Shuz
Lets play name that missing part
While replacing the Alt on my 81 Targa; I discovered a connector with a missing mate, which was located in the right hand side of the engine compartment.
Can someone recognize what am I looking at? And where may I find the other end of whatever is suppose to connect here. Thanks for playing! RBL>
ROW '78 911 Targa
Goes to the back of the thermal valve on my '78. Item #24 on the Parts ID page here:
CIS Primer for the Porsche 911 I don't know if you have one on your year. Follow the vacuum line from the bottom of your WUR. if you have one, that is where it goes.
Shuz
I apologize for the ignorance, but what does it do?
RBL> |
ROW '78 911 Targa
Delays vacuum being applied to the wur diaphram during a cold start for a short time.
If the '81 has it's stock CIS, it won't go to the thermal valve. The thermal valve wasn't used on the '81, as the WUR wasn't vacuum operated. As far as I know, '79 was the last year for the thermal valve.
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) |
those were black taped to the engine loom down by the warmup regulator.
Shuz
In short, just a loose wire that I need not worry about... Correct?
ROW '78 911 Targa
Based on the year and Jim William's and John Walker's input....forget about it!
Might want to tape it up and tuck it out of the way though.
Fleabit peanut monkey
Correct. The wire harness was carried forward from earlier years and that was a part/connector not deleted.
1981 911SC Targa |
