I plan on adding an adjustable stop bolt on the footboard. Thanks.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Call 911
Shifter suddenly started rattling and feeling sloppy in my '88 and I knew exactly what failed - the shift rod bushing. So this past week I pulled it all apart and installed a new bushing plus ball socket piston. Not a bad job as it's all done from inside the cab. Biggest pain was getting the new bushing pressed into the shifter housing. I ended up using my belt sander on the bushing flange, trimming it down a bit. Bushing then popped into place using a wood block and plastic mallet. With these new parts fitted, plus the JWest urethane coupling previously installed, the car now shifts with an amazing feel of precision.
Dave Kirk My Porsche restoreth my soul. |
Dave,
Did you try soaking the bushing in hot water? Asking because I just ordered the kit from PP and was wondering if you did also |
83 911SC Cab
Last bolt torqued....
3.2 and 915 fully rebuilt with upgrades....last CV Bolt torqued, now it's break-in time!!
Call 911
Drone,
Got my parts from our host as well. Did not soak bushing in hot water but probably should have tried that.
Cleaned the nether regions, jetted the carburetors (back down to 170 airs),adjusted float levels, and cleaned the bugs off the glass.
Ubi bene ibi patria
Picked up some plated parts on Wed. On Thur - loaded the main chassis for transport to the painter.
First - some of the 'bling': ![]() Second - destination - painter's ![]() Car looks positively tiny on this 5-ton flat deck. The fenders, doors, hood, rear deck engine compartment lid, & bumpers were shipped separately. It's been a very long time to get to this date/point on this project. Needless to say "I'm stoked". The car comes back (hopefully) late next week - all this augurs well for a great summer. Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke Last edited by Hawkeye's-911T; 07-02-2022 at 10:14 AM.. |
When you find out that the shop the previous owner used doesn't know how to apply anti-squeel without hosing the seals.
![]() Looks like a rebuild is in the works. (Not leaking, just wet from pre-maintenance washing). Last edited by 917_Langheck; 07-02-2022 at 09:18 PM.. |
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
Thanks, I just swapped my sport seats out for these. Very comfortable, light and they get a lot of compliments.
RS Touring | Classic Touring Seats ![]() ![]()
Eva
Bought and installed a Rennline Cup Holder because 10 years of spilling coffee was getting old...
What an absolute POS this thing is... Supposed to be a single bolt install on seat slider. The center of the mount is machined too wide and didn't sit within the track as it's supposed to... Angle grinder skinnied it up quick... Then the other 2 ears on the outside of the mounting arm were too fat to slip underneath the track, as intended... So, after I cut off the ears and narrowed the center of the mounting arm, it fit. Today, I go to use it and the bottom of the cup holder itself, fell out... The 1mm allen screws holding it together backed out and were on the floor. I very seldom if ever about manufacturers, but a $100 cupholder that comes fkt up every way from Sunday... TRASH. 0 to 10 rating for quality, 1. 0 to 10 rating for forced ingenuity, 5.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- Last edited by 911SauCy; 07-03-2022 at 05:20 PM.. |
Call 911
Changed oil and filter and checked/adjusted valve lash on my '88 911. Also wet media blasted all 4 valve covers while removed. Refilled with Amzoil 15W-50 synthetic.
Went from Austria to Italy by train
![]() ![]() to do some sightseeing (Pisa) ![]() and a lot of driving ![]() ![]() ![]() and finally ![]() ![]() and back home by train again
Stefan '78 911 SC crashed & gone, but not forgotten '77 911 S www.carmania.at |
hit a deer...
'84 911 3.2 Carrera '83 911SC Targa - SOLD IG: @heuersandcarreras "I want to use it. That's what 911s are for." - Richard Hammond |
[QUOTE=Matthew_VA;11741443]hit a deer...
![]() I also hit a deer a couple of years ago, in a MC40. He was racing me and then decided to cut in front of me and I knocked him off his feet, he fell on the hood and he slid off and off the road. He survived as when I returned in opposite direction he was no longer on the side of the road. I still drive the car but with a wrinkle on the hood.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
Rebuilt my weber's last winter. Been tinkering with the jetting since. Got the idle jetting perfect. But, the transition, at about 3000, to the main jet has been going lean on my EGT with a little roughness. So with the help of Pierce Manifolds, I got some main air correction jets to play with. Other than the pain of removing the top of each carb to replace those jets, I've got her running sweet now. So finally with the summer wx in Oregon, I'm out driving her again.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
COL911
Confirmed, cleaned reinstalled positive battery terminal I thought was responsible for intermittent no start, only to over tighten and crack negative clamp, which was probably already cracked and the cause of the issue in first place! On the positive side, no pun intended, I should be ahead of the game after cleaning-will know for sure after installing new negative clamp tomorrow.
COL911
[QUOTE=COL911;11745096]Confirmed, cleaned reinstalled positive battery terminal I thought was responsible for intermittent no start, only to over tighten and crack negative clamp, which was probably already cracked and the cause of the issue in first place! On the positive side, no pun intended, I should be ahead of the game after cleaning-will know for sure after installing new negative clamp tomorrow.[/
I would replace the entire cable. I have seen corrosion all through a cable causing long term problems.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
![]() ![]() ![]() Installed all the rear brakes on my car and then test fit my new seats. Sent from my iPhone using Tapatalk |
Tags |
fuchs are ugly , stock sucks |
