Dropping a 3.2, to do list?
Hi guys. My 84 is having it's 3.2 dropped this winter. Thoughts on things to do while it is out? Here is my plan so far:
- extensive detailing (including intake plenums, fan shroud, fan). - SSI and M&K 2:1 install - new fuel lines (trying to get in touch with Len for these) - cut airbox to cup style (PO drilled) - Heat backdate - new cam oil lines - valve adjustmet - Reroute spark plug wires over fan (not S style) - clean engine bay - repaint engine surround tin - new sound pad - extensive reseal Any other thoughts? Would like to do new vacuum lines (is there a good source of all the ones I would need?)
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 12-24-2014 at 02:12 PM.. |
Project Addicted
Do vacuum lines and have the injectors cleaned.
Reseal triangle of death. Adjust valves
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
French Import
Inspect clutch and replace parts as needed.
Inspect and resurface or replace flywheel as needed. Inspect clutch release fork for cracks and replace if needed Upgrade the CHT sensor if the original is still there Replace soft rear brake lines. Inspect starter and alternator. Replace intake manifold gaskets and torque bolts. Air leaks there will lean out the air/fuel mixture and may cause damage to the engine and will fail smog in CA. Easy and inexpensive fix/maintenance!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Another item to consider is to re-anodize all the fasteners and other small metal pieces so they have that new gold finish. Sometimes, the Worth clamps used in various places on the engine can be re-plated (anodized) as well
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) Last edited by Jim Smolka; 12-24-2014 at 06:05 PM.. |
Also, inspect the engine bay rubber seals that seals the engine sheet metal to the body of the car. Replace as needed. If done like it was at the factory, the new seal has a top part and bottom part. The top part goes onto top of the sheet metal. The bottom part goes on the underneath the engine bay sheet metal.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Thanks for all the info so far!
The oil pressure switch on the back of the motor
FYI, in the tech article section, there is information regarding the replacement of the clutch assembly.
crank shaft seals front and rear,
plugs, rotors, caps, rear suspension arm bushings, AND obligatorily a pic of you in the engine compartment with a beer
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Just had my 3.2 out. In addition to your list (BTW - it's a good list), may want to check clutch/flywheel, clean injectors, replace o-ring seals on engine oil cooler and check the engine support/mounting bracket for cracks on the ends.
Have fun. ![]() BER |
I replaced the speed/reference sensors when I had my engine out. The wiring on the originals literally came apart in my hands during their removal. heat, oil leaks, and age make them pretty brittle. Replace them and they should be good for another 30 years.
Registered Loser
Awe. F it. Just do a top end while ur in there!!
At this rate I will just replace the entire car. ;-)
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Banned
GS, I recommend you add one of these to your "to do" list!
only one???
ROW '78 911 Targa
Inspect all engine harness and injector wiring for brittle areas that may have developed cracks and repair or replace.
Clean, clean, clean and clean some more. Just when you think it's clean, clean some more. That job never seems to end. I'm not doing this but I considered splitting the case just to make cleaning that much easier.
Mike '89 CARRERA #402 |
Brew Master
My suggestion would be when you're done with yours, come to Ohio and help me with mine.
+1 X1000
Also, torque your intake manifolds...
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Back to your list, how are you planning on re-routing your spark plug wires. I am trying to get the wires back to their original position on the fan shroud of my '87, but have not found a really good solution.
’87 Venetian Blue Coupe |
