Captoz's Avatar
Engine bay sound mat, is it possible?
Can you install a new sound mat without dropping the engine? I would like to replace mine which was missing when I brought the car but it does look a tight fit back there. I have a 77 2.7 911. Anyone done this and can offer some advice.
Cheers
James
Old 08-14-2011, 08:55 PM
Certified User
billjam's Avatar
Yes - but only if ...
you don't want it glued in place (as it normally is), and
your arms are three feet long, 1" diameter and with four elbows.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 08-14-2011, 09:52 PM
slodave's Avatar
I believe you can replace, with glue, if you lower the engine. Minimal effort needed for that. Easiest to do with the engine out though.
Old 08-14-2011, 09:53 PM
Captoz's Avatar
Thanks for that.
Sounds best left till the engine is moved!
Old 08-14-2011, 09:59 PM
Captoz's Avatar
I have to change the engine mounts, sounds like I could wrangle it in then.
Old 08-14-2011, 10:00 PM
slodave's Avatar
Removing as much as you can from the top of the engine helps as well...
Old 08-14-2011, 10:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You can do a partial drop, remove heater fan and AFM plus butterfly hose should give you enough room. Others have done it this way
'85 Carrera Targa
PCA/POC
Old 08-14-2011, 10:48 PM
slodave's Avatar
I'm guessing you are one, Jim?
Old 08-14-2011, 10:58 PM
Captoz's Avatar
Do you mean working as one? Sorry dont quite get your angle.
Old 08-14-2011, 11:05 PM
slodave's Avatar
Me? I was referring to the post above mine.. His name is Jim.
Old 08-14-2011, 11:09 PM
I did one a few months ago with a partial engine drop. You will be half way there while you replace the engine and trans mounts. The hardest part I dealt with was cleaning off the old mat and bits of foam to prep the area. Sounds like that won't be an issue for you.
PP offers two kinds of mats. the light weight one is the one I used, and think it is better suited to this kind of install. with its flexibility and stretch it may be easier to work with in the confined spaces.
Putting a padded canvas over the engine made for a more comfortable working area.
Cheers Richard
Old 08-15-2011, 01:35 AM
Almost Banned Once
sc_rufctr's Avatar
It can be done but...
If it was mine I would wait until the engine is out. I don't mean to put a jinx on you but it really is only a matter of time before you'll need to drop your engine to do something.
Maybe just to fix some oil leaks or as I do once a year for valve adjust, thorough clean and inspection.
Once it's out you can thoroughly clean every thing and clue that sucker in it's perfect position.
You can also check fuel lines and electrical cables while you're at it. Maybe even replace the foam packing behind each shock absorber, if needed.
There's always lots to do with our cars.
Would I drop the engine just to do it? No... I would keep it in it's plastic bag ready to go.
- Peter
Old 08-15-2011, 03:09 AM
kodioneill's Avatar
Partial engine drop set mat in place by sliding it down behind the engine and cutting the necessary hole for the hood shock. Then spray glue on mat and firewall let dry then attach.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-15-2011, 05:38 AM
Chain fence eating turbo
I was trying to rip mine out yesterday.
I would think you can do it without dropping the engine if you get the pad in place first, then come back and glue it.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-15-2011, 06:20 AM
wayner's Avatar
Any recommendations on which mat to use?
I have a 73
SOLD - 914 wide body hot rod
Old 08-15-2011, 06:43 AM
I just used the regular one. Seemed like the money could be spent better somewhere else.
Old 08-15-2011, 06:49 AM
So put me on a highway
It can be done.
Engine sound mat
1985 911 Euro Cab.
Old 08-15-2011, 07:21 AM
Bear911's Avatar
Interesting, a lot of different opinions. I did it by removing the CIS boot. OEM mat slid in there without to much trouble. Good fit too, only needs a little glue at the top to keep it perfectly on position. Just make sure you don't drop old mat bits into your fuel injection when taking the old one out. I guess it depends on what you have in there at the moment.
Old 08-15-2011, 01:39 PM
