LinkBack Thread Tools Rating: Thread Rating: 19 votes, 4.26 average.
bivenator's Avatar
Today I put the finishing touches on a front suspension and brake rebuild. Its the first time off jacks in about a year. It felt really good, in the morning the ride height will get the treatment.
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates
88 coupe
Old 01-12-2013, 07:42 PM
I ordered new axle shafts & CV joints from Pelican. Ohh, I also ordered an O-Ring so that I can remove the fuel tank screen and clean it, then put back without any leaks.
I put the car on jack stands in preparation of installing these when they get here Next weekend's project.
Vern
Old 01-12-2013, 08:11 PM
Rescuer of old cars
Arne2's Avatar
Originally Posted by 80-911SC View Post
Would you share your info on this .. pretty cool ....
The LED strip was from eBay, here. The LEDs could stand to be a touch brighter, but they still seem bright enough to me, especially mounted high at the top of the window.
The metal bracket is a scrap piece of thin sheet steel, bent into a tight V with one side taller than the other. The taller side of the V slips between the glass and the seal inside the car, the strip light attaches to the exposed side of the short leg of the V using double-sided tape. The picture below is taken from the passenger side inside the car, with the right edge pulled out of the seal a bit to show the bracket.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-12-2013, 08:26 PM
Installed new silicone PIAA wiper blades.
Unplugged ignition/door/seatbelt buzzer - which has been annoying.
-Derek
'84 911 coupe
Old 01-12-2013, 08:39 PM
drove it to work!
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 01-12-2013, 09:19 PM
Sugar Scoops Rule :)
dave 911's Avatar
bench bled my new master cylinder, and then relived my Navy days and said every cuss word known to man (and spilled all of the brake fluid back out again) after many repeated attempts to get the fill tubes into the grommets...including 2 trips to Sears hardware for different size bar clamps....I could not get that method to work for me.
I finally took the fill tubes and reseviour out, installed them in the MC outside the car and threaded them up through the firewall & footwell -- DEFINITELY the way to go. Had to remove the gas filler tube to gain access to the top holes. And still had at least 5 aborted attempts when one of the grommets wanted to start coming out the top of the MC from wiggling the tubes too much until I got my technique down...
2 rounds of bleeding done, and it rained good yesterday so all the salt is gone off the roads for the time being - yeah
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 01-13-2013, 04:27 AM
Bled my brakes..... AGAIN. Gee, this gets easy after the 20th or so time.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 01-13-2013, 04:58 AM
HJT911's Avatar
Allignment and final installation of my new front tow hook.
Old 01-13-2013, 05:55 AM
Front hub/brake/rotor install...and trying out the bling...;-)
Just Drove- Mild weather in Pa
Old 01-13-2013, 06:01 AM
Rob T.'s Avatar
i installed a oil pressure light in the dash..... right work for a sunday
Old 01-13-2013, 06:46 AM
Northern Motorhead
wildcat077's Avatar
I test fitted my new "used" OG Racing six point roll cage ...
Lots of work ahead before i remove the carpets and weld on the backing plates,and paint it black !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-13-2013, 06:58 AM
sjf911's Avatar
Despite the cold, I managed to spend the majority of the day in the garage doing mostly electrical work. Added 7 new sensors, an ECU expansion box, and lots of wire. Next is plumbing in the piping to log exhaust back pressure with the additional MAP sensor.
Current temp in garage:
View from the workbench:
New dual element ambient air temperature sensor mounted inside front bumper
All the electrical boxes with new and revised wiring
Engine wiring and sensors:
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 01-13-2013, 07:45 AM
dave 911's Avatar
I've found a good mix of Pink Floyd, Led Zeppelin and a little Cure thrown in provides the right Zen for bleeding. . . .
Dave
'76 911S Targa
Old 01-13-2013, 07:52 AM
Finished the wife's CTT rear brakes that I ordered the wrong pads for. Replaced the washer nozzle that must have got knocked by a snowbrush. All the while the 911 looks on forlorn and jealous.
Old 01-13-2013, 08:41 AM
Repainted inside of LH battery box on 70 where battery ate it up. Cleaned and primed yesterday. Wouldn't have found it for awhile if I hadn't been reinstalling the through the grill lights. Lucky.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 01-13-2013, 09:53 AM
Gene Smith's Avatar
Valve adjustment and oil drain. Now I'm going to check my chain tensioners and cam timing. I want to see if I can see why I have a chain rattle at low idle. I hear a slap when I shut it down too... Then I'll add some new Brad Penn and get it cleaned up for winter. Winter- brine on the NJ roads and too chilly for sailing.
Old 01-13-2013, 10:08 AM
Carrera3.2LG50's Avatar
Since it was in the mid-70s here in NC, I gave my venetian blue beauty a good wash.
My 8 year old daughter was my helper and manned the hose.
Old 01-13-2013, 10:44 AM
Garage Queen
PorscheGAL's Avatar
Got the short block back together. Cylinders and Pistons go on after lunch. Things have gone very well and weather has been a perfect 75-80 degrees all weekend for this project.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 01-13-2013, 11:12 AM
Pelican Parts Vendor
BRAIDusa's Avatar
Today I wished it was back from the fab shop so I could drive it
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 01-13-2013, 03:13 PM
Tags
fuchs are ugly , stock sucks
