Juggino's Avatar
Send a message via AIM to Juggino
How can I upgrade my 3.0 engine
What can I do to gain some HP on this non computerized engine. I already did an exhaust but I do not know what else I can do that is relatively easy without doing a rebuild with a cam, etc. Any suggestions?
Old 08-23-2012, 07:35 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
carbs
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 08-23-2012, 07:38 PM
tshebib's Avatar
This one's easy. Follow the link and don't look back
Finally registered with Pelican- Introduction
Old 08-23-2012, 07:40 PM
ROW '78 911 Targa
timmy2's Avatar
EFI, Bitz kit or TBI's for more horse power with fuel efficiency and tuning ability.
Add EDIS as well. I'm headed that way this fall.
Old 08-23-2012, 07:57 PM
SWoolley's Avatar
No cis
I just went through all of this. CIS sucks and is too temperamental. Go with aN EFI setup or carbs. Drove a buddies car with webers and a secret cam grind....very nice and responsive.
Old 08-23-2012, 08:14 PM
ROW '78 911 Targa
timmy2's Avatar
HP to weight ratio... Put it on a diet. Multiple threads here for getting your car slim and trim.
Old 08-23-2012, 08:46 PM
Now in 993 land ...
aigel's Avatar
Throwing carbs on it isn't really an "easy" modification.
Porsche already did the easy stuff, unfortunately. These cars aren't like some american iron, where hp may be found a little easier.
On my SC I had put 964 grind cams, SSI + dansk sport muffler, and increased the advance a little over spec. I also took some weight out of it - not too crazy. You can follow the link in my sig describing the car. Eventually it was too slow and uncomfortable, so I bought a 993.
G
81 SC (sold)
Old 08-23-2012, 09:56 PM
ROW '78 911 Targa
timmy2's Avatar
You really need to define what you are looking for. That new screwbaru will give you a run for your money...
SSI's and a good exhaust are good for what, 15 HP increase, EFI is touted at 25 HP increase, same with carbs, so with both you may gain 35 to 40 hp.
That takes you from 185 to 215 HP in a fairly heavy vehicle.
Do both and lighten it up and you'll be rockin....
Or, stick a 3.6 in it and go....
Old 08-23-2012, 10:21 PM
Do cars get smogged in NY, or is that only done in California?
Old 08-24-2012, 04:03 AM
kodioneill's Avatar
No smog here for now but you never know.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-24-2012, 06:01 AM
Senior Member
SSI's and a free flowing muffler will really help.
Old 08-24-2012, 07:04 AM
Vin-barrett's Avatar
^this
my 83 has carbs, 964 cams and euro compression... none of that gave me a seat of the pants improvement as significant as simply doing the SSI's...
Im a brooklyn native , hope you dont park that beauty on the street
-Vinny
1983 911SC
Old 08-24-2012, 07:56 AM
Reiver
Reiver's Avatar
another perspective.
I have other cars with huge HP, they are fun but I can't really 'drive' them without breaking multiple laws unless on a track.
My '83 sc makes about 200 hp and I I've lightened it up considerably. It is nimble and I can flog the hell out of it and enjoy it. I can use the cars rpm range and it is much more street fun than some of my other cars with more than twice the HP.
Get a few more HP, lighten it up and drive the hell out of it.
Old 08-24-2012, 08:58 AM
Excellent point and one of many reasons I chose a torsion bar 911 as a fun car.
Now I'm just plain addicted.
Dean
2017 Toyota Tacoma TRD Sport(Hate it)
1965 Chevy Biscayne
Old 08-24-2012, 09:05 AM
Senior Member
Originally Posted by Vin-barrett View Post
^this
Thanks, and one of the many things that a lot of people do not understand about engines is, until you can get the exhaust out in an effecient fashion, it does not matter what you do with carbs, ignition and so on, the inability to get the exhaust out will always hold you back.
Second thing is that until the suspension and brakes can handle every last horse power you have on tap, then you are going to have a substandard car.
Upgrade your brakes first, they are the main safety item on the car. Then do the suspension, re-doing the bushings, torsion bars, sway bars and so on to make the car really handle with what power you have now, and expect to have in the future. Then and only then focus on the engine and the first thing to do with the engine is upgrade the exhaust!
Joe A
Old 08-24-2012, 09:15 AM
Joe A
Great Advice.
This is how I'm personaly going about my car. No sense in engine improvement untill suspension and brakes are up to snuff. And yes exhaust is key to realize full potentional of engine mods.
Dean
1965 Chevy Biscayne
Old 08-24-2012, 09:46 AM
Scott R's Avatar
Joe A
+2 Brakes were my single greatest upgrade.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-24-2012, 09:54 AM
Agreed, I have always been in the camp where the thoughts of "cat back" exhaust upgrades were kinda voodoo in that they may add a little hp at the top and little to none and maybe even a loss at the bottom.
Obviously this stuff varies from car to car but in the case of the 3.0 I believe the stock system is less than ideal. I've "upgraded" exhausts on lots of different cars and never had such a drastic change as in my 911.
-Vinny
1983 911SC
Old 08-24-2012, 10:10 AM
Senior Member
Vinny,
The newer your car is, the worse the exhaust is in terms of performance. Thats why the SSI's systems are a direct copy of the early Porsche factory exhaust system. It did ONE thing, get the exhaust out of the engine.
Later model exhausts had to deal with smog, noise and last forever, so Porsche changed things and it was not always for the good.
Old 08-24-2012, 10:32 AM
Josh D's Avatar
The stock 3.0 SC HE primaries are too short and of unequal lengths, offering very little, if not 0 scavenging effect. The SSI's and early factory HE have primaries of longer and equal length and merge at a location that optimizes scavenging. That's why they make power throughout the rpm range and not just in the upper end.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 08-24-2012, 10:48 AM
