Shuz
Lets play name that missing part
While replacing the Alt on my 81 Targa; I discovered a connector with a missing mate, which was located in the right hand side of the engine compartment.
Can someone recognize what am I looking at?
And where may I find the other end of whatever is suppose to connect here.
Thanks for playing!
RBL>
Old 07-21-2012, 09:58 PM
ROW '78 911 Targa
timmy2's Avatar
Goes to the back of the thermal valve on my '78. Item #24 on the Parts ID page here:
CIS Primer for the Porsche 911
I don't know if you have one on your year. Follow the vacuum line from the bottom of your WUR. if you have one, that is where it goes.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-21-2012, 10:09 PM
Shuz
I apologize for the ignorance, but what does it do?
RBL>
Old 07-22-2012, 06:19 AM
ROW '78 911 Targa
timmy2's Avatar
Delays vacuum being applied to the wur diaphram during a cold start for a short time.
Old 07-22-2012, 07:55 AM
Jim Williams's Avatar
If the '81 has it's stock CIS, it won't go to the thermal valve. The thermal valve wasn't used on the '81, as the WUR wasn't vacuum operated. As far as I know, '79 was the last year for the thermal valve.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 07-22-2012, 08:44 AM
those were black taped to the engine loom down by the warmup regulator.
206 637 4071
Old 07-22-2012, 10:43 AM
Shuz
In short, just a loose wire that I need not worry about... Correct?
Old 07-22-2012, 08:18 PM
ROW '78 911 Targa
timmy2's Avatar
Based on the year and Jim William's and John Walker's input....forget about it!
Might want to tape it up and tuck it out of the way though.
Dennis
Old 07-22-2012, 10:09 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Correct. The wire harness was carried forward from earlier years and that was a part/connector not deleted.
1981 911SC Targa
Old 09-13-2012, 08:14 AM
