wayner's Avatar
Here is a link to a good discussion thread with people weighing in on the merits of sealing versus not sealing.
I've added my own conclusions with my own point added on pages one and particularly at the top of page two.
To "Glue" or-not-to "Glue!
NOTE
I'd like to leave the glue or no glue discussion for that other thread. It already has some good back and forth/pros and cons discussions building there.
I'd like to keep this one for ideas and evidence.
If you have pictures to add, feel free to contribute those here.
I hope between these two threads we can spare more cars form the carnage...
SOLD - 914 wide body hot rod
Old 05-13-2014, 05:08 PM
88 Carrera, Guards Red
azhodge's Avatar
OMG!!! these cars are pieces of ****, why do we buy them????
Old 06-14-2014, 08:15 PM
wayner's Avatar
Update:
In the thread above (glue or not) To "Glue" or-not-to "Glue!
we have been discussing if the seals should be installed dry or not.
After all my experimenting in a combination of 80 to -40 degree weather, my own conclusion is that dry is a risk unless your car is guaranteed to stay indoors during wet weather. Remember, once water gets inside the seal it will take an awful long time to dry out since there is no airflow between the seal.
People don't like the idea of glue though.
Per the advice of Timmy2, this is what I am now using:
3m glazing compound
For those of you who are not ready to pull out your glass but are concerned about adding protection, mask the area either side of the seal, squeeze some in under the seal, and clean up the excess using a rag dampened with mineral spirits. It cleans right up
OR, if you are installing the seals, add a bit inside the track during install.
I think the stuff is the perfect solution, and for those ill fitting corners, it even comes in strips that can be added to the body before installing the glass.
If you ever have to redo the glass for some reason, then cleanup is not so bad either.
Old 06-27-2014, 05:58 AM
SWMBO
azzarule's Avatar
The Parcel shelf in our 72 was a basket case, as was the bottom of each seat well in the rear, luckily we had a friend with a complete parcel shelf and rear seet clip which we used for replacements. A lot of work in a very confined space to cut prepare and weld in the new pieces, but totally worth it of course. Thankfully no rust in the front footwells or around the front windscreen. Rear problems were all based on the rear shield seal. If only the PO had replaced it. There was no indication on any part of the car that you could actually see, that the rust was under the carpet or seat pads.
But during an engine swap, a screwdriver through the parcel shelf from the engine compartment gave it away!
1985 911 Carrera Cabriolet GPW - Marilyn
1972 911T GPW- Pusha (IT LIVES)
1961 356B Heron Grey -Miss Daisy (currently in restoration)
2000 HSV GPW (goes fast,everytime!)
2003 Indian - Spirit
Old 08-29-2014, 06:20 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Wow what a mess. I think the car would always have had a very damp, musty smell to it if there was that much moisture creating all that rust?
Kevin L
'86 Carrera "Larry"
Old 08-29-2014, 07:12 AM
wayner's Avatar
What is surprising is how much moisture the under padding can hold without the carpet ever feeling damp!
Glaze those seals
Here is how-to
Window Glass Install - Modified Mustangs & Fords Magazine
Old 09-13-2014, 05:24 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
One more thing I've added to the "I Must Check This Out" list!
I know it's a little old now but Thanks for your post wayner
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 10-19-2015, 12:06 PM
wayner's Avatar
Thanks for keeping this thread visible
NOTE to anyone reading:
While I agree that a fresh stock seal installed correctly an be made not to leak, why risk it? Why the hesitation to glaze that new seal as added prevention for when it shrinks or heat cycles?
Glaze those seals. It cleans up easily with mineral spirits even years later
Old 10-19-2015, 01:08 PM
wayner's Avatar
My favourite quote from page one of this thread.
Check your seals everyone!
No, it didn't sit in salt water. It got used in the rain. Lots of it.
That's the point of this thread. There are a bunch of places that water will collect in a 911 body shell if it gets wet. This is made worse when seals fail, rubber gets old, damage is not corrected, etc. Get it wet often enough and it will rust.
Porsche expected its cars to get more servicing than is typically done. I don't mean oil changes but thorough inspections. All the little things that the typical owner ignores completely... They had some long warranties agaist rust perforation but they required that you do an annual (or bi-annual, I don't recall) inspection of the underside of the car and correct any issues.
That still won't solve the rust issues in certain places, as some of that can't be seen without disassembly. They all rust, some sooner than others.
JR
Old 10-30-2015, 10:39 AM
wayner's Avatar
On another thread, here is the debate:To "Glue" or-not-to "Glue!
and here is my advice
Originally Posted by wayner View Post
At this point I have concluded that as Timmy2 suggests, using 3m glazing compound or similar product to act as a flexible, thin, non hardening membrane between the seal and the glass, or the seal and the body is the ounce of prevention that these cars need if they are regularly used and exposed to the elements. I see no down side. It can be cleaned up more easily than urethane sealant, using just mineral spirits, and will adjust with the shrinkage and expansion of the seal with weather or over time.
I see no reason not to use it on the front windshield as well (unless you want to use a more permanent glue to stop movement).
If done properly, you shouldn't have to use any sealant, but I like this stuff just in case
This how-to article was just posted by 3litre on another thread here.
They use the same non hardening 3M glazing compound
I am adding it here for future reference
Lets keep this thread for evidence of why to check or replace seals, and use this other thread to debate if they should also include sealant or not here : is the debate:To "Glue" or-not-to "Glue!
Old 10-30-2015, 10:51 AM
Well I live in Florida......where all car get rained on...HARD! And you are never more than maybe 50 miles from the ocean. My 89 is pretty clean (I think), and my new '75 needs a little TLC. I will be going through that one first.....and will be giving both (AND my 996TT) and god once over.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 02-23-2016, 01:58 PM
wayner's Avatar
Here is another one.
This time a Carrera 3.2 (galvanized) car.
check those seals!
(fortunately this one was saved and given a second life by its owner...)
Another Retro Backdate Thread
Old 04-26-2016, 04:51 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
I've had nightmares about this thread for two years. I'm finally pulling my glass to investigate (full thread coming soon, I'm sure), but here's what I found in the front window channel, passenger side.
Just the beginnings of surface rust. Now this car is galvanized, has always been garaged, and previous owners were in Kentucky and Oregon. If rust is happening under those circumstances, it is likely happening in a lot of circumstances.
Seal gap was 2-3 mm on the top and bottom center.
Now, trim refresh, reinstallation, and then on to the Targa window.
Thanks, Wayner for the heads-up!
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 02-17-2018, 08:41 AM
ghamilton's Avatar
When I got some stone chips in my windshield this summer Hagerty paid to have it replaced.
My shop recommended factory seals, Hagerty said no problem, they even said I could replace the plastic trim even though my shop was able to replace it without any cracking.
And, it was nice and dry behind the seal.
The diff in $ between an OEM and factory is well worth it compared to the cost of repairing rust damage.
BTW Hagerty was great to deal with.
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 02-17-2018, 01:06 PM
wayner's Avatar
I have had leaks in my new factory oem seals
Seasonal temp swings between +30 to -30 might contribute
A small dab of the 3m product listed above has kept the 2nd installation dry
In fact if you do have an older car and suspect leaking, a dab under the lip of the already installed seal does wonders
The stuff is almost the consistency of toothpaste, never hardens and wipes off easily with mineral spirits
I don’t see a downside to this safety measure. It’s not a glue or urathane
Old 02-17-2018, 01:44 PM
Coram Deo
RDM's Avatar
I have two tubes of the 3M glazing compound ready to go when the time is right. You apply after installation? Also, how did you clean the window channel? Someone had a leak before and there's goop in there.
Dru
Old 02-18-2018, 05:15 AM
wayner's Avatar
Scroll up to post #50 for an installation video using the stuff
Error on the side of very little rather than too much. Think of it as creating a very thin gasket rather than filling it with goop
A very very light smeer ( almost a lubricant dab, in fact it does lubricator the seal for installation)
The body to seal Chanel, but also the glass to seal Chanel
After installation it allows the seal and glass to react better to thermal expansion/contraction by lubricating but also self healing the waterproof barrier created by the rubber seal
Wipes up easily with mineral spirits even years later
Many people who believe their dry installation remains dry, actually develop what I call micro-leaks and don’t realize it
Old 02-18-2018, 07:55 AM
wayner's Avatar
To clean up someone else’s mess from using some different material, if it’s hardebrd scrape it. If it’s goopy try mineral spirits although if it is some other material then something like goo gone may work better
Old 02-18-2018, 08:22 AM
Coram Deo
RDM's Avatar
Just in from taking the Targa window out. Lots of stuff that seemed like gum from under the desks (yes, I teach). I thought it was just old rubber seal, but it's lotsa what looks like plumber's putty. Is that normal?
Dru
Old 02-18-2018, 11:38 AM
Burnin' Rubber
Koizumi's Avatar
Why windshield trim should be a regular maintenance item.
No matter how many OEM windshield rubber seals I get installed, the rubber “drops” below the roofline curvature in places over a short period of time. Not good and very much an annoyance that I can’t seem to ever rectify.
Old 02-19-2018, 03:05 AM
