Banned
Reid seems to harbor the common misconception that the "Pacific Northwest" is somehow uniform in climate. Talk to someone in the Tri-Cities, or Lewiston, or Boise about how hot it doesn't get in the summer, and how short that hot season is. LOL. |
But... You have to have lived (and worked outdoors) in the deep south for a few summers in order to understand the quite radical difference in climate. here in WA we have the wet side and the dry, your(95% VFR), side. Where I was raised in NE AR we would have day after day of 100F+ temperatures with humidity close too 100%. Rains were a welcome event but the immediate aftermath was nothing short of stiffling. |
Banned
And yes, the desert West made me understand that there really is a difference when someone says "but, it's a *dry* heat."
I absolutely could not agree with you more!!!! As far as I am concerned the noise can keep it I will send you a second private message, you have not replied to my first, I want to talk to you! I have put up with “ENOUGH OF THIS NOISE”; it’s simply not worth the aggravation of having to wade through it!!!! This tread was my Journey or should I say journal to possibly publish some day. I created this tread a year ago with the sole intent and purpose of informing people about what I was doing to make my 75 911 colder a much better way after slowly doing several years of technological research and attempting to share it with others, I am more than satisfied being extremely successful with what I had been doing & accomplished you might say I am proud of it, then inform people of the world how much PFC’s were better than any other current & past available technology IS regardless of cost, and to discuss its application, installation and interaction on 911s for making the early 911 A/C system cold. Well,,, I am confident I have successfully accomplished this goal! I was just about to go into what I would call phase II; into an even newer level of PFC technology here that people do not know about. But just decided because of the NOISE here I am not going to do it! Unfortunately it’s gotten to the point the noise has rendered the tread untenable and taken it over. I think it might be time to shut this tread down and let it die. There have been more than 2 completely full pages in a row with tons of noise posts that have nothing to do with this treads stated intent or purpose and its made it so it’s no longer worth trying to read or posting anything worthwhile that is on topic, and anything I have posted just creates another problem and off topic more noise caused by a very few group of people. kindest regards Reid |
I read the first few posts maybe you answered this but how light and efficient is your version? Will your system be available and when? Do you also replace other components beyond the condenser?
Banned
The comparison tests (on the same car, different set-ups run under approximately the same conditions) will speak for themselves, without any requirement for hype or repeated claims. Long-term testing will be harder. You won't know if your design is automobile-robust for years, maybe. If you want to blog about your journey, I suggest using something like Google's Blogspot, so that you can control the replies to your posts. Then you can link the blog here, and folks can follow your journey if they are interested, and you won't have to publish any of the comments that aren't to your liking. Another suggestion is to dial back the marketing a little, and let the tech and results speak for themselves. If yor design is truly good, there won't be any doubt when numbers comparisons are made. Good luck. |
Good Advice.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Thanks Reid. Ill give you a call. Don't judge my critique as a slam. I think if you figure out how to answer all these hard questions... you could have something... and know that if I don't ask them then someone else will. The silver lining even in WWEST posts is that he makes some valid points... and you will always have skeptics. So take it alittle less personal and just try to answer them to the best you can prove with real data....
My name is Reid I greatly apologies to you for all the off topic and BS recent posts you have had to wade through by people that are clogging this thread at Pelican to find quality information here Also I would like to thank you for asking excellent questions that are completely on topic here, it’s been awhile since really important questions were asked!! I not sure how to answer regarding “how light”?, are you racing your car? Anyway my condensers are much lighter because they are made with high quality aluminum over the OEM or other aftermarket old technology units, as far as i know I am the only one making custom designed PFC's for 911's in the world My PFC’s have actually been available since early last year on a very limited production basis so I have not yet listed them at Pelican Parts yet and I have not sold any from here at Pelican either, but have finally been discussing this subject public sales again with them the other day and will talk to them again soon when their buyer rep calls me who has been busy. My PFC’s have always been handmade custom built at least so far and only in very limited production. it has only been very recently that i have resolved prior production issue related to special welding changes that was greatly slowing me down but not stopping production, but again this has now been completely resolved where i can fill much larger than individual orders now. Still I am a very small company just starting up moving carefully and slowly because it’s all custom work at this point and high quality. If really needed I can actually produce several matched sets a day at this point, anyway i realize you are probably an individual 911 owner, FYI I have a couple of front and rear matched sets ready now for installation on 2- 911’s, I have been waiting for them to bring their 911’s into my friends Porsche repair shop for their installations which is also planned to be publicly reported on here, but it’s been longer then they originally told me they were bringing in the cars for this service, due to their scheduling issues or the full report would have already been published here. as far as my PFC efficiency goes you did not tell me how efficient compared to what?? so your making me guess not knowing exactly what you mean in your question, i.e. I do not know your knowledge or lack of it related to PFC's (Parallel Flow micro-channel condensers) The technology I use is absolutely the very latest state of the art PFC technologies, PFC's generally are universally considered to be somewhere between 30-40 % more efficient to any other type of prior heat exchanger technology including tube and fin, serpentine, etc; furthermore the PFC surface area of any PFC can be about approx 25 % smaller than any prior condenser technology ever made and still be 30-40 % more efficient than any technology made before it.; this reason this is important is because smaller size approx 25% PFC’s have efficiencies of approx 25 % larger surface area than ANY older technology heat exchangers! the reason 911s don’t have cold a/c is because they do not have enough condenser surface area in the OEM places because there is simply no room. My Hi Tech PFC’s technology greatly overcomes the shortfall of early 911 Porsches Body Design greatly limited condenser surface area by approximately 25 % or more related to service area, coupled with let’s say approx 35 % plus (for simplicity sake) more efficiency over a 25 % larger older technology condenser (which is a double improvement for 2 different reasons). Btw these claims I have stated are scientifically accepted acknowledgements accepted by worldwide leading universities who have done extensive scientific studies regarding PFC technology and these are basically the accepted standards and have been verified all over the internet. bottom line my PFC's are more efficient than anything manufactured anywhere that will fit in the available room of the OEM condenser area spaces for early model 911s Note: the stated word “approx” is an approximation or a rough calculation only, and not a specific and may slightly vary in different installations due to several factors. if you want I would be happy to talk to you about your concerns and answer your questions related to my PFC technology etc my number in Fort Lauderdale is 954-599-5235 email captainengineer@earthlink.net Best regards, Captain Reid Kelly Chief Marine Mechanical Engineer USCG Licensed |
I guess I was wrong, he doesn't even know, can't state, the weight.
Not snake oil, more like vaporware. |
Contamination in a 911/930 ac refrigerant system is not as common as compared to the 944/951 or 928. Inspection of the existing compressor oil, compressor ports, drier inlet and outlet ports usually provides a reasonable clue as to whether contamination is present.
AC refrigerant line filters have been around for many years and typically marketed toward vehicle brands and models that have higher incidents of compressor failure. There are many different approaches: a fine screen, alike a thimble shape, inserted in the inlet port of the compressor ,or an inline filter alike this: In Line Filter example A filter does not guarantee a clean system, typically when contamination is found it can be through out system and in either case AC liquid flushing is required. The issue with condenser design when it comes to liquid flushing a system is that PF designs are the most difficult to clean out, serpentine and tube and are much easier to flush: same holds true for evaporator's: plate and fin (as found in the Boxster/996 and later models) are very difficult to flush as compared to serpentine or tube and fin designs in the 964/993 and 911/930. The "black death" scenario can be found in many brands and models of compressors, such as the 944/951 and 928 being more common, however it can occur in the 911/930. When you find this type of contamination its usually a sign of either improper service or a system problem: man-method or material. |
Banned
It's just a guess.
Reid, I have an 86 Carrera and I gave up on the AC about a year after I bought it in 1998. I had it recharged but was told that it leaked freon due to holes in the hoses. Since filling it and watching it leak is not good for me or the ozone I stopped worrying about it a just rolled down the window.
The 911 design does not allow for extensive luxury items and I don't really need them but I would like to see a modern, small, light weight and efficient AC design that works. I don't think that driving in 90-100 degree weather at high noon in a traffic jam is really fair for any AC but I do think that some cooling would be nice. The condensers seem to be only a part of the system. What about the compressor, hoses and the evaporator and the blower and all of the related system parts? It should be possible to make a small compact unit driven by electricity and using the latest coolant that doesn't need the tangle of hoses and wires. All I am asking is to reduce the ambient air temp by say 30 degrees and reduce the humidity. |
"...Special A/C line filters CAN GREATLY help prevent BLACK DEATH..." "SPECIAL" A/C line filters... Quite clearly Reid was NOT referring to the simple screen filters that can be used, are commonly used, to filter out, trap, metalic "fines". The way I took it Reid was talking about a filter to block the black odorous GOO that results from the combination of teflon molecular level "fines", compressor lubrcant, and refrigerant, under HEAT. You're the A/C GURU here, so how do you read this and what would be your suggested solution for preventing, or correcting for, the formation of Black goo as defined above and in the media. Last edited by wwest; 05-24-2012 at 09:58 AM.. |
I have used these for a suction line filter with no adverse effects on performance.
Parker - SUCTION LINE FILTER DRIERS
Regards, Olin 1972 911T w/Carrera 3.0 - Light Yellow ![]() 1994 964 30 Jahre 911 - Viola metallic |
PTFE-based piston coatings
on wobble and swash plate designs, lacking sleeves and rings, such as the 911/930 Nippondenso, have been used for many years by various compressor manufacturers. This anti friction coating helps prevent pre-mature wear when the system starts up until the refrigerant/oil mix moves through the compressor. The coating is not 'thick', measured in microns. The "BLACK DEATH" scenario can be seen in various makes/model of cars, it is not unique to one specific car. It occurs when the piston coating wears off. And, what can also found in the 'black' is: (i) fine aluminum particles, (ii) brass from swash or wobble plate bearings, and (iii) rubber particles and carbon when refrigerant hoses have tired. Simply put BLACK DEATH can be anything mentioned above as well as all ‘things’ at once. If a compressor decides to have a BLACK DEATH funeral the plague moves typically "north", from compressor through lines through condensers, into the drier and sometimes out of the drier, into the expansion valve, through the evaporator and back to its host... the compressor. In many cases, depending upon how long the body (compressor) has been allowed to further die and grenade, the receiver drier can act as a filter and trap much of the contaminants.... to a point. The finer the particles the further they go and this means past the drier. The longer the system operates the worse things get and farther the junk goes, sometime around and around ! The plague can travel south as well. If compressor decides to leave this world contamination inside of it can be pulled up into the suction line when the system is turned off by ‘backwash’. Filters vs. Screens: A filter or screen is only as good as the size the particles (measured usually in microns) that it can trap and the size of the filter... how much it can hold. The problem with filters and screens is 'clog'. If the filter or screen is too small and a dam develops inside then everything behind it builds up and that means back pressure. So if you have a compressor that is trying to pump and there is a dam in front of it, that means higher system pressures and with that comes breaks and leaks. On the other side, as the compressor is trying to pump stuff north, down south the pressure drops, that means not enough refrigerant/oil flow coming back to the compressor hence a quicker death or catch22. Benefit of a "Filter or Screen": Assuming you have a large enough size filter with a small enough size micron rating, "possibly" anything in front of the filter might be saved from the plague, such a PF condenser that is a real PITA to try to liquid flush out its contaminants, possibly the drier and possibly the expansion valve and evaporator and any lines north of the filter. This in theory would save you the time and expense of liquid flushing components south of the filter, in theory. What ever filter/screen design and size you choose it must not reduce the flow of refrigerant/oil through the system or system pressures will rise on one side and drop on the other where you don't want them to. And, if you add a filter on the suction side chances are you building your house from the roof down rather than from the foundation up: If the compressor grenades the flow of contamination travels north through the system back to the filter. Does that make sense? You will still have to liquid flush the entire system. If you added the filter on the suction side to a system that was already contaminated, does that make sense? That would be a band aid. How to Prevent the BLACK DEATH: Just a few common causes and solutions Cause: Old compressor Solution: Inspect what you have or get a new one. Cause: not enough oil Solution: add oil Cause: not enough refrigerant/oil flow Solution: add refrigerant, add a low pressure switch Cause: excessive high side pressure Solution: more condenser area, more air flow through the condenser, add a high pressure switch, don’t overcharge the system Cause: any of the above or more Solution: right man, right materials, right methods; no short cuts! |
There is something NEW I want to talk to you about I have been thinking about for some time I believe will work that would satisfactory lower the temps thrown off by the rear deck lid condenser I won’t mention here for obvious reasons; I don’t think anyone has ever considered or tried at least as far as I know, or no one has tried this at least as far as i know on a 911 from all the years reading re-911s & a/c. I have decided to try this AND Coupling it with the technologies I am using I believe it is worthwhile to pursue; I will have to talk to you about this privately and think you will find it more than interesting GRIN What we are working on together, I have decided not to talk about it here publicly due to all the unwanted noise here, and just leave everyone clueless about what we are attempting to do. Children disrupting this thread have damaged it for everyone else to know about!!! |
Senior Member
Please email me this weekend. If I do not hear anything by Monday evening will be ordering parts from other sources. I need to get A/C on the car now. Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Banned
Before you commit to Reid, at least talk to Charley. You'll be buying stuff from either Charley or Rennaire anyway, due to the fact that Reid doesn't supply "the other stuff" like barrier hoses. |
