ROW '78 911 Targa
timmy2's Avatar
Very nice work Thor,
We both started our engine drops around the same time.
I see you removed the mounting post on the middle runner for the fan mount.
I was going to do that but it was in the right spot to mount the vacuum switch going to the WUR on mine without re-doing my lines again. Where did you attach yours. I can see the lines dropping behind the #3 runner but can't make out where it is attached.
You can see it in my picture from my car. (Ignore the stainless airbox)
Originally Posted by timmy2 View Post
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-18-2011, 06:09 PM
Brown747's Avatar
thermo valve relocated
Dennis,
I shaved the mounting pads off intake runners 2 and 3 for the fan mounting bracket and removed the unused one on #4 in an effort to clean things up a bit. I moved the thermo valve behind #3 and used a spacer and a bolt to mount it to the throttle linkage pad. There are 2 tapped but unused holes in that pad that will accept an 8mm bolt. Mount it high enough to clear the throttle bellcrank. Your engine is looking good also!
Thor
1978 SC coupe #1834
Old 12-18-2011, 06:52 PM
Brown747's Avatar
Clean up continues...
Preparation for engine install continued on this warm and wet northwest day. Pressure washed the back end...up next tunnel fuel line replacement, clutch cable, and brake hoses and fluid flush....
1978 SC coupe #1834
Old 01-04-2012, 02:51 PM
AutoBahned
RWebb's Avatar
you are smart to replace the rubber brake hoses
I am not real fond of your front wheel "chocks" tho
have a friend there & have them hold a cell phone, ready to dial 911 just in case...
Old 01-04-2012, 02:58 PM
Northern Motorhead
wildcat077's Avatar
Hey Brown,
May i suggest "choking" your front wheels like this ...
I just used some scrap 4x4's and 2x4's i had laying around,and you don't have to raise the car as high in the rear and it keeps the front spoiler off the ground !
If you have a friend with an engine hoist,you can lift the car by the engine mounts then you just lower it onto the engine.It's way safer that trying to jack it up the conventional way with your jack stands extended all the way...
I did the whole R/R by myself and it was a piece of cake,it was my first time as well !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-04-2012, 04:00 PM
Brown747's Avatar
Engine installed
Took advantage of the spring like weather we've been having in the northwest and installed the engine today. C/V joints and brakes to go through but getting closer.
Thor
Before
After
1978 SC coupe #1834
Old 02-07-2012, 04:30 PM
Reiver
Reiver's Avatar
Man, I need a pressure washer.
Old 02-07-2012, 05:33 PM
air+fuel+spark
combatic's Avatar
Nice job! I am going to have to try your mineral spirits trick! I literally used a dental pick on my 40+ year old 901 to get at the nooks and crannies and nearly wrecked my back.
bryan
1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle
R Gruppe #653
Old 02-07-2012, 06:45 PM
Brown747's Avatar
Thanks Bryan... Look forward to meeting up when we get our cars on the road.
Thor
1978 SC coupe #1834
Old 02-07-2012, 06:52 PM
Enthusiast
jrolstin's Avatar
Excellent work. I am in the process of doing the same to my car but I am only halfway through my engine drop because I have been working so much lately and have been busy with school...
Interested in hearing on how the reseal went and if you were able to rid of all of your leaks. Did you replace any seals in the tranny? My trans is leaking for sure and motor as well from 160 places probably.
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 02-08-2012, 01:17 AM
Brown747's Avatar
Jonathon,
Still some work to be done before I start it up to see if my work was effective. As far as the tranny , I replaced the front cover gasket and shift shaft seal. Differential shaft seals, input shaft seal and o-ring. Stay tuned for results.
Thor
1978 SC coupe #1834
Old 02-08-2012, 04:14 AM
Beautiful work. Out of curiosity, how did you manage to get your fan to look like that? I love it. I'm dropping my engine to do some gearbox work and will be going through a similar set of projects.
Old 02-08-2012, 05:22 AM
Brown747's Avatar
The fan, shroud, and intakes were glass bead blasted then protected with a coat of rubbed on ACF-50.
Lear Chemical Research Corporation
1978 SC coupe #1834
Old 02-08-2012, 05:49 AM
al lkosmal's Avatar
Thor,
Looking very good. Nice attention to detail and detailing...................get out the movie camera for the 1st fire up!.............
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 02-08-2012, 05:50 AM
Exactly what I needed to know. Thank you very much.
Your project and attention to detail is an inspiration.
Old 02-08-2012, 11:58 AM
Well done Thor......i'm feeling very inspired!
Scott
1984 Carrera 3.2 Guards Red
Old 02-13-2012, 02:47 PM
Brown First I want to say great job, you have inspired me to do close to the same on my 82 SC all going well , I do have question on the sound insulation. I am going to install this weekend, did you use a glue If so what was your process, was thinking a contact cement or glue Thanks Mac
Old 02-23-2012, 05:14 PM
al lkosmal's Avatar
fire it up....youtube!!!
al
RGruppe #669
Old 02-23-2012, 05:20 PM
efhughes3's Avatar
Use 3m high temp spray adhesive. Mine's held for about 8 years now.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-23-2012, 05:23 PM
al
I second the thought of recording the start up. If I ever have to drop my motor, I think I'll be giving you a call. I enjoyed reading through this thread. Keep us updated.
Old 02-23-2012, 06:08 PM
