LinkBack Thread Tools Rating: Thread Rating: 19 votes, 4.26 average.
Oh Haha's Avatar
Finally completed the stripping of one of the front wheels today.
I don't know why but I haven't touched them for a couple of weeks although I have just about all the time I want now.
Starting the other wheel this afternoon.
Pacific Blue
Wayne
Old 02-05-2015, 09:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3741 (permalink)
Upier's Avatar
I took out my alternator. I was getting an occasional grinding noise. I found the rear plastic cap had fallen out. The rear bearing has a lot of play so time for a new one.
During the removal the car gods got even for my super easy motor mount change by breaking spark plug wire #6 when trying to unweld it from the distributor cap. At least I have a source for a replacement.
'86 Targa (Mighty Mouse)
'11 997.2 Carrera S Coupe (To be named)
08 M3 - Sold
"Having a sports car that you only take to car shows is like having a race horse you only take to the petting zoo"
Old 02-05-2015, 09:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3742 (permalink)
Len 911's Avatar
I received a box with Pelican on the outside. New Door rubber and door stops for the old girl.
Old 02-05-2015, 11:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3743 (permalink)
KBOUSTANI's Avatar
i tighten the door tops and the door speakers.
no more raddle coming from there.
little fixes makes you proud when working on your porsche.
and after i got done with that i tighten all visable screws.i dont like hearing any raddles.
76 carrera 3.0 SSI W/M&K 1RARE76/]89 carrera 4 (964)SOLD
87 targa 3.2,fabspeed cat bypass,sw chip,m&k exhaust(sold)94 carrera 2 cabriolet(sold)00 carrera 996(sold)
95 993,red,meanest looking one(sold)
83 911 sc targa,my first porsche(sold)
Old 02-05-2015, 01:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3744 (permalink)
Doug&Julie's Avatar
Originally Posted by joefrantz View Post
If the shaft is just loose in the socket with the ball on the bottom, that's just an epoxy bond. A little heat and it comes right apart and you can re-stick it with some jb weld, or have it tack welded.
Finally getting to my shifter...and it's apart! Didn't even need heat. Once I pulled it out of the housing, I was able to twist it loose. Time for JB Weld...which I forgot to get before taking the shifter apart, so I'll have to get some when Julie gets back from work.
On another note...my shift bushings are brand new (earlier 2014). I slightly abraised the outside this one when pulling it off the ball with pliers. Not even sure if it would show up on a picture. Should I replace it? ..or is a fresh greasing enough?
Thanks all!
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 02-05-2015, 02:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3745 (permalink)
86FlatSix
JQ911's Avatar
finally got time to install the 1" spacers. getting used to the signal switch far out there
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 02-05-2015, 02:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3746 (permalink)
joefrantz's Avatar
Thanks all!
As long as you remove any burrs and it is not de-formed, I would re-use it.
Joe Frantz
73 911 T
Old 02-05-2015, 06:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3747 (permalink)
A few things in a day...or two
1. Replaced both oil lines from thermostat back, to oil tank and crossover pipe with high clearance units form Elephant Racing. With the car fairly low and wider than stocks rear wheels I should have done this a long time ago. The Elephant Racing units were of superb quality and went in easy.
2. Changed out my ducktail lid grill. I had a raw aluminum unit there prior but had not been very satisfied with its fit. I didn't blame it on the grill I had bought but more on that each and every FG part seems to be just a little different. I bought the grill material thru Amazon and cut it to fit right myself. Holes are of bigger size than my last and I switched to black to better match other pieces on the car.
3. Made a new radio delete plate, to match my horn delete, and bolted another plate with a couple of lap timers to it.
Pete Andersson
Pinstriped Early 911 Club
Old 02-08-2015, 06:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3748 (permalink)
universeman's Avatar
New Bilstein HD inserts in front (rears were done last weekend) and wow, what a difference! The old ones were totally shot. Does anyone know how to tell how old Bilstein inserts are from the part number stamped onto them? I'm curious. The new ones seemed to have a different (slightly) number...H1 instead of H0 at the end.
I had some steering wheel vibration at 65 mph that almost totally went away...which surprised me because I was sure it was tie rods or alignment (probably still needs both.)
Also tried to install the targa bar seal rivets (plastic jobbies, with the special tool needed to insert) but learned the heard way that the old rivets are broken off inside the seal/holes - so I'll need to R+R the seal to properly insert new rivets. $300 for the OEM and $500 for the Porsche orig - yep that's gonna be a pricey job.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 02-08-2015, 06:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3749 (permalink)
Doug&Julie's Avatar
Thanks, that's the plan. Got the shifter JB Welded back together and it will all go back together today...
Doug
Old 02-09-2015, 07:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3750 (permalink)
Doug&Julie's Avatar
Ta Da! ..mit console delete.
Now I need to give it a good cleaning and work out a place to put the hazard light and rear defroster switches (it looks like they'll reach the radio delete plate, so that's option #1).
Top tip...I greased pretty much every part of the shifter during install. I especially noted how the shifter was rubbing against the rubber buffer plate (pic below), and wondered if that was part of my problem with my getting into second gear...maybe the rubber buffer plate was swelling when it got hot, and the drag against the shifter made it harder to shift into second? Well I haven't had a chance to give it a proper drive yet, but at first impression it shifts a ton better. I can't tell you how thrilled this potential fix makes me.
Doug
Old 02-09-2015, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3751 (permalink)
Rescuer of old cars
Arne2's Avatar
Doug, I'm assuming from this that you've ditched the A/C?
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-09-2015, 05:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3752 (permalink)
Doug&Julie's Avatar
That was "ditched" by the previous owner, but yes, the climate control knobs are gone. Don't really need A/C here in the PNW anyway. As long as I've got heat...
I still have the power door lock switch, but most likely won't put that back anywhere as it's not necessary and doesn't interfere with operation otherwise. Turns out you have to keep the hazard switch plugged in...I took a drive without it and none of my turn signals worked (at least on the dash they didn't...and I'm pretty positive on the car they didn't either). Plug the switch back in...all is fine.
I pulled the radio a while ago, along with the cruise control module (that didn't work). Ironically, I may replace the cruise control module...in case I want to start taking long(ish) trips in the 911. ...maybe.
Doug
Old 02-09-2015, 06:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3753 (permalink)
79 Euro's Avatar
In the last 60 days,
Resprayed the roof
Replaced the side window gadget - window doesn't rattle anymore
Installed new fuel pump
Replaced oil pressure sending unit - Druck Press gauge works again
Replaced cam oil supply line - no more oil leaks
Andy Kay
Kennedale, TX
817.948.8538
1979 911 SC Euro - Guards Red
Old 02-17-2015, 04:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3754 (permalink)
Eva
911SauCy's Avatar
Stared at it under the cover in the garage that's 5F and cried on the inside
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 02-18-2015, 04:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3755 (permalink)
Installed a new set of Cocomats
Got some black/natural Cocomats. They really look sharp!
Also found a used fan control knob for $14 shipped from partsheaven.com - the OCD in me will really enjoy having that knob where it belongs...
Jason - Austin, TX
92 968 coupe
Old 02-18-2015, 04:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3756 (permalink)
Cocomats pic
Jason - Austin, TX
92 968 coupe
Old 02-18-2015, 04:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3757 (permalink)
toddu's Avatar
Sent my tach and speedo off to NHS. With the engine rebuild, I'm redoing tach to 8k RPM and moving redline to 7200. Speedo will be refaced to 150mph. Both changes should also make things easier to see with Prototipo wheel.
Todd
'81 SC
Old 02-18-2015, 05:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3758 (permalink)
Seems right now I'm playing with everyone else's 911s, knocked the snow off this one and stretched the short legs with the very snappy 3.4...
Old 02-18-2015, 07:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3759 (permalink)
GT2BH's Avatar
Changed the stock wires to Magnecors, installed a Dansk sport exhaust with bypass, and flushed my brake fluid and replaced with Motul RBF-660
'09 997 GT2
'86 911 3.2
'83 911 SC (work-in-progress)
Old 02-19-2015, 08:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3760 (permalink)
Tags
fuchs are ugly , stock sucks
