1974 Carrera power windows not working
Hello All,
I need some assistance with my 74 Carrera. My power windows are not working. They have been fine for the 8 years I have owned the car, but when I went to roll them up the other night, they were dead. I checked the fuse box, the fuse appeared good, but I replaced it anyway, still nothing. I am stumped..
Any help would be appreciated. 
Jeff
Jeff
1974 Euro Carrera 2.7 MFI
1966 Corvette 427 Coupe
2002 996 (Daily-Driver)
Old 02-23-2012, 10:20 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
P/W Issues.
Originally Posted by JTH 36 View Post
Hello All,
Jeff
Jeff,
Assuming no wiring mods, it almost has to be in the fuse CKT.
Check for a loose wire at the bottom of the fuse holder, dirty/corroded fuse holder.
Hope this helps.
Good luck,
Gerry
Manuals
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-23-2012, 10:39 AM
I have the same car as you,....
The ceramic fuses are a red herring: you cannot tell anything by looking at them. Replace them with new ones and try again. Tighten the screws holding the wires, too.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-23-2012, 10:49 AM
Thanks Guys.. I will take a relook tonight..
Jeff
Old 02-23-2012, 11:20 AM
Also check the relay. You may have to swap the relay with another one that's used for something else - but, at least you will know.
+1 on switching the fuse besides just looking at it. I have blown a fuse before that looked perfectly normal.
Old 02-23-2012, 11:57 AM
naparsei's Avatar
Jeff,
Is that GP White or another color? Mine is Chiffon.
Alex
'74 Euro Carrera * '64 356SC Coupe
Old 02-23-2012, 01:26 PM
Hey Alex, It is GP White.. Well I replaced the fuse, cleaned the contact and checked screws. Still no luck..
Any other suggustions ?
Jeff
Old 02-23-2012, 05:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Since you checked the fuse, get a DVM to make sure your are getting 12 volts at the fuse and at the switches.
or
Swap the switches around to see if you can repeat the failure.
I recently had an issue with my driver side switch that controls the passenger side window. It would work infrequently, but the passenger side worked just fine. Swapped the switches and Driver Side worked as it should. Luckily I had a spare switch and replaced the bad switch.
Jim
'85 Carrera Targa
PCA/POC
Old 02-23-2012, 07:54 PM
