Throw it on the ground!
Switch to Kendall oil appears to have solved my long-term chain rattle issue!
In connection with a recent breakdown in Asheville I met Scott Spence, long term Porsche mechanic and engine rebuilder in CA with Bruce Anderson who now owns German Motor Werks in Asheville. We spoke about my long term chain rattle that I've had with my orig engine and replacement engine (installed 2 years ago) Rattle occurs consistently at high engine temps and low gear low RPM conditions.
He said perhaps it is the oil I'm using and suggested Kendall. When working on race teams in the old days he stated that they would ship Kendall overseas for races. He changed the oil and adjusted the valves two weeks ago and so far no chain rattle! I think the Valvoline VR1 Racing oil I've been using gets too thin at high temps and the hydraulic tensionsers don't work properly. I've had this chronic problem for several years with two different engines so this change to Kendall and the elimination of chain rattle is huge for me. Just wanted to share. I'm surprised that a simple change in oil could have such a profound impact on tensioner performance. (now using Kendall 20W 50 dino vs Valvoline VR1 20W 50 dino racing oil)
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 03-05-2012 at 04:01 AM.. |
been using GT1 for years. good stuff...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
The real Kendall (original),is now Brad Penn.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Reiver
Taking it apart is easy
Anyway, all of this can be found on the gargantuan oil thread here on PP.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Formerly known as Syzygy
Maybe the Kendall GT1 is the same as Brad Penn, but with a different sticker on the bottle? You know seeing that BP purchased the stuff - recipe, facility or whatever...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
ah. the misinformation that flows on the internet.
Kendall today is not the same as Brad Penn. Its owned by Connoco Phillips... and has enough of the ZDDP (around 1200 ppm) for our engines. I have cases of brad penn in my garage as well.. got a great deal on Amazon.. but the "new" GT1 is a very good oil... has been tested over and over again... which is why its listed as acceptable on the monster oil thread. It really hasnt changed in awhile...
Wrong
Reiver
Well I'll be flumoxed and hornswoggled....1200 ppm ZDDP!
The Kendall name was purchased by Conoco some years back and they now produce Kendall products in their refineries. In the purchase, they did not buy the Bradley, Pennsylvania refining facility, and that facility is the one that produces the Brad Penn products. That refinery produces their products using the original Kendall formulas, ergo the Brad Penn oil is the old original Kendall product (that everyone has raved about) except with the Brad Penn name. I use nothing but Brad Penn in my car, and it is readily available in the Atlanta area, at great prices! Check this thread for details.
ATTN: Atlanta area Pelicans, found local source for Brad Penn oil.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 03-04-2012 at 06:51 PM.. |
Phosphorus, wt % 0.108
Titanium, wt % 0.010 Zinc, wt % 0.119 Above is the newest formulation... 20w50. I suppose that .119 is not the same as .12. (insert sarcasm...) You are fine with easy to get GT1 or VR1. Best place to get brad penn on most days is Amazon if you have prime, because with prime.. shipping is FREE.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 03-04-2012 at 07:06 PM.. |
![]() What made the original Kendall GT-1 such a "magic" product was the unique base stocks pumped close to their refinery in NW Pennsylvania. Brad-Penn uses the same thing and its superior as a lubricant, compared to other like products. People who are far smarter than me attest to the qualities of Pennsylvania crude as used for oils. As a consumer of the original Kendall products since 1965, I can personally attest to what they did that others didn't. Unfortunately, I have no idea what Conoco-Phillips uses in their current version of GT-1 race oil and they are not likely to tell me. Given how expensive our engines are, I'll not use any other non-synthetic oil in a customer's or my own car unless I have no other choice. Naturally JMHO,
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
While there are plenty of choices, we use either Motul 300V 15w-50 or Mobil 1 V-twin 20w-50 oil. Both are exceptional products for the air-cooled engines with excellent base stocks and additive packages.
Member 911 Anonymous
Congrats Mark on the fix! I wish the best for you and your baby.
Not for noting, but I had the opposite issue, when I switched to BP I started to get chain tensioner noise, scary shiznet, switched to VR1 and never heard it again. Crazy I know, I really liked how BP kept my baby cool but the leaks were just unbearable.If the noise rears it's ugly head with VR1, then I may have to consider Kendall GT1. Question for the guru's, I did not know the original Kendall formula had 20% synthetic like today's Brad Penn?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 03-04-2012 at 10:10 PM.. |
The original Kendall GT-1 was purely a dino oil. I think Brad-Penn added the 20% synthetic content to improve cold flow.
I used the org Kendall oil but this was a long time ago, wasn't it some funky color like green?
72 911 Although it is done at the moment, it will never be finished. |
Blue
Gary Kozun 83 911SC Cabriolet |
![]() Brad-Penn still is.
