clock fix if anybody is interested
Kind of remember reading that a lot of clocks aren't working, as mine wasn't for 10 years till I told myself its already not working so I took it apart and fixed my clock in about 45 min total on a 73, very easy and quick if anybody is interested I'll post pics and instructions
Great ! please do.
Ron 73.5 T 74 R90/6 (Tupelo Honey) 86 Carrera (Plan B) 1987 BMW K100RS Motorsport |
Throw it on the ground!
Toby, my clock works but white second hand does not. Any ideas?
Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Hi
Yep please do , I'm also interested in your fix Fanof
911SC 83 132kmiles Black, Turbo tail Black leather interior |
well first i took out the clock, then the three little nuts on the back one has a lock on it I just broke that little piece so the nut could come off, then there are three more nuts on the inside back took those off. Basically its a wind up clock that rewinds every 20 sec or so with a magnet on a spring and a set of points that gives it power to wind. All that was broken on mine was the lead from the power in to the coil. Just tinned the points, soldered on a piece of metal from a resister and clipped it. resprung the little clicker when putting it back together and tick tick first two picks are were the wire was gone next two with resister soldered on. No pics of clipping it but you can figure that out and last two clock jumpered on battery and moving. Also in near the middle of the back a little to the right and up is a adjuster in case its running slow or fast and my second hand dosn't move but the clock moves. Haven't figured that one out yet Hope this helps some of ya
makes sense on the white hand now i don't have to worry about it thanks
Semper drive!
Toby,
Great fix! Thanks for the pics. Now I just gotta figure out how to keep my clock from becoming all blurry once I do the repair! ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
The point you soldered is basically meant to be a fuse. They originally used a low temp solder so that if it got too hot it would pop open. If you use standard solder, you run the risk of melting your clock. I put a really small diode in instead as I couldn't find the low temp solder.
I seem to be able to blow up small diodes with enough current so I thought it would be a good substitute for a fuse.
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
Thanks, I too was wondering why the second hand (lil white hand) was not moving
Just too phreaking simple
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
Thanks for the heads up on the low temp solder, think i'll leave the metal from the resister with reg solder and just put a .75 amp in line fuse before the clock. Maybe make it easier next time if it blows the fuse.
There was a guy selling a clock in classifieds about a week ago... said it worked except the second hand.
I had a clock in mine, it worked fine..., just as long as the engine was running??????? Just as soon as you turned off the car, the clock would go into "REST MODE" and not do a thing until I started the engine again. I guess it would have been a great hour meter of sorts, but you could not tell time. I picked up a used one from Oklahoma Foreign, was about $30.00 at the time. I removed the old clock, plugged in the "new" clock, it has been working perfectly ever since. I never could find out from anyone why the original one was acting like it was. I can't even remember the amount of times I took it out and checked it, but it never did work, except when the engine was running. I am very happy now that I can see what time it is, and the old one is in the box, I guess for parts if ever needed. Just my .02 on this subject.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... Last edited by 3.2 CAB; 05-22-2007 at 12:21 PM.. |
Okay, that is really wierd. At first, I thought you must have had a switched power connection that went off when the ignition was off. But if you replaced with another clock and didn't change any wiring, how does the new one work?
The coil that pulls the winder represents an inductive load. Is it possible the battery didn't have enough voltage to kick the coil and with the engine running, the alternator did have enough? Any EEs want to speculate?
Has worked great ever since. I still have no idea what the deal was. I did not change anything other than to remove old clock and plug in "new" clock. As far as the voltage as being a problem, the car always started and never had any low battery symtoms. It is still a mystery to me???
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
If someone has a coil that has actually failed, I'll bet you I can fix it. I would need a broken clock, or at least the coil, to dissasemle and examine. Count the turns of wire, the winding pitch, and the wire guage.. Mount the Coilform to this, and wind away... The blood of my life:
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Not as it seems
are you guys kidding on the white hand?
i assumed it was a rallye inspired thing? if you pull the knob out you can move it around the face and "mark" a time. as an enduro rider from way back time and distance can reveal average speed. you guys really are joking about the white hand right? my take may suck,,, but i had one. T$
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
My clock stops every winter - like clockwork. Then when it warms up, it works fine again. It also works in winter, after the car is started or if I move the hands. Living in SoCal, so I'm not talking sub freezing temps here. I have been lazy to take it apart, but looks simple enough. Tomorrow's project.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Sounds like the old lube is gumming up in the cooler weather. Probably it just needs cleaning and new lube.
Crusty Conservative
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
