I installed the MSD a while ago and finally got around to locking out the mechanical bottom half of my distributor to experiment.
Note: I previously locked out the vacuum plate see thread at: DIY -- Distributor Vacuum Pod Delete and Vacuum Lockout Picture below shows the installed MSD with serial cable attached, I used an USB adaptor and hooked it up to a laptop running Windows 8.1. It would be really nice if this thing was wifi or Bluetooth. ![]() This shows the distributor fully advanced, I decided to lock it fully advanced but I don't know for sure if it is necessary, but it seems that it is recommended. I did lock the stator at mid point, I'll check rotor phasing later. I don't think it's an issue. ![]() I created a locking plate from a thick piece of aluminum. I traced a card board template first. ![]() The plate looks a bit rough, but it does the job. It is wedged in there pretty good, no wiggle room. ![]() I put the assembled distributor back in the exact setting I had removed it with the adjustment nut centered in the hole, the rotor was pointing about 12 degrees advanced past the timing mark on the edge of the distributor. Set my RPM limit. ![]() Programmed a basic curve. ![]() Car started right up, I adjusted the timing so that it is 6 degrees advance at the crank at 1000 RPM. The MSD pulls out 24 degrees at 0 - 800 rpms. As the rpms increase it reduces the degrees it pulls out so at 3000 rpms it is pulling 0 degrees out, and at the crank the timing is advanced to 30 degrees (24+6). ![]() Ok I am happy, the software was easy to use and I could manipulate the curve with the engine running. It's really nice to be able to see how the engine responds to different changes to the curve. Now, who can tell me what type of a curve I should program? Is the stock curve optimal? Should I add timing at idle to smooth it out? Here is a link to the software instructions if you want to read about it; http://www.msdignition.com/instructions/graphviewdemo.pdf
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 02-04-2014 at 12:36 PM.. |
weekend wOrrier
This is cool! Looking forward to hearing about what advance profiles people suggest.
Ron |
Thanks Ron, I'm studying this thread for information;
Best advance curve? It seems that I should be able to use an initial setting of 10 degrees advanced through about 800 rpms, This will allow easier starting and a smoother idle. I think it will burn cleaner as well. Then I will drop the advance to 8 degrees through 12900 Steady advance to 20 total at 2500 and then a little steeper to 32 degrees at 3500. I think that is about as good as it's gonna get.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 02-04-2014 at 12:31 PM.. |
ROW '78 911 Targa
Careful!
There appears to be a green reptile invading your engine compartment.... ![]() Cool stuff, very interesting.
...and my blue mistress
Hey Shane, I forgot to ask you if you needed a tach adapter with this box? I'm about to sell of my Street-fire and my current dizzy to fund this and wanted to knock it all out at once. Fortunately, I have a 2nd diz that I had dissembled and borrowed a few things from for the one in the car but all of that was stuff no longer needed if I'm going to lock it out. Every now and then the stars align I suppose.
Yours looks like the 6530 in the pic so can you just confirm that for me so I don't buy the wrong one? I didn't see anything on Summit that made me think otherwise but just wanted to be sure. Thanks Buddy!
Robbie 1976 Carrera3.0 1978 928 5spd |
No tach adaptor needed, yes it is the 6530.
Pay close attention to the tiny pin that holds the starfish thingy on the distributor, it is very easy to loose. I am researching the method to check for phasing issues now. It looks like I just drill!a hole in the distributor cap, paint a center line on the rotor tip, and use the timing light to check the where it is sending spark, if it rotates out of a certain arc then I may have to readjust the lockout of the vacuum plate.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 02-05-2014 at 07:48 PM.. |
Yep, I can't figure out if he's British or Aussie, I wish the little bastard would speak English.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Is the rotor alignment OK? I think you sort of locked things down in a middle advance position.
Have you thought of going to a crank fired sensor? Seems to me that would be the way to go so you don't have to worry rotor alignment problems. I have just installed a Daytona-Sensors CD1 in my 1973 and love it, but I using the mechanical advance because rotor phasing really bothers me. the CD1 can be programmed even for retard under boost with the MAP sensor hooked up. Doe the MSD log data? Can you study the RPM, Advance, MAP with charts? Just cuirous.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Checking Rotor Phasing
The rotor fires at the trail edge of the stud at idle. As the RPMs increase the rotor fire moves from the trailing edge, to a little right of center at full advance.
I think it is by dumb luck that it works like this, as WOT is the best place to fire the rotor center mass. I am going to attempt a video, for now I can share a few pics of the test equipment; ![]()
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 02-08-2014 at 05:05 PM.. |
Sorry for the production quality. The angle of the camera exaggerates the alignment. And the hole is a little off center to the right.
The distributor rotates CCW.
Revised Curve
Here is the timing curve I ended up with. Idle is smoother. No notable change in transition. I don't think Ill be able to get any closer until I get this on a dyno.
I do not believe the MSD logs data.
Hey Shane, I'm curious what you are seeing with this setup in terms rpm settling? Not sure I'm wording this right but what I mean is now that the magnets in the diz no longer have to flop back when off the throttle does it appear you are getting a more accurate or more responsive tach response? I was playing with the STE on the PMOs yesterday waiting in between adjustments for things to smooth out and got to thinking about this.
This could be yet another reason to go digi. Not sure how big of a deal it really is but not having to wait for the magnets to do their thing returning to position is certainly a nice thing in some situations.
I haven't noticed anything different with tach response. My tach always seemed to be dead on right, before and now. Your tach response delay is odd, perhaps try another tach.
I had to flip my laptop over!!!
Ha! What's your thoughts on the rotor phasing?
The graph is the measure of degrees that the MSD pulls out. The bottom of the graph starts where I set the static timing, at 6 degrees advanced at the crank. So the 24 spot of the graph equals 8 degrees advanced at the crank. The top of the graph which reads 0 is 32 degrees advanced at the crank. The MSD allows for 25 degrees. I could set the static timing at 10 degrees and get a total of 35 degrees advanced.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 02-09-2014 at 12:32 PM.. |
Bumped static timing to 8 Degrees BTDC. Total 34 degrees. 9.5:1 compression Ratio.
Concerning rotor phasing, I feel it is really critical. I have advance and retard programming in my CDI, I am using a Daytona- Sensors CD-1.
I would not use the timing programming in the CD-1 unless I had a crankfire setup for determining where the the crank is positioned.
Where you able to see the video above that shows the rotor phasing with my system? I think that it shows that rotor phasing is not an issue.
The Daytona system is an excellent set up, but a lot higher priced than the MSD.
Thread Tools | |
Rate This Thread | |
