Throw it on the ground!
Switch to Kendall oil appears to have solved my long-term chain rattle issue!
In connection with a recent breakdown in Asheville I met Scott Spence, long term Porsche mechanic and engine rebuilder in CA with Bruce Anderson who now owns German Motor Werks in Asheville. We spoke about my long term chain rattle that I've had with my orig engine and replacement engine (installed 2 years ago) Rattle occurs consistently at high engine temps and low gear low RPM conditions.
He said perhaps it is the oil I'm using and suggested Kendall. When working on race teams in the old days he stated that they would ship Kendall overseas for races. He changed the oil and adjusted the valves two weeks ago and so far no chain rattle! I think the Valvoline VR1 Racing oil I've been using gets too thin at high temps and the hydraulic tensionsers don't work properly. I've had this chronic problem for several years with two different engines so this change to Kendall and the elimination of chain rattle is huge for me. Just wanted to share. I'm surprised that a simple change in oil could have such a profound impact on tensioner performance. (now using Kendall 20W 50 dino vs Valvoline VR1 20W 50 dino racing oil)
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 03-04-2012, 02:10 PM
brads911sc's Avatar
been using GT1 for years. good stuff...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-04-2012, 03:02 PM
The real Kendall (original),is now Brad Penn.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-04-2012, 03:08 PM
Reiver
Reiver's Avatar
The stuff he shipped overseas in 'the old days' is now B Penn as they bought the Kendall platform,,,,Kendall is now reg oil not prop up to snuff for flat tap motors.
Old 03-04-2012, 05:14 PM
Taking it apart is easy
Jerome74911S's Avatar
Kendall GT-1 20W50 sold today is advertised as being appropriate for high performance flat-tappet camshaft engines. It states that it has high ZDDP (I don't have the numbers in front of me).
Anyway, all of this can be found on the gargantuan oil thread here on PP.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 03-04-2012, 05:24 PM
Formerly known as Syzygy
Canada Kev's Avatar
Maybe the Kendall GT1 is the same as Brad Penn, but with a different sticker on the bottle? You know seeing that BP purchased the stuff - recipe, facility or whatever...
Kevin
Old 03-04-2012, 06:25 PM
brads911sc's Avatar
ah. the misinformation that flows on the internet.
Kendall today is not the same as Brad Penn.
Its owned by Connoco Phillips... and has enough of the ZDDP (around 1200 ppm) for our engines.
I have cases of brad penn in my garage as well.. got a great deal on Amazon.. but the "new" GT1 is a very good oil... has been tested over and over again... which is why its listed as acceptable on the monster oil thread.
It really hasnt changed in awhile...
Old 03-04-2012, 06:43 PM
brads911sc's Avatar
Wrong
Originally Posted by reiver View Post
the stuff he shipped overseas in 'the old days' is now b penn as they bought the kendall platform,,,,kendall is now reg oil not prop up to snuff for flat tap motors.
Old 03-04-2012, 06:45 PM
Reiver
Reiver's Avatar
Well I'll be flumoxed and hornswoggled....1200 ppm ZDDP!
Old 03-04-2012, 06:47 PM
The Kendall name was purchased by Conoco some years back and they now produce Kendall products in their refineries. In the purchase, they did not buy the Bradley, Pennsylvania refining facility, and that facility is the one that produces the Brad Penn products. That refinery produces their products using the original Kendall formulas, ergo the Brad Penn oil is the old original Kendall product (that everyone has raved about) except with the Brad Penn name. I use nothing but Brad Penn in my car, and it is readily available in the Atlanta area, at great prices! Check this thread for details.
ATTN: Atlanta area Pelicans, found local source for Brad Penn oil.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 03-04-2012, 06:49 PM
brads911sc's Avatar
Phosphorus, wt % 0.108
Titanium, wt % 0.010
Zinc, wt % 0.119
Above is the newest formulation... 20w50. I suppose that .119 is not the same as .12. (insert sarcasm...)
You are fine with easy to get GT1 or VR1. Best place to get brad penn on most days is Amazon if you have prime, because with prime.. shipping is FREE.
Old 03-04-2012, 06:58 PM
Finally, an accurate statement,....
What made the original Kendall GT-1 such a "magic" product was the unique base stocks pumped close to their refinery in NW Pennsylvania. Brad-Penn uses the same thing and its superior as a lubricant, compared to other like products. People who are far smarter than me attest to the qualities of Pennsylvania crude as used for oils.
As a consumer of the original Kendall products since 1965, I can personally attest to what they did that others didn't. Unfortunately, I have no idea what Conoco-Phillips uses in their current version of GT-1 race oil and they are not likely to tell me.
Given how expensive our engines are, I'll not use any other non-synthetic oil in a customer's or my own car unless I have no other choice.
Naturally JMHO,
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-04-2012, 07:54 PM
Zinc, wt % 0.119
Depending on what valve springs are in use, you may not be fine with those percentages, based on what I've seen. Those are marginal for OEM springs, however aftermarket ones are stiffer and place more demands on the oil's EP package.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-04-2012, 08:01 PM
Canada Kev's Avatar
Naturally JMHO,
OK, Steve, since you mentioned it (and hopefully not to continue another oil debate thread unnecessarily) what would your choice in synthetic oil be?
Kevin
Old 03-04-2012, 08:06 PM
While there are plenty of choices, we use either Motul 300V 15w-50 or Mobil 1 V-twin 20w-50 oil. Both are exceptional products for the air-cooled engines with excellent base stocks and additive packages.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-04-2012, 08:39 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Congrats Mark on the fix! I wish the best for you and your baby.
Not for noting, but I had the opposite issue, when I switched to BP I started to get chain tensioner noise, scary shiznet, switched to VR1 and never heard it again. Crazy I know, I really liked how BP kept my baby cool but the leaks were just unbearable.
If the noise rears it's ugly head with VR1, then I may have to consider Kendall GT1.
Question for the guru's, I did not know the original Kendall formula had 20% synthetic like today's Brad Penn?
'85 Carrera Targa
PCA/POC
Old 03-04-2012, 10:03 PM
The original Kendall GT-1 was purely a dino oil. I think Brad-Penn added the 20% synthetic content to improve cold flow.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-04-2012, 11:16 PM
tobluforu's Avatar
I used the org Kendall oil but this was a long time ago, wasn't it some funky color like green?
Old 03-05-2012, 05:52 AM
Blue
Gary Kozun
83 911SC Cabriolet
Old 03-05-2012, 06:44 AM
Yessir, thats correct.
Brad-Penn still is.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-05-2012, 08:40 AM
