SoCalSK8r's Avatar
Xmas break projects, what did you do?
I was fortunate to have a long winter break so I did quite a bit of maintenance on the cars:
-new pads & rotors, fluid flush on my daily driver
On the Carrera:
-new brake hoses front and rear, added speed bleeders
-brake flush
-pedal cluster rebuild
-new clutch spring
-adjust clutch
-detail wheel wells and clean wheels (while I had all wheels off)
-wash car
I didn't get around to replacing the shift coupler.
Oh ya, and I did get quite a few hours out in the canyons....,
Old 01-06-2013, 03:06 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Let's see... a new (rebuilt) alternator installation, chain tensioner update, fuel injection investigation, and investigating my centrifugal advance. Christmas was good to me this year.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 01-07-2013, 06:51 AM
redstrosekNic's Avatar
New Bosch foglights for the 924
Misc electrical issues rectified in the 924 (oil press. gauge, marker light, gauge lights)
Center console delete in 911
DIY leather shift boot for 911
Currently in the process of a pedal cluster rebuild, new clutch cable, and trying to sort the CIS throttle micro-switch.
Dustin
Old 01-07-2013, 07:01 AM
spsfiend's Avatar
Elephant Racing finned oil lines
Gerry
____________________________________
1987 Porsche 911 - OEM 930 Steel Wide Body
2008 BMW X5
2010 Toyota Tundra 5.7L CrewMax
Old 01-07-2013, 07:11 AM
cycling has-been
bkreigsr's Avatar
Old 01-07-2013, 08:13 AM
painted 4 wheels
got new set of tires
polished all 4 cars
brake job on a Cayenne
saw movies
ate a bunch of food and drank a bunch of wines
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-07-2013, 08:16 AM
JTL JTL is offline
JTL's Avatar
1. Installed 66mm wheel studs
2. Sent Tach to NHWS
3. Started installing new front seats and still working on it
4. Letherique'd stock seats
Cheers, Jt
-84 911 targa
Old 01-07-2013, 08:55 AM
ROW '78 911 Targa
timmy2's Avatar
Drop engine, replace rockers and shafts with rsr seals, install Bitz EFI and tune car, replace rear shocks, sway bar bushings and links. Engine back in and driving.
2 days off and weekends for my break....
Old 01-07-2013, 09:07 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Removed all glass, interior, electrical for redesign of interior (racecar). Will be installing flush mount side & rear lexan, repainting interior white after reinforcing safety cage & suspension and rewiring the entire car with new custom wiring.
Kevin L
'86 Carrera "Larry"
Old 01-07-2013, 09:09 AM
The Dude abides...
bigel's Avatar
Well, I...
Applied 20" of blown-in insulation in my under-insulated attic space
re-routed my rain downspout across the back of the house to a common discharge
Installed four, six-panel entry doors in the second floor of the house (oh and trimmed out those doors as well)
Installed a new Grohe shower arm and shower head and re-caulked the master bath
and partied my fanny off.
Who has time to work on the 911...
'03 Carrera 4S
Old 01-07-2013, 11:09 AM
Canyon Runner
70SC's Avatar
Porsche Crest headers
I did headers & some supertraps just for fun & lost 26 lbs & gained some good mid- top end power too Need to lower the rear again [/img]
Old 01-07-2013, 11:10 AM
fitchn's Avatar
1) Replaced fuse box with ATO style block from Fred Cook
2) Replaced instrument cluster backlights with LEDs from Etarga
3) Euro style H4's installed with 80/100W bulbs
4) Removed stock leather driver's seat and removed the leather to sew a seam that was coming apart.
5) Reinstalled front trunk heater system after 3 years (!) of sorting out a small electrical meltdown.
6) Lubed and aligned window regulators to fix slow window issue on both sides.
7) Then went for a drive along the front range of the rockies.
It was a good Xmas break!
Noah
79 SC
minerva blue metallic
Eureka CA / Boulder CO
Physics is like sex, yes there are some practical applications, but that's not why we do it.
Old 01-07-2013, 11:48 AM
Weseeeee911
Painted a flat deck lid and replaced my whaletail/rear deck lid. I also went for a number of coastal drives covering approx 700 miles
Al
80SC 95-present
Old 01-07-2013, 01:10 PM
tobluforu's Avatar
Stayed warm, bought a new steering wheel and put it in the closet. My car is in deep hibernation.
Old 01-07-2013, 01:23 PM
5:04's Avatar
Christmas day I installed some Rebel Racing Coilovers
Then New Years day I parked it in the garage and pulled the front control arms off to have them worked on.
that911.tumblr.com
Old 01-07-2013, 01:34 PM
Josh D's Avatar
Engine/tranny drop for clean, reseal, pinion bearing replacement and clutch. Also doing CV boots and grease repack. I'm not done yet.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 01-07-2013, 01:50 PM
911M491's Avatar
Oil lines; hard and soft, Aux oil cooler fan switch Oil lines restoration
Fuchs restoration Fuchs Restoration
Old 01-07-2013, 04:33 PM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-07-2013, 05:54 PM
Air Cooled
Craig_D's Avatar
Put my '78 SC up on jacks and pulled the front suspension off for a complete Elephant Racing rebuild, thread here.
It was bloody cold in the garage so I didn't get as much done as I wanted. But I progress a little bit each night. I found some nightmare problems that I solved with luck, so a new control arm, new spindle spacers and new bearings.
Even with the nightmare stuff, I still love it!
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 01-07-2013, 06:04 PM
al lkosmal's Avatar
Got this running
EFI MFI Gasser 001 - YouTube
And got this running
912 home 007 - YouTube
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 01-07-2013, 06:07 PM
