In our discussion we surmised that it probably couldn't turn the engine backward, due to the "one way' clutch on the starter gear teeth. I still cling to that hypothesis, but will remove Bendix from my Porsche starter lexicon. LOL
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
San Diego, CA
ROW '78 911 Targa
Venezia,
You may have melted the insulation on the yellow wire from the ignition switch to a red power lead at the ignition switch or anywhere from the switch to the solenoid. Could be the wiring in the starter is shorted . Pull the yellow wire off the starter solenoid and see if it still wants to turn over. If not, then connect it back up and disconnect the single plug yellow wire connector near a 6 pin plug that goes through the sheet metal near the ignition switch under the dash on the trunk side and try again. If it doesn't try to start with that wire unplugged, the problem is likely in the ignition switch or small wiring lharness to it. |
ROW '78 911 Targa
Any updates? Or is it in a shop now?
I pulled the 14 pin connector and switched on the battery - starter motor engaged but no smoke! Have a flat bed coming tomorrow and will be in the hands of a good 911 wrench by mid day. More to come.
Thanks to all for your feedback and also special thanks to all who have served our country!
1988 911 Targa 1955 MG TF 1500 1974 Triumph TR6 |
If you need a new alternator they don't come any better than this... I have one and it's amazing.
Good luck with it. |
I did this on a BMW Z3 roadster. Alternator fried, Alarm module fried, BMW version of the DME, fried. Had the work done at an independent shop. Total damage over $4k.
*2005 Markleeville "Death Ride" 5 Pass Finisher. 129 miles & 15,000 ft. of climbing *California Triple Crown Member (3 Double Centuries in 1 Year) *2003 Giant Carbon Fiber Road bike with Topolino Wheels + a lot of goodies *2000 Torelli road bike - Campagnolo Chorus equiped + a few goodies *1999 Litespeed titanium, full-suspension mountain bike Shimano XT equiped + a lot of goodies. Bill Carcot 1979 911SC - Sold (Searching for a Boxster) 2000 BMW Z3 |
ROW '78 911 Targa
Starter turning with 14 pin connector disconnected probably means melted wires in the engine harness have shorted.
Likely the Red wire melted to a Yellow one. PM or email me if your wrench tells you that you need a new Engine Harness.
Probably this one
Pelican Parts - Product Information: 930-607-016-02-OEM I wouldn't buy a new one just get out the soldering iron and heat shrink.
Rick 88 Cab Last edited by rick-l; 05-25-2015 at 10:10 PM.. Reason: wrong part |
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Here is the update.
The red and yellow wires from the starter are melted together. Question - does the engine have to get pulled to replace them?
It depends....
More info is needed. There are three red wires going to the alternator. A 10 mm^2 wire (~8 AWG) that stands alone (not in the harness with the 14 pin connector) and goes to the starter and two 2.5 mm^2 wires (~14 AWG) that go to the engine compartment fuse panel. So did the big wire melt through the wire harness to get to the yellow wire or did the smaller red wires melt inside the harness to get to the yellow wire? The later seems unlikely since they are fused.
Rick 88 Cab |
ROW '78 911 Targa
The 2 smaller gauge red wires in the engine harness are not fused in the harness, they connect directly to the main feed from the starter at the alternator and are crimped in the same comnector.
I found an excellent 911 mechanic who got the car back on the road. The wires from the starter back to the alternator were fused together, alternator was toasted, and many wires leading from the alternator back to the engine harness, etc we destroyed. Starter, DME we okay and new splices were made to the damgaed wires and alt. was replaced. Have driven the car approx 100 miles and have some good and bad - good is the car seems to be more powerful than before, radio is clearer and louder; dimmer on instrument lights has more gradients and is brighter; bad is the windshield wipers wont turn off ( so I pulled the fuse and will try to diagnose the issue). An expensive dumb ass move but happy to be flying again inmy 911. Thanks for all for their contributions - Happy Porscheing!
hope youre keeping a fire extinguisher in the car close at hand. sounds like youve still got some melted wires in there somewhere
82 SC , 72 914 |
you could disconnect the wiper intermittent relay and see hat happens.
Rick 88 Cab |
ROW '78 911 Targa
It can get real bad reversing the polarity.
This 3.2 harness was sent to me to make a new one. ![]()
Thread Tools | |
Rate This Thread | |
