View Poll Results: Is hose replacement advised as part of AC restoration? | |||
Yes |
35 | 92.11% |
No |
3 | 7.89% |
Voters: 38. This poll is closed |
LinkBack | Thread Tools | Rate Thread |
El Duderino
I am not going to get into the efficacy ofthe EPA and DuPont testing because that isn't the point. You can site all of the theoretical sources you want -- there is a difference between theory and reality. If a hose leaks in the real world then all the lab testing in the world is meaningless.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
El Duderino
Currently sitting at 16-1 and we all know who the 1 is. There's your answer!
I've contacted the EPA in the past and asked them for the empirical study which supposedly concludes it is not necessary to replace non barrier hoses with barrier hoses. Their response: " gee, we have no idea", and "gee, we have no idea whom changed the text in the EPA website"
Understand that most passenger vehicles have less than 12 feet of rubber ac hose, in most cases the lines are metal. And, today, most refrigerant lines are metal for a reason, other than quick installation by a robot, .... metal does not permeate refrigerant gas as easily as rubber. I believe this previous post sums it up: http://forums.pelicanparts.com/porsche-911-technical-forum/750353--non-barrier-hoses-do--leak.html#post7447688 |
Banned
By the way, one of the major producers of refrigerant hose in the US noted there will be a major price hike this summer. They have not concluded as to much of a % the costs will go up, kinda odd considering the cost of oil is down, wages are down, lol.
French Import
As I am about to replace the old rubber, should I consider having metal lines made?
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Ziggy,
Yes. Of course consider metal if you are handy. As I stated, and the auto industry has moved to, metal leaks less than non barrier hoses. Pro's: Less leakage. Lighter weight (aluminum). Con's: More time to do the job, and more tools required. If you don't get your braze joints correct, you got leaks Potential for corrosion. So, if you want to delete the source of common permeation (leakage) through old fashion non barrier hoses, you have 2 choices: A) Barrier hoses, either buying a set, or having them made for you, and some buy their own hose crimper or borrow one. The hose PP sells individual barrier hoses and complete sets. B) Make your own metal lines. Look up Jim Sim's in the various threads, he's done metal lines, and as well he has used our barrier hoses on an earlier car. PS: just ignore willy. |
French Import
Thanks!
I usually do... ![]()
Fleabit peanut monkey
I know what poll thread I would like to post.
Should wwest be banned permanently? Yes or no
1981 911SC Targa |
I view Willard's addiction to AC threads kinda like a fly trying to pass up a steaming pile of horse sh#t. He can't resist landing and subsquently leaving his fly specks (sh#t) all over the place. He needs to seek out addiction rehab or better yet as Bob suggests, be assigned to it.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
88 Carrera, Guards Red
wow, that did not take long. must be a record.
Banned
French Import
but...but...but... what about that trinary switch???
I'm about to venture down this path and have decided to try the DIY route.
I bought a hose crimper from amazon, and will try it out once I get back from vacation in a couple weeks. Check out a pic at: New flux capacitor, aka AC hose crimper So far I've only planned out materials to replace hoses from the compressor to the R/D, as a "phase 1". More to follow. Cheers Nathan
87 Carrera Coupe Black on Black, H4 Headlights, Nurburgring Sticker |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I replaced the liquid line on my P-car with copper tubing - never have to worry about it ever leaking again. Hadn't done the suction line yet because it hasn't leaked but when it does it will be replaced with insulated copper tubing
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
The Bavarian
'80 911 SC Targa black/black |
Thread Tools | |
Rate This Thread | |
