Vortex effect
Hi Guys and ladies,
Just a question if anyone has tried one of those devices that fit within the air box and disrupts the air flow in such a way that is suppose to create a vortex like air movement. I had an an old CAMRY wagon ('87) and fitted one to it. There was a noticeable improvement in power. (and yes it was pretty ordinary to start with so before anyone jumps in a good wash and polish probably made it go faster too ![]() I wondered if anyone had tried it? A quick search through the forum did not find anything but then again I only spent 10 mins...... Geoff |
was youre camry carburated? Id say it depends on the car and how the intake is designed. I dont think fuel injected cars would benefit because the fuel is already well atomized by the injectors and squirting directly at the valve. It doesnt have to travel through the intake
82 SC , 72 914 |
88 Carrera, Guards Red
Snake oil. Don't believe what people say about "felt" improvements. Including yourself. The science is not there. if they worked all the car companies would use them. If you believe in that stuff, I can sell you a system to add water to your fuel to increase gas mileage. Or was it a magnet that you wrap around the fuel line to increase mileage.
Just be sure not to put in an Australian vortex system... it will make things far worse north of the equator.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Chain fence eating turbo
Vortex is just a buzz word. It's the placebo effect that is at work here.
Vendor
Location: 155 Commerce Drive | Fort Washington, PA 19034
Eh, personally I think it's snake oil as well. You will get noticeable increases from a Fabspeed airbox and a BMC filter, that's all the bolt on intake work these cars need IMO.
Hamsa Naser Hamsa@fabspeed.com W: +1 267 742 3006 |
Its not completely snake oil. Like I said depends on the engine. My 1946 willys jeep has one built into the carb gasket and it runs like crap without it.
82 SC , 72 914 |
72 911 Although it is done at the moment, it will never be finished. |
Member 911 Anonymous
Your money will be in a vortex like the electric Turbo kit.
![]() The best boost for HP is losing weight from the car, like the spare if you have road side service, lighter battery, removing rear seats, the bumperretes, car mats, so on.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Oh, you mean like THIS one I found in my used Subaru Outback?
1) K&N Filter stickers are NEVER a good sign in my opinion. B) What's this? It's an Alabama "Turbulatornado"! I guess the instructions failed to tell the installer to make sure and remove the BLUE PLASTIC COATING! 3) Geeeez o Pete.......they didn't even make sure the snorkulus tube fit the MAF sensor assembly correctly. No wonder it ran like cr*p until I rescued it! ![]() ![]() ![]() |
I wound up keeping it below the toolbox for "show and tell".
OMG
Hi Guys,
It was asked earlier and the Camry it did make a difference in was fuel injected. I am as skeptical as the next person but it was noticeable. I had one installed on an 1999 Camry and did not feel any difference. I just wondering if for an older car (say for instance before the 964) would it make a difference. |
