Milo2361's Avatar
finally got the Wideband O2 sensor in today! when i installed, the little LED light went exactly like the directions said, and i double checked EVERYTHING and its installed 100% correectly. but....... I'm kind of confused tho - - in the VE table shouldn't i see actual Air-fuel ratio numbers (i.e. 14.7 or similar) rather than the current "55, 60, 62, 65, 71..." ?
1998.5 Ram 2500 Cummins
Old 11-24-2011, 03:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
R.I.P.
drmatera's Avatar
No, VE table is different than A/F table
Old 11-24-2011, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Milo2361's Avatar
ah-ha! a clue... i'll look into it in the A.M. thanks!
Old 11-24-2011, 06:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
R.I.P.
drmatera's Avatar
sorry I was on my i-phone watching a movie with family so my reply was short.
The VE table numbers are part of the math used to fire the injectors. raising the numbers increases fuel flow, lowering them decreases flow. Your A/F table looks similar except you will see "target" A/F numbers. The default A/F table in Tunerstudio is pretty good although a little lean in the light throttle cruise section for my taste. But it's a great start and will let VE Analyze do it's thing.
Old 11-25-2011, 06:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
R.I.P.
drmatera's Avatar
here is a pic of one I used. I have since leaned out the cruise to 14.7 up from 14.2 - It's a slightly modified table from the default
Old 11-25-2011, 06:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Milo2361's Avatar
ahhh i see. any thoughts on how to get to that table through Megatune? I played around w/ megatune (unconnected) and couldn't find ANYTHING that looked like an actual AFR table... or should i just download tunerstudio?
Old 11-25-2011, 06:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
R.I.P.
drmatera's Avatar
get tunerStudio
Old 11-25-2011, 06:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
sjf911's Avatar
Tunerstudio is superior to megatune but you need to have an established project open to access the tables. Here I have opened the drop down menu under fuel settings and selected AFR table 1:
You can export and import all of the tables as you like. It is not a bad idea to save the old tables as export files, then you can modify them any way you like and always re-import the original (you can also backup the entire project at anytime which includes all tables and settings).
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 11-25-2011, 07:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Tony`s kit does not support AFR table. Then you have to upgrade to MS extra
Old 11-26-2011, 06:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
Milo2361's Avatar
wait... so the guy that i'm having tune it soon won't be able to use an AFR table?
Old 11-27-2011, 05:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
brads911sc's Avatar
tony's kit is so outdated Im surprised that anyone would even buy it. It doesnt come with the most expensive bits like Fuel injectors, pressure regulator anyway and doesnt use TPS which is a major drawback. the ECU is about 4.5 versions and many major upgrades behind.... the sad thing is that the MS3 ecu is only about $200 more than his outdated version. A MS 2, V3.57 is only $150 more... Seems to me he would charge alittle more and get out of 2007. Not knocking his kit, it works well for many users, but 95% of the difficulty is the tuning maps not the hardware, so as long as you have his maps, Id pass on his kit until he upgrades it with at least a MS2 V 3.57 ECU. There were MAJOR updgrades in V 3.57 and even more upgrades in MS 3.. Back in 2008 it was great. But that was then and this is now... To each his own...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 11-29-2011, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Milo2361's Avatar
took it up to omaha and met the guy who was gonna tune it - did a lot of WOT tuning - got everything running much more smoothly. no hesitation when i slam the pedal thru the floor, runs much smoother than before! going back to western, NE again in about a week ; will test gas mileage again there and back (uphill vs downhill(3k feet elev. difference), head wind vs tail wind).
idle still barely surges - we tried to lean out the mixture at idle, but the car started to miss and pop so he had to richen it back up. i feel the idle afr (~12.9) is too rich! but leaning it out makes it worse. perhaps the slight idle surge is another problem?
warm up config is next; but he looked at it and said it probably doesn't need much work, since it seems to warm up fairly normally. dyno runs probably going to happen in january
Old 12-11-2011, 09:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Milo2361's Avatar
also - just got baffles(from ben) for Ben's GT3 style muffler - since it was droning pretty bad. my only question is how far in do i put them and which end goes in first? should the pointed center be facing out the exhaust (top) or into the ehaust (bottom)?
Old 12-15-2011, 12:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
ROW '78 911 Targa
timmy2's Avatar
I've been looking into the bitz and other set ups and read you entire thread and other posts you've made.
Did you ever plug the old fuel line fitting hole you have circled in red? That may be you ongoing vacuum leak that doesn't let you lean out you settings. Could be opening slightly even disconnected.
none of the maps work properly man. talk about frustrating... spend 20 some hours putting this together and have it not work.
edit: checked for vac. leaks thoroughly - carb cleaner on ANYTHING that has to do wit ha vacuum. all vac lines, all intake runners (tops and bottoms) all check out - absolutely zero fluctuation with the idle.
do i have my dedicated vacuum hose hooked to the right spot?
Yellow circle = vacuum line coming off left side of distributor(as if facing the rear of car)
blue circle - where i have my dedicated line to the Fuel Pressure Regulator
red circle - random hole in cold start valve - do i need to plug?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-26-2012, 02:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
