Ssi in 3.2 parts questions
1. Is this the second oil line i need? I have the front wheel well mounted oil cooler.
Pelican Parts - Product Information: 911-107-729-10-M127 yes. 2. What gaskets are used between the ssi secondaries and the muffler? here it is: 901-111-193-00-M17 3. I want new exhaust studs, but p part studs listed say not for thick flange manifolds. What do folks use as i gather ssi's for the 3.2 are thick flange. I assume 46mm. Exhaust stud for SSI's w/ Thick Flange appears to be 999-062-237-02-M260 - 51mm this appears to be the lock nut: 900-910-097-02-OEM 4. Heat backdate. I ordered the left and right ducts, but both are identical. Each had proper parts label however. Label/shipping error, or are they just similar? Update: 100% an error from pparts looking at the pictures. Thaks folks, uless other have better parts alternatives, I think I found/was told all the info I need. Last edited by gliding_serpent; 11-13-2014 at 06:41 PM.. |
I will answer 1 above. Yes.
83 911 Production Cab #10
I will answer 4 below. Yes as in Label/shipping error.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 11-13-2014 at 04:11 PM.. |
Your current Part #5 may be okay. ![]() Downloadable parts manuals are available here via this portal. HOME - Dr. Ing. h.c. F. Porsche AG To ID part numbers, look for a page that looks like this: ![]() Sherwood |
thanks for the info.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 11-13-2014 at 05:41 PM.. |
Sherwood |
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
I'll post some pics, when I find them. I guess you already found them...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
abides.
Trying to replace the exhaust studs would just be opening a can of worms... I wouldn't do it if I were you.
Graham 1984 Carrera Targa |
No regret but here is the link so you can decide for your self and a few others that maybe of some help. Time-Serts to the rescue Help: SSI / Engine Tin Installation Problem Exhaust Stud Fitting Cleaning Flapper Boxes
Vintage Owner
Boy, those certainly are beautiful! I had a set on my old '75 Targa and loved them. They put out a ton of heat as well (I think they worked better than the setup on my '84 without all the blowers and relays).
It appears that the SSI heat exchangers you show have the thick flanges, so won't they fit on the original exhaust studs without changing anything? Also, does the passenger side air elbow fit if the factory AC bracket is in place? I don't think it would as that space seems quite tight, but have no personal experience in trying the backdating.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
My ac is removed, so i should be fine.
I am searching on the exhaust stud thing, but it appears you guys are all right... No need to replace unless one is broken. May get the special tool to remove the nuts. |
Now i am reading on the elephant racing alternate oil line options... The over the transmission line sounds tempting for servicing. Plus, my car is low.
abides.
Harbor Freight has a cheap set of long allen bits that works well.
Bye, Bye.
Elvis has left the building. |
abides.
Yeah, I learned from the experience of breaking a stud on scooter's car :/
