Heck, I’m only 5 not 71!
targa80's Avatar
Another Front Condensor Fan Bites the Dust
I have been testing the AC system for leaks before I reinstall the system in the car.
The system holds a solid vacuum and I have ordered a new Dryer to install once the system is back in the car. The next step was to check the two fans (Evaporator and front Condenser) . The Evaporator fan needed a little lube on the two bearings since it was hard to turn initially. The Front condenser fan was frozen and when I took it apart this is what I found.
The brush mountings melted to the commutator
You can see one of the Brushes in the picture.
Looking at the AC circuit, it is protected with a 20 amp fuse in slot 20 and I don't remember it being blown. As an added precaution, I will be installing an in-line fuse with a lower amperage rating for the new motor.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 07-15-2014, 09:30 PM
Rodek
Sorry to hear about the motor biting the dust and I hope your new motor gives you years of trouble free A\C. BTW, nice tip on the fuse. I think I'll do the same once I get that hose taken care of.
Old 07-15-2014, 10:24 PM
1988 Carrera
shadowjack1's Avatar
As I recall that new inline fuse should 7.5 amp.
Old 07-16-2014, 04:45 AM
That fan is the cause of a LOT of 911 fires. There is a Porsche part number for a inline fuse that is part of a recall.
Old 07-16-2014, 05:59 AM
Dueller's Avatar
I think I have two of those motors if you need one. One is NIB if I recall. Let me know.
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 07-16-2014, 07:19 AM
Brew Master
cabmandone's Avatar
Wow! 20 amp? Is that what is called for in that circuit? It seems like the suggestion of a lower amperage fuse inline is a very good idea.
Old 07-16-2014, 07:35 AM
Barrpete's Avatar
+1, 7.5 amp is correct.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 07-16-2014, 08:17 AM
MConn's Avatar
If you don't want to cut your harness, the Porsche part number for the inline fuse is 911612077 - kind of pricey
I think I had to use a 10 amp because of starting current, but I'm using a footwell blower motor.
Mike
The more I learn, the less I know.
Old 07-16-2014, 09:56 AM
ganun's Avatar
BTW, a cool idea to lay it all out like you did and pull a vacuum. Now all you need is to hook the comp to a 5 hp elec motor and put the evap in its box ........
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 07-16-2014, 10:35 AM
ganun's Avatar
I forgot to mention that the evap blower should be replaced if it was hanging up, even if you freed it up and it rotated better it still won`t run at the revs as a new one.
Old 07-16-2014, 10:38 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse kit.
HOPE THIS HELPS.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-16-2014, 10:41 AM
Rodek
Alright, since I'm still learning my 911 and it's A/C system, I have to ask. Where is this inline fuse supposed to be located? The smuggler's box or the in-trunk fuse holder or....somewhere else???
Old 07-16-2014, 11:41 AM
targa80's Avatar
Originally Posted by Rodek View Post
Alright, since I'm still learning my 911 and it's A/C system, I have to ask. Where is this in-line fuse supposed to be located? The smuggler's box or the in-trunk fuse holder or....somewhere else???
rodek,
if i remember correctly you said you did not have the front condenser with the fan. the fan on the evaporator in the smugglers box is protected from the elements of outside air on the other hand the front fan draws air directly from the environment and is drastically effected over time. i would not go with a separate fuse in-line for the evaporator fan but that's just my thought process, others may disagree. you are lucky to have an uncle with the vacuum pump and i bet he has the gages too. if not i bought the gages anf the 2.5cfm vacuum pump from my local harbor freight. yes, they are made in china and they are cheap but for a diy shady tree mechanic they fit the bill for my limited use. did i mention that they are really cheap.
Pat Henry
Targa80
Old 07-16-2014, 12:46 PM
targa80's Avatar
looking at the schematic for the a/c circuit fuse 20 is rated at 25 amps, understand this provides power to all of the electrical elements of the a/c system.
Pat Henry
Targa80
Old 07-16-2014, 12:50 PM
targa80's Avatar
jim,
thanks for the offer but i have one on the way from our host.
Pat Henry
Targa80
Old 07-16-2014, 12:52 PM
Rodek
Originally Posted by targa80 View Post
rodek,
Thanks for clarifying! I don't have a front condenser so I guess the inline fuse doesn't apply. Yes, I'm glad my uncle has the vacuum and you're probably right about him having the gages. I may go ahead and pick my own set up at harbor freight just to have them around for my other vehicles too. It's not a bad idea to pick up that vacuum I suppose as well.
Old 07-16-2014, 01:16 PM
This fuse holder located on the fan harness
was added on the M/Y 88-89 on a Porsche service bulletin.
Fusing for the 3.2 cars was not Porsche's finest hour.
Check my threads/posts for added fuses and relays.
Or, pm me.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-17-2014, 09:29 AM
Vintage Owner
Jack Stands's Avatar
Those brushes looked a lot like mine when it stopped working. A new motor ( I think sourced from eBay), and an inline fuse and I'm good to go.
There are threads on replacing the condenser fan, just be careful removing the blower fan off the motor shaft.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 07-17-2014, 08:43 PM
Discseven's Avatar
I had same melt down with mine.
A follow up on Jacks note about removing blower... the allen screw securing blower to shaft on mine was sealed with some sort of hard wax. I'm not drilling it out in the photo below... I'm just poking the stuff with a drill bit... and it came out. The blower took some time getting off the shaft.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-18-2014, 08:02 AM
Vintage Owner
Once you loosen the Allen head sets crew, getting the squirrel cage blower off the shaft can be a chore. As the motor is toast anyway, I found it easiest to chuck the motor housing in a vice and tighten down until the housing is distorted enough to crush the armature against the outer housing, preventing it from turning. Then by simply rotating the outer edge of the fan blades, I was able to turn the entire shaft so as to get it to break away from the commutator and electrical windings, then simply remove the shaft with the fan attached. Then, it was simple to rest the hub of the fan supported on a vice and simply tap the shaft out of the hub with a drift.
When you install the new motor and fan assembly, check the positioning of the fan in the blower housing so it doesn't hit or rub against the plastic.
84 Targa (sold)
70 914-6 (sold)
2016 Cayenne
Old 07-18-2014, 11:09 AM
