1974 Carrera power windows not working
Hello All,
I need some assistance with my 74 Carrera. My power windows are not working. They have been fine for the 8 years I have owned the car, but when I went to roll them up the other night, they were dead. I checked the fuse box, the fuse appeared good, but I replaced it anyway, still nothing. I am stumped.. Any help would be appreciated. Jeff
Jeff 1974 Euro Carrera 2.7 MFI 1966 Corvette 427 Coupe 2002 996 (Daily-Driver) |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
P/W Issues.
Assuming no wiring mods, it almost has to be in the fuse CKT. Check for a loose wire at the bottom of the fuse holder, dirty/corroded fuse holder. Hope this helps. Good luck, Gerry Manuals
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I have the same car as you,....
![]() The ceramic fuses are a red herring: you cannot tell anything by looking at them. Replace them with new ones and try again. Tighten the screws holding the wires, too.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks Guys.. I will take a relook tonight..
Also check the relay. You may have to swap the relay with another one that's used for something else - but, at least you will know.
+1 on switching the fuse besides just looking at it. I have blown a fuse before that looked perfectly normal. |
Jeff,
Is that GP White or another color? Mine is Chiffon. Alex
'74 Euro Carrera * '64 356SC Coupe |
Hey Alex, It is GP White..
Well I replaced the fuse, cleaned the contact and checked screws. Still no luck.. Any other suggustions ?
Member 911 Anonymous
Since you checked the fuse, get a DVM to make sure your are getting 12 volts at the fuse and at the switches.
or Swap the switches around to see if you can repeat the failure. I recently had an issue with my driver side switch that controls the passenger side window. It would work infrequently, but the passenger side worked just fine. Swapped the switches and Driver Side worked as it should. Luckily I had a spare switch and replaced the bad switch. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
