LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
ROW '78 911 Targa
timmy2's Avatar
Replace the Injector seals, injector sleeves and seals, rubber air box to runner sleeves, Throttle body to air box o-ring, metering plate assembly to air box gasket. Cold start injector gasket.
When apart test your air box for cracks using the pressurized air submersion method (seal all holes to vacuum area and apply a little air pressure while submerging)
There are posts and pictures of Tony (boyt911sc) demonstrating how in some threads.
Read this thread too:
CIS Troubleshooting for Dummies
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-19-2014, 10:24 AM
GT2BH's Avatar
First batch of items is here
and took my car to service and saw another beauty
'09 997 GT2
'86 911 3.2
'83 911 SC (work-in-progress)
Old 09-21-2014, 07:23 AM
911 engine porn !!!!
Old 09-22-2014, 05:33 AM
ROW '78 911 Targa
timmy2's Avatar
Nice...
Dennis
Old 09-22-2014, 07:25 AM
GT2BH's Avatar
Things are trickling in. Main shipment from Pelican is outstanding and just got an email it will be delayed. Second time this happens - the shipping time on the website is wrong. Last time it said shipping in 9 days and its been over a month
Rennline stuff - RSR Engine Carrier and Fan Housing Strap
'09 997 GT2
'86 911 3.2
Old 09-24-2014, 08:11 AM
GT2BH's Avatar
I found a local shop that does ultrasonic and chemical cleaning. I am thinking about chemical cleaning for the oil tank, however I am not sure if I should do US cleaning on the cam housing, engine case, oil cooler, etc. What is the general consensus?
'09 997 GT2
'86 911 3.2
Old 10-02-2014, 07:48 AM
GT2BH's Avatar
More engine porn - my custom harness by timmy2
'09 997 GT2
'86 911 3.2
Old 10-03-2014, 09:45 PM
GT2BH's Avatar
Got stuff!
Gotta say, excellent service from Dougherty, quick and efficient.
Turns out my heads need major work so cgarr (Craig) is taking care of that, and my rods are getting the royal treatment from Steve@Rennsport.
Once those arrive, I'll be able to start assembly!
'09 997 GT2
'86 911 3.2
Old 10-08-2014, 08:20 AM
Enthusiast
jrolstin's Avatar
Wow this is epic. Nice build! Sub'd
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 10-08-2014, 10:02 AM
Registered Loser
Craig does great work, pay the extra cash and have him R&R all exhaust studs on the heads!
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 10-08-2014, 12:06 PM
gtc gtc is offline
abides.
gtc's Avatar
Yes.
I had my case, cam towers, and chain housings ultrasonically cleaned after spending way too many hours trying to clean them by hand. I should have done that from the start.
I still need to take my oil cooler in.
Graham
1984 Carrera Targa
Old 10-08-2014, 12:48 PM
GT2BH's Avatar
I'd prefer to replace the exhaust studs since one broke while I was removing the heat exchangers
Originally Posted by gtc View Post
Yes.
I dropped my cam towers, chain housing, oil cooler and oil tank yesterday. Once they're done I'll drop the case. Looking forward to how it turns out.
I got some bad news yesterday from one of my instagram followers who said his Bursch headers rusted very quickly and that I should coat them or use heat wrapping. Looks like I'll start sanding them to remove the paint and then paint them with high heat spray paint.
'09 997 GT2
'86 911 3.2
Old 10-08-2014, 10:59 PM
GT2BH's Avatar
Got the first batch of stuff back from ultrasonic cleaning
'09 997 GT2
'86 911 3.2
Old 10-09-2014, 05:31 AM
Registered Loser
Find any dipsticks in that oil tank?
Old 10-09-2014, 05:59 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Craig will look at them when he's working on the heads and give you his thoughts on their condition. I agree with whiz that now is the best time to do them & Craig has all the tooling and experience to get them out cleanly and quickly, even if some break in the process of replacement. If you've never dealt with replacing a broken stud before, especially one that has broken off flush with the head surface, you may want to have Craig do them & save you some troubles.
Kevin L
'86 Carrera "Larry"
Old 10-09-2014, 09:24 AM
GT2BH's Avatar
Yes sir, I'll email Craig and see. My new set arrived, but I can probably sell them here
'09 997 GT2
'86 911 3.2
Old 10-09-2014, 10:09 AM
GT2BH's Avatar
Just the one I dropped a month ago
'09 997 GT2
'86 911 3.2
Old 10-09-2014, 10:13 AM
GT2BH's Avatar
Got a question. When removing different parts from the crankcase, a few studs came off (pics below). What is the general consensus on reuse? I ordered new studs that mate the engine case with the transmission since one was bent, and ordered a set for where the oil breather cover mates with the engine, but what about these random ones?
Got my crankcase halves cleaned but they still have a layer of whatever liquid they used so I started wiping this half down with Dettol wipes. Will go through it one more time then use rubbing alcohol to finish it off before assembly.
and an update on the final setup:
100mm slip-fit nickies with 9.5:1 JE pistons (essentially 3.3L), 964 cams, Bursch headers, M&K 2-in-1-out exhaust and a bitz EFI kit
'09 997 GT2
'86 911 3.2
Old 10-12-2014, 07:45 AM
GT2BH's Avatar
Anybody? stud reuse?
'09 997 GT2
'86 911 3.2
Old 10-12-2014, 09:21 PM
ROW '78 911 Targa
timmy2's Avatar
I reused any studs that just backed out.
Unless they were damaged.
Dennis
Old 10-12-2014, 09:50 PM
