Tori's Avatar
Dash lighting - not instruments
As a newb, i'm not quite certain what is supposed to be illuminated on the dash....
At night i see the Defrost symbol it lit on the right side of the heater/vent controls, but the left side seems dark. I assume there is a bulb out.
What all is supposed to be lit ?
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 11-21-2016, 07:54 PM
Banned but not out, yet..
RSBob's Avatar
Everything on the left of the wheel is dark. On the right rear window defrost and both sides of the air control levers box should be illuminated, but good luck getting your hands back there. Otherwise everything is pretty dark. Using a small screw driver you can pry off. The faces of the knobs and take a look for yourself.
Old 11-21-2016, 08:27 PM
You can replace the bulbs by laying on your back in the drivers footwell and pulling the bulb holders out from behind. It's a bit of a PITA but doable. I found mine were in pretty rough shape. I had to re-solder the seats for the bulb holders back on the wiring. I've also seen where they have gotten too hot and the bulb holders have melted. Have to pull them out and see. There are 4 in total.
I don't remember 100% but maybe the fan symbol lights up when you slide the top lever to the right on an SC.
Old 11-21-2016, 09:04 PM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
When you turn the vent fan on, more lights come on.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 11-21-2016, 09:30 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 doable, just a real PITA to do, if you remove the seat, it will be more comfortable.
These are type of bulbs that's in there.
'85 Carrera Targa
PCA/POC
Old 11-21-2016, 09:36 PM
Tori's Avatar
Thanks guys.
Jim, those look like #37 bulbs. Wonder if LED's are available. I'll dig into that area sometime in the future now that i know what to expect.
Also, did you guys know the up and down pointing tri-angles glow in the dark ?
Old 11-21-2016, 09:46 PM
DRACO A5OG's Avatar
Yes, so does the interior door handles round buttons
'85 Carrera Targa
PCA/POC
Old 11-21-2016, 09:55 PM
Tori's Avatar
WHAT !!! Round buttons ? I gotta run to the garage... brb.
ps.
https://www.amazon.com/Cutequeen-20PCS-White-1-SMD-Lights/dp/B00F6RC4JC/ref=sr_1_1?ie=UTF8&qid=1479794262&sr=8-1&keywords=37+led+bulb+white
Old 11-21-2016, 09:59 PM
Tori's Avatar
Crud, i'm missing my door handle dots. Are those available ? I'm also missing one of my vent control decals. Are those little guys available ?
Old 11-21-2016, 10:06 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Radio.
When I did mine, I pulled the radio.
easy-peasy...
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-22-2016, 02:59 AM
door handle dots available at host
928 part
Old 11-22-2016, 04:38 AM
Tori's Avatar
928 part
I looked for them here on the host site for a '87 928, couldn't come up with anything. Lil' help ?
Old 11-22-2016, 09:14 AM
Tori's Avatar
...and while we are talking dash lights, how is the lamp above the glove box door supposed to function ? I assume just like the rest of the interior dome lamps ? ON, OFF, or on with doors. ???
Old 11-22-2016, 09:16 AM
DRACO A5OG's Avatar
On, Off and with glove door.
As far as the dot: 928-537-747-00 Luminous Glow Dot For Door Handle Fits 911 1987-95 928
'85 Carrera Targa
PCA/POC
Old 11-22-2016, 10:10 AM
Tori's Avatar
Thank you brother Jim. I've got them in my "project list"
Old 11-22-2016, 06:07 PM
RSBob's Avatar
Oh, if you want to be 100% correct, which is highly overrated unless you are anal, then it's a way of life, there should be a light in the ashtray. Great way to keep you an eye on a joint if it went out. You are not anal if you let the joint go out, you are doing it just right.
Old 11-22-2016, 08:33 PM
