Throw it on the ground!
Elevated & Surging Idle on 3.2 Ideas?
This is new. Normal idle has been 900 to 1000 rpm. All of sudden that has elevated to 1,200 with a regular cycle/pulse up to 1,300 and back to 1,200 every few seconds. What would cause this?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 07-14-2011, 05:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Have you check the throttle linkage to see if anything is binding? Is the Idle Switch connecting/clicking at rest?
Tap on the ICV to see if settles down.
Check the vacuum Y lines behind the TB to either side to those bell diaphrams ( one being the FPR ). My buddy's 86 was disconected on the passenger side one.
'85 Carrera Targa
PCA/POC
Old 07-14-2011, 05:22 PM
Call 911
dkirk's Avatar
Check the torque values on the intake manifold-to-cylinder head nuts. These have a tendency to loosen due to thermal cycling. I had an unstable idle on my 1988 3.2; checked the torque on said nuts and most were only finger tight. A re-torque to the service manual value cured the idle instability.
Dave Kirk
My Porsche restoreth my soul.
Old 07-14-2011, 05:24 PM
Good suggestion. I changed out the intake gaskets and spacers over a year ago and have not retorqed since. Py previous intake leak symptom was a rough idle but who knows.
Old 07-14-2011, 06:38 PM
Thanks for the ideas! I will check all of these items.
Old 07-14-2011, 06:40 PM
DRACO A5OG's Avatar
As I understand it it should be re-torqued after 2000 miles, but would a leak cause a lean/low idle situation?
'85 Carrera Targa
PCA/POC
Old 07-14-2011, 07:25 PM
A rich condition due to a bad 02 sensor might cause this too.
Old 07-15-2011, 08:23 AM
Large Registered Member
PatrickB's Avatar
Don't forget Fuel injector's too. If they are original, it's time to send them out to be overhauled!!!!!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 07-15-2011, 08:27 AM
Idle switch
Old 07-15-2011, 09:03 AM
scottb's Avatar
Had a similar problem. A mixture adjustment solved it.
1984 Targa
Old 07-15-2011, 09:13 AM
All good suggestions. Due to the sudden onset, I'd pull the icv when warm, and re-connect the elec - make sure the valve is half open. Be sure that it moves freely.
Old 07-15-2011, 10:34 AM
Sorry to hijack, but I have often wondered when this should be done. Is there a factory recc'd service interval for the injectors?
Re the idle, there have been a lot of threads on this (3.2s seem prone to bouncy idle).
So use the search button too as this problem can have multiple causes.
1986 Targa
1968 MGB (2)
Old 07-15-2011, 11:14 AM
Injectors are good. All sent to Witchhunter for reconditioning at time of engine swap 2 yearss ago.
Problem appears to be intermittent. Did it again this morning on the way to work. Not out to lunch and not on the drive home
Mark
1987 911 Coupe
Old 07-15-2011, 05:12 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Idle issues
If none of the above resolve your issue:
1. Remove and clean the ICV, and reset the idle by shorting the connector
located on the engine compartment fuse panel as per the Bentley.
2. check for a disconnected/defective vaccum line.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-15-2011, 05:39 PM
DRACO A5OG's Avatar
Great pics Gerry
'85 Carrera Targa
PCA/POC
Old 07-15-2011, 07:57 PM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
In the last picture there is a braided vacuum line next to the rubber ones and just above the "Y" vacuum lines, can anyone tell me where this line goes to or comes from? I finally had some time to check stuff out (crappy idle and idling very rich with no response from air fuel mix adjustment. Found the "Y" pulled off and the braided line missing (or maybe fallen down somewhere I can't see). There is a braided line over by the oil filler tube that goes down behind the engine
Old 07-17-2011, 03:39 PM
