mspirito's Avatar
Vibration in front end at 85 mph
I have a vibration in my steering wheel at 85 that continues on the faster it goes. The wheels and tires have been balanced. It has new rotors and pads, no improvement. Tried another set if tires and wheels same result. It has poly bronze bushings with very stout torsion bars. Anyone have a similar issue care to speculate on a cause. What about the hubs, could they be out of balance ?
Old 11-15-2013, 04:48 AM
Bland
unclebilly's Avatar
get your tires dynamically balanced. you could also have a slight flat spot on your front tires.
Old 11-15-2013, 04:54 AM
You don't mention checking wheel bearings for adjustment or repacking them with high temp grease.
Old 11-15-2013, 05:18 AM
T77911S's Avatar
bent rim?
i had a 280z that had a bent rim(s). i had the tires balanced ON the car. stopped the vibration.
problem is, that is a lost art due to the balance machines. i have searched 2 towns for someone that still does it, no luck.
check ball joints and tierod ends along with play in the steering shaft.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-15-2013, 05:41 AM
al lkosmal's Avatar
+1 I just went through this same issue. i ended up replacing the front wheel bearings and all is good.
al
RGruppe #669
http://www.x-faktory.com/
Old 11-15-2013, 06:56 AM
mspirito's Avatar
Wheel bearings replaced no improvement , tried another set of tires and wheels no improvement
Old 11-15-2013, 08:28 AM
I would still double check the play in them. When I replaced mine, the tightening screw worked loose on the nut that holds everything down, so it worked loose enough that I could feel the increase in play.
Old 11-15-2013, 12:36 PM
