83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Burnin' Rubber
I got the parts on eBay from a couple of different sellers. The parts are all well-made, sturdy not flimsy at all. It's hard to capture with my iPhone but the install looks OEM. Ebay Sellers: Andy14nq offroadarsenal Inexpensive, too! I installed a 15A inline fuse as well. Took 15 minutes tops to install. |
I've already got the spare gauge to work with. I talked to Harmut at Palo Alto, and he wasn't able to take on this project. I'll contact http://www.newvintageusa.com/bigmarkdesign.html For now I'll attach a multi-meter for my next road trip. I always like to bring one along in my tool kit anyway.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 08-28-2015 at 05:28 AM.. |
Darn. They just got back to me to let me know they no longer work on our gauges
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I went down the same road and contacted Palo Alto and Mark with no luck. The difficulty is in the AFR movement. I'm pretty close to having a working gauge. I worked with an electrical engineer to design an external box that will drive the 2 stock fuel and oil level movements. This way, no modifications need to be made the the stock gauge other than the faces. It's also nice because the needles both move from top to bottom like the stock gauge. The electrical work is done and I'm having the faces made now. I'll post some pictures when everything is done. Should be a couple weeks.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
I have a donor fuel gauge
Any ecomonies of scale here if I piggy back on your project contributing to your cost recovery?
Great addition for our cars CHT and VDC the other would be a Fuel Mixture gauge.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Always Be Fixing Cars
Lots of cool solutions here. Anyone find a cigg lighter option that is a bit more.... 80's looking?
Also wondering what the alternator idiot light reports? Total failure (ie belt snaps) under charge? Over charge?
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
All the heavy lifting is done... I'll post pics as soon as it's done. I'll post some pics showing what I did and I'll see if we can make the parts available. I have no interest in building these or making money on it so I'll do what I can to pass it on.
Thanks!
Standing by
I ordered
![]() I was planning to run it in mode 4 (below), maybe install it in the unused warning slot in my oil pressure gauge or on the dash where the OXYs light is. I still haven't received it so it could turn out to be junk. If not I'll do a write up and post it. Mentioning it now because it seems relevant.
1980 911SC |
Schleprock
Here's some good information on the alternator light function. It's more than just a typical light bulb being turned on!
Race Car Dash Alternator Light
Kevin L '86 Carrera "Larry" |
Here is a picture of the finished gauge. As I mentioned it is a standard fuel/oil level gauge with new gauge faces. The little box converts the voltage and O2 sensor signals to the correct voltage ranges for the stock gauge movements. This setup works with the older narrow band sensor.
Can I order an electronic box from your guy?...or a kit with schematic??? Pre-assembled would be great.
Where can I get the gauge refaced? Looks like the prefect solution (other than narrowband, but I can live with that ;-)
I too wish there was a way to use a wide-band sensor but the circuitry is much more complicated and we couldn't come up with a way to use the existing movements. For one of my other cars I'm putting together a wide-band gauge using the parts from a clock but it will be a full sweep gauge based on the innovate gauge (no volt meter). I'll post a picture of that in a couple days.
My other ride is a C-130J
Great advice Wayner, you motivated me to get some "insurance" as well.
My car has the dealer installed air conditioning unit installed. So I was able to buy a VDO bracket which fit perfectly in the space of the never used ash tray. I installed an OEM 55 mm VDO voltmeter and an OEM VDO 55mm outside temperature gauge Doesn't look too bad. I love knowing the status of my electrical system
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
My battery gave up the ghost mid lap at a hpde. I lost all power and the hood was smoking a bit, but i was "lucky" and there was no leaking. I have since switched to agm batteries, and saved some weight in the process.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Caveman Hammer Mechanic
The battery was just the symptom. AGM will not save you from an overcharging problem, it will just delay the inevitable, with bigger thrills. Do some diagnostics, STAT!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 11-04-2015 at 09:15 AM.. |
This WAS an AGM battery. AGM won't save you from a battery explosion if you are overcharging.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 11-02-2015 at 05:37 PM.. |
(I still haven't gotten around to following my own advice but I did ride with a multimeter on the passenger seat last outing).
