Lorenfb's Avatar
"I'm not sure if you would need a logger with CIS if you have a display. It seems like you could only tune for full throttle, or maybe for fuel economy, since there is only one adjustment and it affects the entire range."
That's exactly right on! And using the WUR as an adjustment for the AFRs has
the same effect as the mixture screw, i.e. Both vary the control pressure which
affects the full range.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-29-2012, 07:11 AM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Does this look familiar?
1974 Porsche 914 race car - $1500 (Kailua)
Wow! that looks just like my 914!! I wonder...............
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 02-29-2012, 07:24 AM
Banned
I respectfully submit that you are mistaken - I know for certain that adjustments to the WUR have much more dramatic effects to control pressures/AFRs than the mixture screw does. The mixture screw affects idle AFRs but only has a very minor effect on the mid and top ranges while adjustments to the WUR have dramatic effects all across the board. This has been well documented time and again with wide-band meters both on the road and on dynos . . .
Old 02-29-2012, 08:34 AM
Lorenfb's Avatar
"I respectfully submit that you are mistaken - I know for certain that adjustments to the WUR have much more dramatic effects to control pressures/AFRs than the mixture screw does."
So! The key point is that they both affect the same thing, i.e. the control pressure,
and over the full range. And for most/all situations, only very small changes are
required to tweak the AFRs unless a major problem exists. This excludes situations
where an external ECU is used to selectively change the control pressure at certain RPMs.
Bottom line: A monitor of the AFRs has limited utility other than to make a change
of the mixture over the full range, and not like the utility for an EFI system.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-29-2012, 08:42 AM
2porscheguy's Avatar
Originally Posted by Ronnie's.930 View Post
There were severaly threads on this when I did a quick search - here is one:
Modified my WUR
I am a DIY person, but for this I just sent mine to the WUR guru, Brian Leask.
Another guy, well know on this board, Brian Bodart - RarlyL8 Motorsports, even stocks already modded WURs that you can buy . . .
Ronnie's.930, any idea how much a modded WUR goes for, for an '80SC?
Alex
Alex
'80 911SC Targa
'06 997 C4S Coupe - SOLD
'07 997TT Coupe
Old 02-29-2012, 05:26 PM
Banned
Brian Leask charges about $350.00 to mod a Turbo WUR don't know about SC. His also comes with an excellent, comprehensive guide to tuning and a tool as well.
Brian Bodart is very easy to get in touch with - RarlyL8 is his handle on this board. I believe that he works in concert with Leask (or did at one time).
Here is one of Bodart's threads:
Show & Tell, help me restore this neglected 930
Once nice thing about both is that you tell them about your engine, ignition and fuel system (mods etc) and they "pre-set" the adjustments - it seems they are usually pretty close if not spot on (based on feedback on this board).
Old 02-29-2012, 06:14 PM
This is the one that I have and it is great. You can get it from our host and on the setup I have you can log RPM, AFR, vacuum/boost. Up to 2 hours worth and download with a USB connector to your PC or laptop.
I have used it very successfully with my MFI 2.7 motor. Could not do without it. And it is an easy Porsche installation with no need for other parts, like a tach adapter, and a data logger and and....$$$
This is my installation AFR is the lower gauge. Upper one is a volt meter. There is a switch on the right to turn off the voltmeter so you don't get confused with AFR
Here is the main unit. This box, a cable and a wideband sensor is the whole setup. The internals are mil-spec and really high quality.
Here is what the kit looks like. Comes with everything including software. The cable is made in China.......the rest right here in the USA. Check more information at http://www.daytona-sensors.com/WEGO4.html loads of information here.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-29-2012, 06:29 PM
Looks like a nice unit. Data logging is a plus, I'm only really worried about what's going on when I'm hard on the gas in 3rd or 4th.
I just found out I'll have to swap the exhaust studs for some longer ones for the thick-flanged SSI's.
I'm excited though as none of the exhaust nuts were seized
Tom
Old 02-29-2012, 06:44 PM
Here is a chart from the supplied software
03 Boxster
Old 02-29-2012, 08:26 PM
So, are those dips in the green line indicative of when you shifted into the next gear?
Tom
Old 02-29-2012, 09:22 PM
proffighter's Avatar
No, rpm's are increasing while AFR's are jumping, looks like a bad CIS
Shifting looks like this:
Roland
930 Turbo '81 Too many modifications to list
Old 03-01-2012, 12:18 AM
Have you tested the PLX unit yet, how did it turn out?
Old 03-06-2012, 08:34 AM
Waiting on new(longer) exhaust studs. Just got a call that they've arrived. Hoping to get everything done this weekend so I can report the results
Hopefully the old exhaust studs won't be too hard to remove..........
Tom
Old 03-06-2012, 06:30 PM
Originally Posted by theFONZ View Post
I have been thinking of getting an Innovate kit also. Please let us know how this one works out.
I'm not sure if you would need a logger with CIS if you have a display. It seems like you could only tune for full throttle, or maybe for fuel economy, since there is only one adjustment and it affects the entire range. I could be wrong though, I'm still learning about CIS.
So my understanding is that without the adjustable WUR, one can only make one adjustment to fuel enrichment which entails adjusting the AFR at WOT. Should this be done "under load" or by simply applying the throttle until redline and adjusting the mixture to your desired AFR? Does being under load affect the AFR at WOT?
Thanks!
Alex
Alex
'80 911SC Targa
'07 997TT Coupe
Old 03-07-2012, 01:19 PM
Took me awhile to finish as the first 2 studs came out easily while the remaining 10 broke
So, after much, much cursing I mulled over pulling the motor to flip it in order to drill and time-cert the offending portions of the studs.
In the end I drilled them on the car(thank God for the lift @ work) and time-certed them.
Thank fully the w/b kit I have had just enough length in the wires to do the install. After I check for oil leaks from the new oil lines, I took her out for a good spin.
After warm-up, at idle I was seeing afrs of 14.6 or so which is good. Under load in 3rd and 4th I saw 12.3-12.9 and 13.5 under cruise(moderate load). I was a bit concerned when I first fired it up as I was seeing the afr @ 12.1, but once warm(above 170 deg on the gauge) it fell in line.
Now that that's done on to the next project!!
On to raising the spindles on my Bilstein strut housings
Tom
Old 05-06-2012, 12:24 PM
Functionista
manbridge 74's Avatar
Thanks for the followup.
Was this on E10 or pure gas?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-06-2012, 01:35 PM
Good ole 92 octane
Tom
Old 05-06-2012, 05:00 PM
I can't wait to save up enough cash for some Weber/PMO's to see if this will be helpful
Tom
Old 05-06-2012, 05:01 PM
