LinkBack | Thread Tools | Rate Thread |
Is it possible to upgrade a 1985 to the 1986 to 1989 dash pad relatively easily?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Not sure, I have never done it. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick |
930T Owner
The dash pad itself should bolt down no problem if you use an '86 dash pad. However, The two unknowns from me would be the defroster vent and the center A/C vent. The defroster vent on the 86 and up is anchored by screws that are secured by raised supports on the dash frame. the A/C vent is specific to the 86' up through 964 cars. You'd have to get the A/C vent but not sure if you would be able to connect it to the blower duct behind. The difference in shape makes me think that would be problematic.
One way to know would be to compare pictures of the metal dash with the pad removed on an '85. If I could see that I could give you a better indication. Chris.
Hams930T 2017 Turbo S |
^^ What he said.
The dash will fit but you'll have to find a way to anchor the windshield defroster vent as it's held in by 5 or 6 screws. But the rest of the dash should stay put with out the vent.
1983 Porsche 944 (Sold), 1986 Porsche 944 N/A (parts car), 1987 Porsche 944 Turbo (Sold), Mercedes ML55, 2011 BMW 328i X-Drive, 1987 Porsche 944 and a 1987 Porsche 911 Carrera |
You can use the search function to look at the threads from others who have done it.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Here's a thread on "84 dash replaced by a 964 dash. I think the 964 dash is the same as
''86-'89. Good luck! my dash swap (964 dash in 84 carrera)
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Private Message sent.
Cheers
Uncertifiable!!!
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
