Schleprock
Yes crank polishing needs to be done professionally.
One set of rod bearings looks like typical wear, although very worn due to hard use and possibly thin oil allowing contact with the crankshaft at high rpms. The speckled rod bearings look like failure of the bearing material itself coming loose from the bearing shells. cgarr can do the rockers if you plan to send him the heads too. He does a nice job refacing the rockers and also installing a low friction bushing in the rocker bore. We have used them in our racecar engines with good results. I don't think you need to do anything special to the parts prior to reinstallation. The rods should be checked for their bore dimensions, especially since the rod bearings look bad. New rod bolts are a must since the old bolts must be discarded- they are a one time use stretch bolt. ARP rod bolts are a good choice since they are not much more expensive than a set of new OEM Porsche rod bolts.
Kevin L '86 Carrera "Larry" |
Can you tell if the bearing shells are the 'original' Porsche or a replacement like Glyco, are there markings on the backs?
That chunk of plastic under the valve is a real mystery - could it be a piece of the CIS airbox that fell into one of the ports? Peter 78 SC 3.0 |
'09 997 GT2 '86 911 3.2 '83 911 SC (work-in-progress) |
This is the back of the failed bearing.. notice the corner is chipped
Bearing moving inside rod??
I am no expert but it looks like the bearing may have been moving inside the rod.
Was it the locating tab that has been broken off at the corner? Perhaps some more experienced people can give an opinion on this and the origin of the bearing shell. Peter 78 3.0 SC |
![]() Not too worried - getting a new harness from Timmy2
ROW '78 911 Targa
That's a very smart bot!
ROW '78 911 Targa
Not really, they copy someone's post in a thread and repost it. This one happened to be mine from page one.
See it all the time, Pelican is a popular site. Notice it is gone already since I reported it.
Schleprock
Once the bearing wants to move, it's going to spin and then the bearing gets completely smeared. Those bearings haven't spun, but they sure do look crappy. Somebody may have scuffed the back side of the bearing to remove the plating and give the bearing some bite in the rod? If you can't feel any ridges in the crank with your fingernail, you're probably OK. Just clean it up with solvent and then treat it with rust protectant or motor oil. DO NOT leave the crank dry or it will rust very quickly.
That was the only bearing which was completely gone - I am told it might be an oiling issue. I'll be packing everything up this week and shipping it out for machining and will order all the other necessities as well. Now the waiting begins (and the money is spent).
Can anyone confirm whether these are the original or upgraded chain tensioners?
Schleprock
Those are the later style oil pressure-dampened "Carrera" chain tensioners.
Thanks! So all I need to do is replace the cam oil lines and I'm good. I am stressing out about my shopping cart, don't want to miss anything
Schleprock
Are any of the oil lines leaking? If not leaking, it's OK to re-use them. The pieces associated with the oil lines that are good practice to replace are the aluminum sealing rings and the o-ring on the tensioner "snout" where it is fed the oil.
The o-ring is just for splash sealing the tensioner snout to the chain housing cover. The seal rings are most important. However they can be re-used in a pinch. Only when the seal rings are really smashed (from over-tightening) and grooved are they risky of leaking.
Update:
I've packed up the stuff and the heads/rockers are going to Craig (cgarr), rods are going to Rennsport and cams are going to Dougherty. Rods will get checked and ARP bolts installed, and the cams will be ground into 964 specs. I've placed an order for the 100mm cylinder with 9.5:1 JE pistons from LNEngineering and they've shipped. Craig will take care of the heads to match. Big order pending from Pelican, hoping it'll be placed by Friday. The tools I've ordered a few weeks ago from Pelican are incomplete and they are ignoring my request to ship partial shipment and leave the last tool until it arrives. I'm annoyed.
If you have the rods done, rebushed and big end trued, the machine shop will need the old rod nuts/bolts. They are not useless yet. Great progress!
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
thanks for the input
I started looking at the CIS today, changed a few vacuum hoses and cleaned the plastic bits. What are the main areas I should be tending to while the engine is out? The only issue I had before taking the engine out was that after my MSD installation my idle was at at about 1.5k RPM.
