A/F meter in dash clock position
Have any of you installed a 2 1/16" diameter A/F meter in the clock space? If so, what did you use to adapt the smaller gauge to the dash space?
Bob G
‘87 Carrera Targa
‘74 914/4, much modified
Old 06-06-2014, 03:12 PM
Chain fence eating turbo
The clock lens. I whittled a hole in a busted clock, painted lens black, and mounted WBO2 to it.
Old 06-06-2014, 03:14 PM
Uncertifiable!!!
Uwon's Avatar
Look at this as a start.
PLX Wideband
It will wet your appetite.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 06-06-2014, 06:59 PM
Bob G
‘87 Carrera Targa
Old 06-06-2014, 07:08 PM
Our host sells a plastic plug for the gauge (delete plug). I got one and hole sawed approximate diameter. Looks pretty good.
Old 06-06-2014, 07:21 PM
I have used the plastic clock plug that Pelican sells. It is a very nice machined piece.
I just finished the install using the Daytona-Sensors WEGO IV unit. This one is all self contained and you can download data from the front panel USB connector.
I have also built in a digital readout above it that is a clock, volt meter, and temperature gauge. I will post photos tomorrow.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-06-2014, 10:03 PM
If I'd known Pelican had the plug, I wouldn't have mutilated a clock.
Old 06-06-2014, 10:56 PM
Tippy, if you saw the price of the plug your mangled clock solution might look more attractive.
Old 06-07-2014, 05:49 AM
Certified User
billjam's Avatar
I used a PVC pipe cap. It was a while ago, but it must have been a 75mm pipe cap with an OD of 80mm because it fitted in just right. Drilled and filed a hole for the gauge and glued some vinyl on.
$0.50
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 06-07-2014, 06:37 AM
$0.50
I like your style, Bill. Mine is for a 911 style (Getty) dash in a 914 and this fits the 'bill' nicely.
Thanks all.
Bob G
‘87 Carrera Targa
Old 06-07-2014, 08:24 AM
Here is my setup with a Daytona-Sensors WEGO IV [sold by our hosts PP] The plug is also sold by our hosts.
You can download data from the mini USB port on the front and the unit is completely self-contained with no additional boxes.....just a wire to the wideband sensor.
The upper digital readout is a combination digital clock, voltmeter, temperature gauge. You can toggle through with the right spring loaded toggle switch, or you can set it for 5 seconds on each function.
This way you keep your clock, get AFR and voltage and temp.
The left toggle is for switching from oil cooler temp to outside air temp.
03 Boxster
Old 06-07-2014, 10:46 AM
I gutted an old gauge and used some PVC pipe to make a mount inside. [/LIST]
Old 06-07-2014, 11:04 PM
rsscotty's Avatar
Here are pictures of the speedo & clock delete plug....
Welcome to Rothsport Racing - Chassis Products
Old 06-08-2014, 12:37 AM
THAT IS WHAT I started with. Well made machined plastic
03 Boxster
Old 06-08-2014, 06:32 AM
Grappler
Rodsrsr's Avatar
Why are all the gauges so small? Doesn't anyone just make a larger air/fuel gauge?
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 06-08-2014, 07:51 AM
my setup is very easy to read. Large digital numbers. Good night of day
03 Boxster
Old 06-08-2014, 01:36 PM
Navin Johnson
TimT's Avatar
The extreme
TechEdge
There other displays are bit larger than a 2-1/16 round gauge
'69 911 GT-5
'75 914 GT-3
and others
Old 06-08-2014, 05:45 PM
