First Engine Drop and Rebuild
After finding 5 broken studs on my sc, I have decided to have a go myself to get it fixed. I have a chance that way of getting it on the road next, rather than saving for another 1-2 years to get someone to fix it for me.
Ordered a high lift trolly jack and stands last week that turned up yesterday, unfortunatly the jack is fault so has to go back. Made a start tonight, removed all 12 exhaust nuts (nothing broke ) and removed the complete exhaust system. Next disconnected the air pump and six plugs. I will try to keep this updated as I do things, as I am sure i will need lots of help. I haven't a full picture of the car, it's been in my garage for years, but at least you can see the colour ! ![]() And a picture of how messy the engine is ! One or two leaks to sort out as well.
The Dude abides...
Rock on westyguesty! I'll be doing the same (hopefully this winter) on my 87 where I encountered 4 broken studs.
Are you going with steel studs or the others? I'm subscribed and will anxiously follow your story as you proceed. Good Luck...
Steve '03 Carrera 4S |
Awesome!!! You are on that like Bill Clinton on Monica Lewinsky!
Good job. Keep the pics coming.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Great project!
Just a suggestion, buy some zip lock plastic bags and put the fasteners (nuts, bolts, etc.) in a bag labled with location or purpose. Makes things much easier when putting it back together!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Yes, going for standard steel studs, only using it for mild street use, so I think it's the best option for me. Ordered them, plus nuts,washer,gasket set and blanking plugs. Should get them next week.
...you are the chosen one, this never happens.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Usually you leave the exhaust on when removing the engine. It provides a safe platform for lowering the engine.
81 Targa, Bamboo Beige, 3.2 SS |
That make sense, I was going to try to remove just the exhaust and leave the heat exchanges there, but all the bolts were rusts, cut them off and it still wouldn't budge. Now it's all off, i should be able to seperate them and put the heat exchanges back on to help balance the engine.
Managed to spend a few more hours tonight, oil drained, no particles on plugs although the tank plug was fairly gummy. Oil pipes disconnected (could not believe how difficult the hard line was to remove ! definately deserve a berr after that one), harness and wires unplugged.
Not sure, but I am short on space, so was planning to leave the gearbox where it is, found and loosened the three nuts, but can't find the one by the start motor, only two nuts that hold the starter on. What am I missing ? If am leaving the gearbox in place, do I need to disconnect the clutch linkage ? Where do i disconnect the throttle linkage ? I had a few bits turn up today, these, plus gasket set. Fitted the emission plugs.
Engine drop the hard way......
Westy, I think you are a good DIY'er or even a good technician shown by your work. The time and effort you spent removing the exhaust unit in situ needed more time and effort doing it than the conventional way. Second, dropping the engine without the transmission would be more difficult than dropping the whole thing together. Why make the work more difficult when you could do it the easy way? I'm not saying you are wrong!!!! I believe you have not done this work before (911 engine drop) but have some experiences with other engines. While a few have done the 'engine only', doing it solo is not simple when you install the engine back. It is your choice to decide which manner you want it done. And keep us posted. Tony |
ROW '78 911 Targa
You will have the room if you do it right.
Drop the motor and tranny together. Roll it out the garage door behind you, and then pull off the tranny onto a cheap Harbor Freight furniture dolly, and slide it under the car with the starter and exhaust parts. Then work on the engine. Last edited by timmy2; 09-05-2012 at 03:06 PM.. |
Keep the tranny and engine together. But, if you want to leave the tranny in place, the last barrel nut is on top above the starter.
I would have left the exhaust in place too, drop the engine on to a dolly and roll it out. Then separate the gear box, mount the engine on to a stand, then remove the heads and get to the studs. That is how I did it.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks, will go for removing as one then, the gearbox could do with a good clean anyway. Is it just the cv joints to remove as the extra step, plus the extra mounts.
pay it now or pay it on the way back in.
one of the nuts holding the starter also holds the engine on. the upper one.
you can disconnect the throttle cable at the bellhousing and at the engine. you do need to disconnect the clutch cable but you could leave the rest of the linkage in place. Quote:
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
OK, you have convinced me, gearbox coming out as well. Needs a good clean anyway.
Driveshafts dropped dropped tonight, tight to get off, and the bolts didn't 'crack' loose, everyone felt like it rounded as it came free, but all out
ROW '78 911 Targa
You'll thank us later when you put it all back in...
![]() Good luck and go slow and carefully. Good time to clean up engine bay and replace sound pad if needed too! Post pics as you go. Ask questions when you need to. I replaced the lower studs on mine last fall. Some info on mine here starting around post 28: Finally, back in the game!
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 09-06-2012 at 03:22 PM.. |
Tired Member
Where are you located? There may be Pelicans near by who can lend a hand.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Do you have Wayne's rebuilding book?
ROW '78 911 Targa
+1, if not, get it, you'll need it.
