				What voltage at the A/C fan switch
			I'm deep, deep into replacing all the A/C components on my '83 SC...barrier hoses, evaporator, both condenser, etc..etc... and just finished the retroaire evaporator fan upgrade.  It's been running good for a few days and all of a sudden...bupkiss.
				Checked all the fuses under the hood, swapped relays, checked fuses in the back...nada. Using my voltage meter I get 3.6 or so volts at the fan power wire. Is is normal? Can I troubleshoot a bad switch by just jumping power over to one of the fan speed wire (low/med/hi) or should I be using a 12 volt source to see if the fan motor is okay? Did I mention it's all brand spanking new? Thanks, Dean  |
			 Member 911 Anonymous
			Need to check voltage at the connector of the blower in the smugglers box:
			Compliments of Gerry 86 911 Targa Current: Blower (Evap) Motor Lo Blower Motor Med Blower Motor High Voltage at High: Note this data is off of 84-86 3.2 Also check A/C fues #2, if it is loose due to heat shrinkage. For my issue I re-placed the fuse block and rails for $26: Fix: 3.2 A/C #2 fuse FINALLY!!!!
			'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-24-2011 at 07:49 PM..  |
			Did something get lost in translation?  I don't see any numbers?
			Really? you don't see the images? I see 4, No?
			Try to reload the page, F5
			'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-24-2011 at 08:24 PM..  |
			Well,
	I still don't see them, but I have solved the problem and thank you for the input. In my case, it ended up being a loose relay. Really barely noticeable that one was sticking out a little more on the fuse box than the others....really hard to notice. Fans are all back on and I'm breathing easier. Now to finish up!  |
			Cool
	'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC  |
