Xmas break projects, what did you do?
I was fortunate to have a long winter break so I did quite a bit of maintenance on the cars:
-new pads & rotors, fluid flush on my daily driver On the Carrera: -new brake hoses front and rear, added speed bleeders -brake flush -pedal cluster rebuild -new clutch spring -adjust clutch -detail wheel wells and clean wheels (while I had all wheels off) -wash car I didn't get around to replacing the shift coupler. Oh ya, and I did get quite a few hours out in the canyons....,
Coram Deo
Let's see... a new (rebuilt) alternator installation, chain tensioner update, fuel injection investigation, and investigating my centrifugal advance. Christmas was good to me this year.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
New Bosch foglights for the 924
Misc electrical issues rectified in the 924 (oil press. gauge, marker light, gauge lights) Center console delete in 911 DIY leather shift boot for 911 Currently in the process of a pedal cluster rebuild, new clutch cable, and trying to sort the CIS throttle micro-switch.
Dustin |
Elephant Racing finned oil lines
Gerry ____________________________________ 1987 Porsche 911 - OEM 930 Steel Wide Body 2008 BMW X5 2010 Toyota Tundra 5.7L CrewMax |
cycling has-been
73 911T MFI, 76 912E, 77 Turbo Carrera |
painted 4 wheels
got new set of tires polished all 4 cars brake job on a Cayenne saw movies ate a bunch of food and drank a bunch of wines
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
1. Installed 66mm wheel studs
2. Sent Tach to NHWS 3. Started installing new front seats and still working on it 4. Letherique'd stock seats
Cheers, Jt -84 911 targa |
ROW '78 911 Targa
Drop engine, replace rockers and shafts with rsr seals, install Bitz EFI and tune car, replace rear shocks, sway bar bushings and links. Engine back in and driving.
2 days off and weekends for my break.... |
Schleprock
Removed all glass, interior, electrical for redesign of interior (racecar). Will be installing flush mount side & rear lexan, repainting interior white after reinforcing safety cage & suspension and rewiring the entire car with new custom wiring.
Kevin L '86 Carrera "Larry" |
The Dude abides...
Well, I...
Applied 20" of blown-in insulation in my under-insulated attic space re-routed my rain downspout across the back of the house to a common discharge Installed four, six-panel entry doors in the second floor of the house (oh and trimmed out those doors as well) Installed a new Grohe shower arm and shower head and re-caulked the master bath and partied my fanny off. Who has time to work on the 911...
Steve '03 Carrera 4S |
Canyon Runner
I did headers & some supertraps just for fun
& lost 26 lbs & gained some good mid- top end power too Need to lower the rear again [/img]![]()
1) Replaced fuse box with ATO style block from Fred Cook
2) Replaced instrument cluster backlights with LEDs from Etarga 3) Euro style H4's installed with 80/100W bulbs 4) Removed stock leather driver's seat and removed the leather to sew a seam that was coming apart. 5) Reinstalled front trunk heater system after 3 years (!) of sorting out a small electrical meltdown. 6) Lubed and aligned window regulators to fix slow window issue on both sides. 7) Then went for a drive along the front range of the rockies. It was a good Xmas break!
Noah 79 SC minerva blue metallic Eureka CA / Boulder CO Physics is like sex, yes there are some practical applications, but that's not why we do it. |
Weseeeee911
Painted a flat deck lid and replaced my whaletail/rear deck lid. I also went for a number of coastal drives covering approx 700 miles
Al 80SC 95-present |
Stayed warm, bought a new steering wheel and put it in the closet. My car is in deep hibernation.
72 911 Although it is done at the moment, it will never be finished. |
Christmas day I installed some Rebel Racing Coilovers
![]() Then New Years day I parked it in the garage and pulled the front control arms off to have them worked on.
that911.tumblr.com |
Engine/tranny drop for clean, reseal, pinion bearing replacement and clutch. Also doing CV boots and grease repack. I'm not done yet.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Oil lines; hard and soft, Aux oil cooler fan switch Oil lines restoration
Fuchs restoration Fuchs Restoration |
Stahlwerks.com
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Air Cooled
Put my '78 SC up on jacks and pulled the front suspension off for a complete Elephant Racing rebuild, thread here.
It was bloody cold in the garage so I didn't get as much done as I wanted. But I progress a little bit each night. I found some nightmare problems that I solved with luck, so a new control arm, new spindle spacers and new bearings. Even with the nightmare stuff, I still love it! ![]() ![]() ![]()
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Got this running
EFI MFI Gasser 001 - YouTube And got this running 912 home 007 - YouTube regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
