arbita1's Avatar
Tool for Removing Heat Exchanger Nuts
I got the left side heat exchanger off, but I'm having a bit of trouble with the right one.
All three barrel nuts are removed and I'm left with the three nuts. I have a bunch of wrenches/sockets, but nothing seems to give me the right access to try and turn the nuts. The engine case seems to get in the way.
What do you guys use? Also, the engine is removed and on a stand.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-28-2011, 12:35 PM
Less brakes, more gas!
euro911sc's Avatar
I have a set of 'distributor' wrenches. They worked. also craftsman swivel sockets. If you put a swivel on a socket its too long so you need the integrated kind. Also crowsfoot sockets and stubby box wrenches.
Make sure you know which nuts came off what studs. Mine were of two different sizes. IE for some I needed a 13 and for some a 12. Its a PITA, but you just need to find that special tool combo for each one.
Oh, a sidewinder socket wrench helps to. That's the socket where you have a T handle and just turn the T and the socket spins. Its very useful other places as well like CV bolts and starter nuts.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-28-2011, 12:53 PM
snap-on 3/8 drive, 13mm chrome wobbly socket and long extension. and oxy/acet heat on the nut first.
206 637 4071
Old 09-28-2011, 01:04 PM
Been here a while
yup, I'm with John Walker, of course....I have some universal short sockets, snap on, in 12mm and 13mm, these will do it.....when you buy SSI's you get a 12mm bent closed end wrench.
looking for 1972 911t motor XR584, S/N 6121622
Old 09-28-2011, 01:36 PM
All the above, although I never had much problem with a long offset boxed 13mm wrench.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-28-2011, 02:41 PM
83 911 Production Cab #10
JJ 911SC's Avatar
+1 on the "offset boxed 13mm wrench".
Mine came from some tool kit from my 1st car back in the 80's. A Lada, the Russian version of the Fiat 124 Glad I keep the tool pouch
BTW some of those copper nut comes in a 12mm version.
Who Will Live... Will See
Old 09-28-2011, 02:56 PM
ROW '78 911 Targa
timmy2's Avatar
+1 That's what I used.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-28-2011, 03:04 PM
Spiderman
Jesse16's Avatar
Same +1 on the 6pt swivel socket. Like the term "wobbly socket", gotta remember that one. I got a 3/8" drive x 10 and 13 mm one from Sears and find I use them quite frequently. Nice purchase. I saw mention that a 1/4" drive version was nice but didn't find I needed that myself.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 09-28-2011, 06:45 PM
Recreational User
porschenut's Avatar
The actual term is "wobble socket", in case anyone plans to do an internet search
Old 09-29-2011, 05:22 AM
great tools to have
i have found these socket adapters real handy and perfect for removing heat exchanger nuts just use an open end wrench and a short socket and better with a ratcheting wrench. is as handy as a regular socket wrench in tight spots harbor has them for about $10
Old 09-29-2011, 06:20 AM
arbita1's Avatar
I'm going to give my offset box wrench another try tonight.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-29-2011, 07:06 AM
arbita1's Avatar
I got them all off. The offset box wrench took off 2. And the dremel took off the last. So I have 1 broken one. I guess not bad out of 12. So do I need the $40 stud remover or are there.other ways.
Matt.
83 911SC
85.5 944 NA - Sold
Old 10-01-2011, 01:35 PM
JJ 911SC's Avatar
Matt
Post a picture of the broken stud as well as what cylinder. Depending where it is you might need different approach. I had one on #6 outside that the stud puller could not be fitted. To my surprise ( was going to try anything at that point), got the sucker out with a bolt out.
Old 10-01-2011, 02:35 PM
arbita1's Avatar
Originally Posted by JJ 911SC View Post
Matt
Cylinder No. 2 on the inside stud.
Matt.
83 911SC
85.5 944 NA - Sold
Old 10-01-2011, 03:58 PM
did you use heat, or just crank the nuts off? heat works on the nuts, but not so much on the studs. cut it flush, drill dead center with a pilot drill and finish with 17/64. if you were centered, there's just the threads remaining and they can be pulled out like a spring. that's the beauty of christian's tool. if you're off-center, finish the job with a timesert kit.
206 637 4071
Old 10-01-2011, 04:17 PM
JJ 911SC's Avatar
Good location, plenty of room to work with.
Start spraying PB Blaster but if the engine is still in it will not be going down the stud.
You need a straight stud puller and an air gun.
You start at 25 LB for about 20 seconds, and increase by 5 pound at the time. Mine got out at 50 Lbs.
The straight stud puller Top Right on pics
As soon as I can find the picks of the set up; Air gun/Puller/Stud I'll update.
JJ 911SC's Avatar
OK found the pics
This is a straight in line stud extractor. They seem hard to find, the place I got mine from does not carry them anymore and no result from Google!!!
Found it... http://www.amazon.com/Titan-Stud-Puller-Drive-Model/dp/B00265M8N4/ref=sr_1_1?ie=UTF8&qid=1317529228&sr=8-1 (I pick up mine on sale at $10 at the Canadian version of HF Tool)
Old 10-01-2011, 05:07 PM
too many projects 1983 sc
56 nomad's Avatar
[QUOTE=JJ 911SC;6286397]OK found the pics
alright i'll bite, how well did it work?
when i looked at the website it looks like a step drill..is it similar to a stud extractor, meaning it must be pre-drilled and centered to get it out..any chance of it snapping off?
.thanks ,ben
Old 10-01-2011, 07:22 PM
JJ 911SC's Avatar
[QUOTE=56 nomad;6286627]
OK found the pics
.thanks ,ben
??? Link has been change.
I have update to a different link.
I got 7 of the 12 the studs using it.
Amazon.com: Titan Stud Puller - 3/8in. Drive, Model# 16023: Home Improvement
Old 10-01-2011, 08:24 PM
irrelevant on seized nuts but
I use Snap-On 1/4" 6 point wobble sockets. I can't confirm but I believe they're shorter than other brands.
then nickle anti-seize on studs with new gaskets.. then recheck after a few run-cold cycles. Torque specs for the nuts are less than 20#
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-01-2011, 08:49 PM
