Northern Motorhead
wildcat077's Avatar
OK to use a TORX 55 socket to remove flywheel ?
Hey guys,
I would like to know if it's allright to use a TORX 55 socket to remove the flywheel bolts.The Torx is a six point socket and it seems the bolts are 12 point and require a special socket ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-06-2011, 03:39 PM
AutoBahned
RWebb's Avatar
No!
Use the correct triple square
Old 10-06-2011, 03:43 PM
Wer bremst verliert
JohnJL's Avatar
If you strip it out it is a pain...you can get triple-square bits from sears.ca or Babco.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-06-2011, 03:44 PM
Northern Motorhead
wildcat077's Avatar
Thanks guys,
That's what i was thinking,just called my local auto parts supplier to order one ...
Is it OK to use an impact gun to remove the flywheel bolts ? It worked well for the pressure plate fasteners !
Cheers !
Phil
Cheers
Phil
Old 10-06-2011, 03:54 PM
AutoBahned
RWebb's Avatar
sure
Old 10-06-2011, 04:09 PM
Hmm, I've seen the correct tools for sale at several regular old auto parts stores.
Porsche wasn't the only manuf to use them.
Maybe it's different up there, eh?
Old 10-06-2011, 05:40 PM
Chain fence eating turbo
I've used a Torx to remove and replace my flywheel bolts a couple of times. No problems, just keep square to bolt head and lots of pressure holding it against the bolt.
Old 10-06-2011, 05:45 PM
Northern Motorhead
wildcat077's Avatar
Steve,
Not to worry,i found a set that i will be picking up after work tomorrow!
Imagine that !
One cannot have too many tools
I'm in the middle of an engine drop due to an exploding clutch and i caught the "while i'm there " syndrome ... lol
Cheers !
Phil
Cheers !
Phil
Cheers
Phil
Old 10-06-2011, 06:04 PM
You can usually pick up a set of 4 at places like O'Reilly, Autozone, etc...
You could always order them from Pelican Parts for $14.75
http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_CAT332_pg12.htm
Lisle 60750
Old 10-06-2011, 06:11 PM
Good to know.
Old 10-06-2011, 06:17 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Napa is pretty common in Montreal. They have them.
J F MECANIQUE INC
2251 SAINTE-CATHERINE ST E, MONTREAL
514-521-4949
My favorite parts store in Montreal was always Chez Paree.
Old 10-06-2011, 06:28 PM
Bob Kontak's Avatar
I know New Beetles and Passats use them on drive axles. Probably Audi, too.
Old 10-06-2011, 06:30 PM
al lkosmal's Avatar
Heat is your friend when removing these bolts. I use a propane torch to heat up the bolt (it doesn't take much) and they typically come right out. (using a triple square bit). W/O heat they are much harder to remove.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 10-06-2011, 07:40 PM
Northern Motorhead
wildcat077's Avatar
Can anybody confirm if i need an 11mm triple square bit for the flywheel ???
That seems to be the equivalent of a Torx 55 ...
Cheers !
Phil
Cheers
Phil
Old 10-06-2011, 07:41 PM
efhughes3's Avatar
I wouldn't touch these with an impact. Too easy to strip. With the flywheel locked down and a good-sized 1/2" ratchet or breaker, I've never had an issue to remove these. As mentioned, heat may be of assistance on those that need it.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-06-2011, 08:21 PM
Bob Kontak's Avatar
No - See Masraum's link - they do not come in odd # metric sizes. (well, I don't think they do) Probably 12 but I cannot say for sure. I will check the Porsche parts catalog and report back.
Edit - nothing in the parts catalog that defines the bolt socket size with granularity. Also, the parts link provides nothing and the 901/915 clutch replacement provide nothing (tech info center)
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-102-206-00-M58&catalog_description=Flywheel%20Bolt%20%28sold%20pe r%20each%2C%20%39%20req%2E%29%2C%20%39%31%31%2F%39 %31%31%20Turbo%20%28%31%39%37%38%2D%38%39%29%20
http://www.pelicanparts.com/techarticles/911_clutch_replace/911_clutch_replace1.htm (references "special tool") I remember it being 12mm.
Old 10-06-2011, 08:40 PM
AutoBahned
RWebb's Avatar
take a steel hammer & smack the bolt head flat on - i.e. normal to the axis of the bolt
Old 10-06-2011, 08:42 PM
I had a couple of fwd dodge/plymouth products that were vintage '78-82 that used VW 1.7L motors and transaxles. They used them for the head bolts. I believe I was also told that Ford Pintos used them for something too.
Old 10-06-2011, 09:25 PM
Bob Kontak's Avatar
Not the sexy Horizon? Owned one. The intoxicating 1979 edition. What a babe magnet. Sadly, I had no soft Corinthian Leather. In fact, no air conditioning and vinyl seats (in Houston) and the friggin inner fender strut mounting shell rusted at the spot welds and pulled away from the inner fender requiring me to use 30" of all thread to pull the suspension back together and then the front engine mount rusted out and the engine dropped four inches. But I digress.
Old 10-06-2011, 09:53 PM
al lkosmal's Avatar
when you say it like that...it sounds bad.
RGruppe #669
Old 10-06-2011, 10:09 PM
