How can I upgrade my 3.0 engine
What can I do to gain some HP on this non computerized engine. I already did an exhaust but I do not know what else I can do that is relatively easy without doing a rebuild with a cam, etc. Any suggestions?
carbs
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
This one's easy. Follow the link and don't look back
Finally registered with Pelican- Introduction |
ROW '78 911 Targa
EFI, Bitz kit or TBI's for more horse power with fuel efficiency and tuning ability.
Add EDIS as well. I'm headed that way this fall. |
No cis
I just went through all of this. CIS sucks and is too temperamental. Go with aN EFI setup or carbs. Drove a buddies car with webers and a secret cam grind....very nice and responsive.
ROW '78 911 Targa
HP to weight ratio... Put it on a diet. Multiple threads here for getting your car slim and trim.
Now in 993 land ...
Throwing carbs on it isn't really an "easy" modification.
Porsche already did the easy stuff, unfortunately. These cars aren't like some american iron, where hp may be found a little easier. On my SC I had put 964 grind cams, SSI + dansk sport muffler, and increased the advance a little over spec. I also took some weight out of it - not too crazy. You can follow the link in my sig describing the car. Eventually it was too slow and uncomfortable, so I bought a 993. ![]() G |
ROW '78 911 Targa
You really need to define what you are looking for. That new screwbaru will give you a run for your money...
SSI's and a good exhaust are good for what, 15 HP increase, EFI is touted at 25 HP increase, same with carbs, so with both you may gain 35 to 40 hp. That takes you from 185 to 215 HP in a fairly heavy vehicle. Do both and lighten it up and you'll be rockin.... Or, stick a 3.6 in it and go.... Last edited by timmy2; 08-23-2012 at 10:24 PM.. |
Do cars get smogged in NY, or is that only done in California?
No smog here for now but you never know.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Senior Member
SSI's and a free flowing muffler will really help.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
^this
my 83 has carbs, 964 cams and euro compression... none of that gave me a seat of the pants improvement as significant as simply doing the SSI's... Im a brooklyn native , hope you dont park that beauty on the street
-Vinny 1983 911SC |
Reiver
another perspective.
I have other cars with huge HP, they are fun but I can't really 'drive' them without breaking multiple laws unless on a track. My '83 sc makes about 200 hp and I I've lightened it up considerably. It is nimble and I can flog the hell out of it and enjoy it. I can use the cars rpm range and it is much more street fun than some of my other cars with more than twice the HP. Get a few more HP, lighten it up and drive the hell out of it. |
Now I'm just plain addicted. Dean
2017 Toyota Tacoma TRD Sport(Hate it) 1965 Chevy Biscayne |
Senior Member
Second thing is that until the suspension and brakes can handle every last horse power you have on tap, then you are going to have a substandard car. Upgrade your brakes first, they are the main safety item on the car. Then do the suspension, re-doing the bushings, torsion bars, sway bars and so on to make the car really handle with what power you have now, and expect to have in the future. Then and only then focus on the engine and the first thing to do with the engine is upgrade the exhaust! Joe A
This is how I'm personaly going about my car. No sense in engine improvement untill suspension and brakes are up to snuff. And yes exhaust is key to realize full potentional of engine mods. Dean
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Obviously this stuff varies from car to car but in the case of the 3.0 I believe the stock system is less than ideal. I've "upgraded" exhausts on lots of different cars and never had such a drastic change as in my 911.
-Vinny 1983 911SC |
Senior Member
Vinny,
The newer your car is, the worse the exhaust is in terms of performance. Thats why the SSI's systems are a direct copy of the early Porsche factory exhaust system. It did ONE thing, get the exhaust out of the engine. Later model exhausts had to deal with smog, noise and last forever, so Porsche changed things and it was not always for the good.
The stock 3.0 SC HE primaries are too short and of unequal lengths, offering very little, if not 0 scavenging effect. The SSI's and early factory HE have primaries of longer and equal length and merge at a location that optimizes scavenging. That's why they make power throughout the rpm range and not just in the upper end.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
