*** As is most likely, more likely than otherwise, the case of the overall "total" of the factory design. Not enough capacity to keep the evaporator fully chilled (~35F "target") during initial cooldown on anything beyond a moderate temperature day. Last edited by wwest; 06-07-2012 at 07:00 PM.. |
Keep in mind that the 911's A/C is a re-circulatory system, and the more air that is pulled from the cabin and cooled through the evaporator, the faster the 32* condition at the the evap can occur for the system to start cycling. I see the point WWEST is getting at, but still believe the stock blower fan is woefully inadequate.
Personally, in AZ summer heat, I don't see that condition happening, at least without additional condensers. But when I've walked for 10 min from an air conditioned office in 110* to get to my car that is probably 125* inside, 70* vent temps with lots (for a 911 anyway) airflow feels pretty damn good!!
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Last Word
I believe that by using a car cover, or windshields blinds, tinting the windows along with the existing hardware that is already available through sources that are pr-oven to carry quality products the ac system in a 1974 to 1989 911 can be modified to handle 100 degrees plus temps but...............Why not stick with a pr-oven source that has been vetted through reliable sources.
If it sounds to good to be true...................................
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
In point of fact the reverse is more true than otherwise. Reid's product is likely no better than competing products having long been in the market, plus proven to be reliable and reasonably priced. |
questions
questions questions questions
I have been EXTREMELY BUSY working on NEW THINGS to say the least! I will answer questions previously presented here in the last few days your going to have to wait untill I can find the time to answer them |
Banned
I hope that some of the new things you are working on would be acquiring test data on your equipment as to pressure drop across the working condenser (to get an idea of actual working efficiency) and comparison test data using OEM and/or current aftermarket offerings. Or, failing that, actual instructions for those DIY folks who want to bolt stuff in. If you're going to answer the questions with more theoretical discussion not based on anything you yourself have done, my suggestion is that it will not be well-received by your potential target market. It's a tech forum - let's have some actual tech. |
Howdy Josh, Thanks for joining my PFC discussion; Finally a PFC believer Be so kind to Tell the folks here your engine oil temps when your ambient temps are 105 and your running only one rear deck lid PFC and your vent temps These old technology serpentine promoters here just don’t get it they have been brainwashed LoL, the only thing they seem they can talk about is their justification to promote what they have spent their money on and are now stuck with old technology and nay say PFC’s Josh I know quite a bit about the Retro Air PFC your using, from when I was doing my research before I designed my own PFC I did extensive testing on the same PFC your using, unfortunately you paid a lot more for from Retro Air you could have gotten it far cheaper from where Retro Air gets theirs from (smile) AMA Automotive Air Conditioning Parts & Equipment - Compressors Condensers Accumulators Expansion Va: Parallel Flow Condensers - Aluminum The picture of PFC below came from ackits.com, I purchased for PFC testing, evaluation and comparison purposes. I believe is the same PFC you got from Retro Air, it works I guess OK if you have nothing better in your 911 deck lid, but it HAS FAR LESS Efficient/Performance then what I have designed and manufacture (note if anyone wants this same PFC, I will sell it for less than I paid for it FROM ACKITS) Before I engineered and designed and had made my own PFC I got angry after trying several already available universal size PFC’s found on the internet including the one like you have because I could not simply buy a PFC that would give me good enough efficiently/performance and the exact sizes I knew I wanted/needed to make a really cold 911 using state of the art PFC technologies! The one like you have I also have proved to me after thoroughly testing it worked but not quite good enough to make me happy. I used this same PFC you have in my deck lid, and alternately with my OEM Behre tube and fin and with a few other PFC’s for testing my first 911 Front chin custom designed PFC I made. FYI having an additional front chin PFC makes a big difference compared to having only a rear Deck Lid PFC only, and even more so to say the least in all kinds of driving conditions, stop and go driving and extended idling etc. As I am sure you probably have noticed by now in your 911 @ 105 ambient F you’re a/c works finally works pretty good (smile), for me I wanted better than pretty good, I wanted as cold as possible using only a/c condensers made to fit the 911 original places Porsche USED and I also wanted my 911 a/c system temps to be very comfortable in ambient temps over 100. Note: although our ambient temps here in our tropical summer are only 95 F and 99 % humidity daily and “sometimes night and day around the clock for weeks”; As I am sure you know from where you live when you have afternoon ambient temps above 90 F and your car is sitting in the sun or shade and inside your passenger compartment when you first open the door can easily be over 160-180? F Plus and you feel this 160 F Plus interior radiated heat before you step inside with the door first opened and you wait a bit for some HOT to escape before sitting inside Josh if I can help you with any of the knowledge I have learned after a lot of testing with PFC’s to make your air vents colder I would be more than happy too, i.e. sealing in your rear deck lid PFC, evap, etc., to make things work more efficient than it currently does Below is a testing PFC I bought from ackits.com that is the same also sold I believe by Retro Air for a much higher inflated price
Banned
YOU HAVE BEEN DISSING ME FOR A YEAR!
I want nothing to do with you! stop requoting everything I say here about anything no matter what it is! Take your **** attitude out of here why do you not just go away and waste your time someplace else here at Pelican, take this to the bank you will never have anything I make or do! |
Posted here in this tread by Wayne at Pelican Parts
CEO, Pelican Parts Inc. I am trying very hard to follow Waynes advice and expect others here to do the same but unfortunately we have a few people with intent to damage this tread! If you can not do this please find other places to go to away from here. Quote:
Banned
1.) I don't think you have to worry too much about me wanting whatever you're selling. If you ever do indeed sell anything. 2.) As a matter of technical interest, I'm waiting for you to publish something other than vague theoretical advantages of what your potential product might or might not be able to provide for the cars in question. I am very interested in TECHNICAL DATA. This is the 911 technical forum, right? Hard to have a technical discussion without having hard data. Of course, thats why this forum exists, and why we're all here. And how I spend my time is not your concern. But I do appreciate that concern nonetheless. 3.) I selectively quote, Reid - I almost never requote an entire post. That's bad form. FTR, the stuff I quote from you is often the funny, ironic or hypocritical stuff. Like the complaint from you about reposting, when you're posting the same post in three separate threads. That's comedy gold right there. Actually, I've been seriously questioning your product for about two months. My first concern, way back when, was that you supposedly had this stuff for sale, but there was no report from anyone that had actually purchased the product, nor did there seem to be any particular way that someone could actually buy something from you. I was actually interested in the product at that time. But the more I read, and the less you said, the less interested I became in your product. Currently, I am only interested in the comparison of your product vs. what is actually available on the market. This is not "dissing". I do laugh a little when you complain about posters doing exactly what you yourself have done - that funny in any circumstance. But actively seeking actual results and seeking to get hard data is not anything close to "dissing". I'm going to keep asking the questions until they get answered, Reid. And no worries, I won't be trying to buy anything from you. After all, you can't buy what isn't for sale, right? |
Banned
KelogGes, Thank you for your time and efforts in developing an updated A/C system for our cars.
It is unreal how rude you have been treated here. This is normal fair for Pelican, doesn't make it right. |
1. cost? for each component? as well as in the kit? What is included in your kit? For example, If I change my condenser, Ill also need a drier and expansion valve. Will you sell the drier or will you have a vendor you work with on that? It would be pointless to change a condenser and not change old leaky hoses and o-rings. I guanantee you Reid, if you sell a condener, and a user doesnt get the performance you are advertising, they WILL blame you and your condenser. That is why Griff and Rennaire sell kits and why they disacourage small incremental changes unless everything has been upgraded already. Good way to gain a poor (word of mouth) reputation... not to mention lawsuits and returns.
2. weight? 3. selling points over a well designed kit by Griff and Rennaire who have already proven 35 degree temps WITH 95 degree ambients and "OLD" technology. for anyone who has ice cold AC in a hot climate and has spent $$ why would they dump a working system? Just because its newer technology? 4. What problem are you trying to solve? Does your product solve that problem? Poor vent temps are not a problem... Griff already solved that. So what is the problem this addresses? Is it the Griff cost? Can you really make a product that will last 10 years, provide 35 degree vent temps, and charge the consumer less than $289? 5. Have you done a market study/analysis? How many pre 89 911's are registered today, how many have an aftermarket kit like Griff? How many of the owners have owned their car for over 5 years (they probably wouldnt spend the $$ if they havent spent it in the first 5 years). What is your breakeven point for production numbers? Assume a $300 price point. 6. Have you prepared a technical Q&A with ALL questions answered? 7. Filter vs No Filter? if you site a list of filters from 20 years ago that doesnt fit a car made after 1998, you lose credibility. If you site AC manufacturers and words like "every" and "all" when in fact 5 of the 6 top auto manufactures (Toyota, VW, Honda, Ford, Chrysler) use no such device, you lose credibility. In fact, the ONLY car manufacturer that actually uses a filter in a post 2005 car is GM. 8. Fans vs No Fans? 9. Proof of your products superiority? if you site research for Serpentine Vs Yours and it doesnt even compare Serpentine but rather tube and fin, you lose credibility. 10. Non-Barrier hose issue? you give us pictures of a chinese vacuum pump and just tell us to add refrigerant every year? Seriously? That is not a solution. 11. Engine temps. With Factory AC, With your AC. Same ambients/humidity. Side by side comaprison in 4-5 different climates. 12. What about that research you posted that is mixed at best against the original design and doesnt even apply to serpentine. Where is the Serpentine vs your product research? data? real world testing? side by side comparisons? We have NEVER seen it!
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
2. weight? 3. selling points over a well designed kit by Griff and Rennaire who have already proven 35 degree temps WITH 95 degree ambients and "OLD" technology. for anyone who has ice cold AC in a hot climate and has spent $$ why would they dump a working system? Just because its newer technology? 4. What problem are you trying to solve? Does your product solve that problem? Poor vent temps are not a problem... Griff already solved that. So what is the problem this addresses? Is it the Griff cost? Can you really make a product that will last 10 years, provide 35 degree vent temps, and charge the consumer less than $289? 5. Have you done a market study/analysis? How many pre 89 911's are registered today, how many have an aftermarket kit like Griff? How many of the owners have owned their car for over 5 years (they probably wouldnt spend the $$ if they havent spent it in the first 5 years). What is your breakeven point for production numbers? Assume a $300 price point. 6. Have you prepared a technical Q&A with ALL questions answered? 7. Filter vs No Filter? if you site a list of filters from 20 years ago that doesnt fit a car made after 1998, you lose credibility. If you site AC manufacturers and words like "every" and "all" when in fact 5 of the 6 top auto manufactures (Toyota, VW, Honda, Ford, Chrysler) use no such device, you lose credibility. In fact, the ONLY car manufacturer that actually uses a filter in a post 2005 car is GM. 8. Fans vs No Fans? 9. Proof of your products superiority? if you site research for Serpentine Vs Yours and it doesnt even compare Serpentine but rather tube and fin, you lose credibility. 10. Non-Barrier hose issue? you give us pictures of a chinese vacuum pump and just tell us to add refrigerant every year? Seriously? That is not a solution. 11. Engine temps. With Factory AC, With your AC. Same ambients/humidity. Side by side comaprison in 4-5 different climates. 12. What about that research you posted that is mixed at best against the original design and doesnt even apply to serpentine. Where is the Serpentine vs your product research? data? real world testing? side by side comparisons? We have NEVER seen it! Quote:
douglas. wouldnt you want my 12 questions answered before making an informed decision? this is a tech forum. Ive yet to see ANY tech except 20 year old parts lists, unsubstantiated claims that cant be proven, and articles that are neutral at best.. if he answers my 12 questions, the skeptics will be answered... his avoidance of the questions are why we are still talking about this at all! questions 11 and 12 involve real world testing. real world does not equal his car and his buddies car down in S Florida.
the only "updated" (from factory) system (that means complete kit) is made by Retroaire, Griffiths and Rennaire. I never saw Reid's "system". in fact he keeps telling us all he isnt selling anything at all...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 06-08-2012 at 02:47 PM.. |
Banned
Speculation, of course. But since RetroAire already does a rear PFC condenser, why not just go with them? |
Just answer the damn 12 questions., LOL
