on the correct side and was aware of the barrel offset.
Old 06-27-2011, 08:35 AM
Now it's on dpegan to add some pics...
Roland
Old 06-27-2011, 12:11 PM
Mine istalled
Roland
Old 06-27-2011, 12:16 PM
