Need control pressure spec for 77 3.0 carrera row and proper WUR number
I have a 77 euro 3.0 carrera What is the correct WUR # and what are the proper warm and cold control pressures? Thanks much.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
WUR 0438.140.017
Cold 1.2 bar warm 3.1 bar
1974 911 cab. RoW 3.2 with carrera3 CIS, Bosch HKZ ignition, SSI, 915- 7:31, curb weight 1115Kg, 231Hp. BMW 530dA touring |
the wur that's installed is a 140 033
Wur-033......
Thanks Tony. I have a problem with the warm pressure it's 3.8 bar. Spec calls for 2.7-3.0 bar. Cold seems normal @ .5 bar. System pressure @ 5.0 bar.
Wur-033......
The cold control fuel pressure is too low!!!!! And that's not NORMAL. Your WCP is still within specification but on the high side. You are mis-reading the WCP spec values: (2.7 - 3.1 bar)........no vacuum (3.4 - 3.8 bar)........with vacuum Keep us posted. Tony |
What is the cold pressure spec? this is a euro 3.0 car.
do you have the spec book? per mine control pressure(wur off) at idle, throttle closed 3.6+/-.15bar engine stopped, fuel pump running 2.9+/.15 system pressure 4.5-5.2bar you can make it adjustable easily enough, I have instructions if you need them I used to just tap mine to where I wanted it. You had to disassemble it if you went too far though(a potential PIA)
thanks Bill what's the cold spec? Don't have a book for euro spec.
http://forums.pelicanparts.com/uploads15/EarlyWURs1248319527.jpg
does this graph for the 033 wur indicate .5 bar@10c and 2.7bar warm?
Fleabit peanut monkey
Warm pressure is a range, period. Not on a graph.
1981 911SC Targa |
Thanks Bob
I can pull several threads where I assumed that the CCP graph was for both. It's confusing at first blush but makes sense when you think about it.
1981 911SC Targa |
Different reference graphs.........
Mike, There is a discrepancies in our reference graphs. I am using the factory shop manual from Porsche which shows a completely different slope for WUR-033 from yours. I've been using the graphs from my factory shop manual for almost 20 years and never had problem with the setting. So I'm sticking to my reference charts and let you decide which to use. Good luck. BTW, 0.5 bar cold control pressure setting is too low based from actual tests and my experience working with all sort of Bosch WUR's 0-438-140-xxx. But if you are happy with this setting and it works for you, just keep it that way. Tony Last edited by boyt911sc; 02-10-2014 at 03:23 PM.. |
Cold control fuel pressures.........
Thanks Tony and Bob. I'll try the high end of the ccp @ 10c.
Hello,
Has this ever been solved? I mean the discrepancies in our reference graphs for the WUR-033. In the workshop manual of Porsche it shows a different graph compared to the graph in the Types, Dimensions, Tolerances softback book (always from Porsche) or compared to the graph in some Bosch workshop manuals? My WUR-033 is set to the TDT (or Bosch documentation) and I'm wondering if I should rebuild it to the graph in the workshop manual? Thanks, Peter |
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
