gt3racerich's Avatar
Nice cage and doors!
Rich
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant.
Old 07-10-2013, 10:17 AM
Danish 911S driver
Danish Dynamite's Avatar
Cage out again and is now at the painter to get powder coated... Time for more cleaning:
I recieved some special aluminum half-of-a-hinge from the US. Now it is time to get them on the doors:
Christian
1972 911 S - 3.0 MFI in the making of an ST:
http://forums.pelicanparts.com/porsche-911-technical-forum/733424-another-st-build-time-denmark.html
Old 07-27-2013, 02:55 PM
Danish 911S driver
Testfitting doors
The fit is really good! But requires a little work to match the fenders...
Christian
Old 07-27-2013, 02:58 PM
Rob T.'s Avatar
Hey christian
Very nice build, and i am excited how it will look when its done.
Mounting some lightweight doors is on my wishlist since years. Very cool.
But i noticed something at your roll cage.
The strut under the roof looks a little bit twisted, or is it just the picture?
Old 07-28-2013, 10:22 AM
Danish 911S driver
Hey Rob
Thank you. It will be good when done!
The doors are really nice. I am exited to see them painted.
I see your point. And it scared me
I checked once the cage got back from the powder coating. All straight!
/Christian
Originally Posted by Rob T. View Post
Hey christian
Christian
Old 08-03-2013, 11:44 PM
Danish 911S driver
I bought a set of the first generation big 930 brakes in the US. I still need to clean and check the calipers. But the discs went to my brake guy to have a small layer taken off. They are very straight and look great now:
Christian
Old 08-03-2013, 11:54 PM
Danish 911S driver
Off topic, but I just unpacked a box for my dad. A set of 46mm Webers.
They look like pure gold imho:
Christian
Old 08-04-2013, 12:00 AM
Flojo's Avatar
Great work; money well spent.
But please: cover your beautiful steering wheel ore use an old ragged one during all that nasty work.
Would be a pity if it gets spoiled!
Old 08-04-2013, 02:50 AM
Uncertifiable!!!
Uwon's Avatar
Hey Christian,
I have been following your progress and admiring your build for quite a while. I think that you have some '78-80 1/2 front 930 floating rotors. Have you got the hats as well? What size wheel rims are you contemplating? Just wondering as I have modified a full set myself to fit 16" Fuchs on a 3.2 based build.
Skål
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-05-2013, 07:57 PM
Danish 911S driver
Hey Uwon
Yes you are just right. I have the hats as well.
I just took then off when the discs were beeing cleaned. I will run 8 and 9 X 15" Fuchs. And I am also planning for a set of 9 and 10 X 15" Minilights
Hey Christian,
Skål
Old 08-09-2013, 12:19 AM
Danish 911S driver
The door project is coming along nicely:
Left side almost there!
Left side needs a little more:
Christian
Old 08-19-2013, 11:31 AM
Danish 911S driver
The tank filler came back from powder coting. And we made a bracket for it. I looks good, I think!
Testfitting:
Christian
Old 08-19-2013, 12:09 PM
Danish 911S driver
Left door almost there:
Pretty nice fit, I think
The last part of the rain gutter on the right side is now welded on. It still needs some more work, but it looks good!
/Christian
Christian
Old 08-24-2013, 01:10 AM
Danish 911S driver
Time for a little update. Rain gutters are done. Fenders and doors are done. And I am satisfied
Christian
Old 09-07-2013, 01:15 AM
Danish 911S driver
Other small things done.
The two holes where the fuel filler connection goes through the fender are closed - welded from the inside and sealed:
The plates where the battery boxes normaly are are now sealed and the fuse box holders are back on:
Christian
Old 09-07-2013, 01:20 AM
Michael - 69E's Avatar
Very nice project - any updates? Er der chance for at se den til track days med PCD? :-)
Michael
Blut Orange 911 E, 1969
Indisch Rot 911 Carrera 3,0, 1977
Alfa Rosso Alfa Romeo GT Veloce, 1967 (SOLD )
Old 10-22-2013, 11:11 AM
Danish 911S driver
Thanks, Michael!
Yes, the car is at the painter right now. I am very exited to hear/see about the process and of course the final result
Ja, jeg håber at være klar til foråret. Så vil den være et fast indslag!
Christian
Old 10-23-2013, 07:50 AM
Uncertifiable!!!
Uwon's Avatar
Originally Posted by Danish Dynamite View Post
Hey Uwon
Chistian,
I have installed 930 brakes and rotors on a 3.2 Carrera and I don't think that I could have put 15" rims on the front. In my case there less than 10mm between the outside of the caliper and the inside of the 930 16" Fuch rim. Also, I had to put in a 6mm spacer to clear the spokes for the fronts.
If it does not fit, you may have to cut down the diameter of the rotor on the lathe and reposition the caliper holes vis-à-vis the mounting ears on the hub.
Your build keeps inspiring me. My build is co-incidentally also at the paint shop at this moment, albeit its not such an ambitious restoration as yours.
Old 10-24-2013, 06:44 AM
Danish 911S driver
First pictures from the painter! More should come next week
/Christian
Christian
Old 10-31-2013, 09:44 AM
Danish 911S driver
More from the painter...
Christian
Old 11-04-2013, 10:03 PM
