Last pieces of the puzzle are in, 50 PMOs.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 04-23-2019 at 06:07 AM.. |
Mikes wrapping things up. Black plug wires being installed.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
Hey Nippy
Tell Mike Bruns hello. He helped me build my twin plug 3.0L 10 years ago. The darned engine runs perfect. Idles smooth and then screams like a cat when you put your foot down. I asked Mike for a build that I could run the daylights out of and then drive home and just change the oil and adjust the valves once a year. Got what I asked for. Your will be happy with his work for sure.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
the plugs of em wires look very "solid", not like them BERU/NGK ones? What brand are these? Manufacturer code/partnumber please.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Plug Wires
The ends are Magnacore (5 pieces per end) the wires are a Moroso blue max 8mm spiral core that we have used for years, the wires are custom built as needed, you can buy the wire in 50' to 100' rolls in several colors, black,blue,red and cut to length, to do a typical twin plug 911 it takes a bit over 50' including coil wires depending on coil locations.
Mike Bruns Kent, glad to hear you are well !
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Wires ran, Mike Bruns is finishing the deal, SO EXCITED! Dyno Saturday for carb tune!
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 05-22-2019 at 05:58 AM.. |
So you settled on the Dynomax 17231 muffler?
Exciting !
Please post a dyno video if that is possible. |
I remember when Mike ran my engine on the dyno. I built the engine at home in my garage so I was a little nervous. He sent me to the gas station to get some gas. When I got back the engine was screaming on the dyno. What a relief. I was so nervous that I might have done something wrong.
Its going to dyno for carb high RPM/Speed tuning that you cant do by seat of the pants on the streets.
However here it is when Mike was running power pulls a few months back. This is 50MM PMOs, open race headers and a GT3 cup muffler 381.8HP/303.8TQ This is 50MM PMOs, S cargo replica stainless headers and a dynomax muffler (the set up were going with) 374.2HP/297.1TQ
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-07-2019 at 09:05 AM.. |
Here ya go
Dyno vid here Results
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-16-2019 at 02:54 PM.. |
Wow that makes tons of torque.
Mike Bruns getting the tranny ready. The pinion depth is set.
Nippy, thanks for the dyno vids.
That muffler sounds really good, i think i will try one of those on my car. |
Dont thank me, thank Mike Bruns hes been kind enough to do all the work and also document it for me and the forums. Hopefully if and when you guys need some work done, you can go his direction. Hes the man, not that I need to tell ya but hes been very accommodating to me knowing I am trying to document every step as it happens.
MBruns for President
Mike is THE Man - your car will be a beast! Looking forward to seeing it
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I pick up the engine and tranny Friday if all goes well. So the car will be on the road again very shortly.
![]() Nice new ground strap Mike found in his stash! Guard LSD installed and ready The diff is all set and the final adjustments are done on the gear stacks and shift forks, the box is ready to go together for good! Mike said he's never seen a 915 tranny that has these #s intact, usually they get ground off over the years from being dragged around on concrete
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-05-2019 at 06:15 AM.. |
Schleprock
Looking great as usual. Mike is top notch.
Noticed one thing i'm sure Mike already took care of
Kevin L '86 Carrera "Larry" |
Yep Mike has it covered as usual!
