Retired, finally
LOL
![]() I'm sure that's what my GF thinks as well, especially since I'm spending $10 on a transmission rebuild and upgrade on Bwunhilde, my 1984 Carrera track car. That's in addition to the 914 that's having it's rust issues taken care of, and the Supra Chump Car that I'm building in the back yard. GF would rather I spent the money on my house, which is need of some repairs. Good luck. I hope you get her (what ever your car's name is) fixed soon. Then drive the hell out of her.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Straight shooter
Get some tools, start tearing. Valve covers come off in just a few minutes and those will tell the story best between minor or major.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
OP, you have a good attitude. That's 90% of the battle.
Jeff Jensen 1973 911 |
You can also pick up a used engine, and drop it in.
Then you can drive the car while you are taking time to sort yours the right way. Once you are done rebuilding the original, sell the replacement for about what you paid for it.
07 Boxster 88 Carrera Cabriolet 3.2 (sold) 05 Boxster S (sold) |
Platinum Member
OP - Lots of mixed advice here. Could be many things. You may start by reading this:Pelican Technical Article: Time to Rebuild? - Part I
From the description, this could be a minor problem, and I seriously doubt a connecting rod/cap. I would pull all the plugs, and turn the engine over by hand, make sure it turns smoothly. Then do a leakdown test. If thats ok, pull the valve covers, check the rockers, and the tensioners. |
Metal in the oil?
If there is metal in the oil, the engine must come apart, even if it is just a rocker bushing that got eaten up. You have to get all the flakes out of the engine. The up side here is that after inspection, you can probably clean and re-assemble the motor with very few new parts, to keep the cost down.
Bob B |
It's a good looking car.
My $0.02 (for what it's worth), jack it up, pull the valve covers, drain and inspect the oil that comes out of the case and the tank, and then turn the engine over with a wrench on the crankshaft pulley bolt. It should be pretty self evident if some thing is seriously wrong. The bottom ends on the 3.2's are pretty stout but have the skinnier rod bolts. Unless it's been over-rev-ed, it's hard for me to believe a rod cap came off. However, anything significant in the oil requires flushing the whole system at a minimum and serious investigation. Hoping for the best, Tinker |
A&F,
Any update on your trajectory? Rob |
Location........
Where is the car located? There may be some Pelicans nearby that would jump in to help with the engine work. Wouldn't be the first time!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Chain fence eating turbo
Don't devalue this car, it is the best and last 911. |
Metal Guru
I literally screamed when I saw the rod hanging out of the case.
Here is your opportunity to build up a new, kick-ass engine. Best of luck to you.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Oh boy..sorry to see and deepest regrets...did MM rebuild the engine?
Holy wow! See if you can find a short block, or a whole engine.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 12-15-2014 at 06:38 AM.. |
Yeah, I'm going to disassemble and inspect it. What portion of the crank I can see in my new "inspection" window looks good. Anyone have the run down for what are the going rates for 3.2 cores, runners and cases? Can I use a 3.0 case? (930 is the same case as a 3.0, right?) |
Oh my.....that is just sad. I can't believe that rod punched a hole in the case. Look at the positive side of this, you have a beautiful looking coupe. Now you can build a fresh 3.2 or even a 3.6 and install it and know you have a tight, fresh motor. On the other hand you can look for a used, running 3.2 and just bolt it in and drive it. If it were me, I would build a fresh motor salvaging what parts you can from your engine and then enjoy the car.
'71 914-6 #0372 '17 Macan GTS |
Retired, finally
Oh, $$$$$!!!!
My 1984 Targa was destroyed in a front end wreck last month, but the motor and newly rebuilt transmission are still good. Either you buy my engine or I'll buy your Coupe.
Houston.....we have a problem.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
well that answers youre question. Any recourse with the engine builder or are they already out of buisness?
82 SC , 72 914 |
