Counterclockwise?
Power windows not working
After running a while my power windows are struggling to work.
My understanding is there is a relay that is heating up and dying.
Problem is I can't find it!
Can anyone help?
Rod
1986 Carrera
2001 996TT
Old 04-09-2014, 06:34 AM
The relay is behind the fuel gauge...pull the gauge and I believe it is the middle relay. You should first try to remove the relay, clean the spades with Emory cloth and slightly bend the spades to ensure you are getting good contact. I had an issue once..bad relay the first time but when it happened again, the clean/bend trick worked.
1986 3.2 Carrera
Old 04-09-2014, 07:03 AM
http://forums.pelicanparts.com/uploads20/0052+Power+window+Relay+Location1334430998.jpg
My bad..it's the relay on the far left side when you remove the gauge.
1986 3.2 Carrera
Old 04-09-2014, 07:10 AM
Recreational User
porschenut's Avatar
You should be able to easily reach the bank of relays from the trunk. I've done it a thousand times. Removal of the gauge isn't necessary.
Old 04-09-2014, 08:27 AM
Counterclockwise?
Thanks guys. You have no idea how bad this has been bugging me.
Worse is when I get to the track and can't open my window!
Rod
1986 Carrera
2001 996TT
Old 04-09-2014, 08:31 AM
Could also be a bad window felt or a motor going bad
1975 Carrera #116 3.6 guards red sold
1980 911sc Talbot Yellow got back!! 1978 911sc 3.6 Sold
1996 993 tt white Sold. 1997 993tt red Sold 1986 930 sold
1986 491 Prussian blue sold 2002 tt white sold
1996 993tt adventurine/gray 1987 carrera with a 3.8
Old 04-09-2014, 05:22 PM
OsoMoore's Avatar
A couple times I've lubricated my felt window tracks with graphite spray. It helped a lot.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 04-10-2014, 07:38 AM
scarceller's Avatar
This could help as well:
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 04-10-2014, 07:46 AM
Counterclockwise?
I understand all of the other things that can go wrong and I have gone there.
Windows work fine, until I drive the car for a while.
And both windows act the same.
Rod
1986 Carrera
2001 996TT
Old 04-10-2014, 08:50 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relays.
GOOD LUCK,
GERRY
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-10-2014, 09:59 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Have you checked the fuse, it may appear fine but check to see if it is loose, heat will shrink it. When you are stationary, you may have just enough contact at the fuse to have a closed circuit but when you are moving, it may move enough to give you a semi-short. This is what happened to me, while I was using my AC at HIGH and Window at the same time. Replaced#1 fuse block per Dr. Gerry's advice and it solved it for me.
'85 Carrera Targa
PCA/POC
Old 04-10-2014, 10:42 AM
dshepp806's Avatar
Could certainly be electrical,..need clean copper continuity from source to destination!! Those are easily addressed...keep us posted.
Otherwise, you've a mechanical issue.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-10-2014, 02:33 PM
