It's not puzzling, your hand drawn wiring diagram is wrong or not clear. The relay in the smugglers box is powered from a fuse in the frunk. It's triggered by another fuse against the starter motor wiring (so it shuts the system down when cranking). It feed direct power to switch on the dash, which then feeds power to the evaporator motor, temperature switch, clutch and the trigger side of the condenser relay. So, it has one big motor, one big electromagnetic clutch, some small switches and a relay trigger on it. Not trivial.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
The relay on the car now is one I believe I purchased from Pelican that had a fuse built into the relay. My original relay did not. I will say that at some time in the past this relay has gotten pretty hot ( maybe when my previous compressor clutch shorted out) such that some the plastic housing surrounding the spade connectors had melted.
Pazuzu is correct.
The old SC schematic has not changed much in the Carrera, and you will find one Carrera schematic that shows a pressure switch the factory never installed. As far as the relay goes, the older metal can relays had a higher amperage rating, the new ones sold do not; I believe Porsche kept the same part number (which is not common) and changed the relay (added a fused and dropped the amp rating). Get yourself a 30-40 amp relay (they are common). Just cause it says P on it does not mean its perfect.
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Sturmvogel
Both of those stupid e-tards got canned by a PP Uberfuehrer. So they can't help. But in this case, you have it right on the higher amperage and fused relay. There is a lot of stuff and a lot of wire on that circuit. And absolutely P<>perfect. There are very good aftermarket suppliers of electronic goods, and the manufacture of such goods has improved some in the last 30 years.
Went to another source for 86-87 911 A/C schematic diagrams, no second relay for clutch,same as posted.
Fleabit peanut monkey
You talk out of your ass with wind that is not applicable to any routine issue. FOAD. I mean die. Literally. You are an empty, pathetic man without value even within the sliver you deem yourself a demigod. How is this allowed to happen?
1981 911SC Targa |
Did you scan that picture with a toaster, Willy?
1981 911SC Targa |
God damn it. How is wwest allowed to pollute this forum again? Where is Black993, a real moderator, BTW, when we need him?
1981 911SC Targa |
So the box labeled Air Conditioner Relay in the 86-86 diagram must be the one in the smugglers box. Before I tapped it yesterday I had no evaporator fan blowing at any speed, no fender condenser fan running and no compressor engaging. After I tapped it everything began to work and proceeded to work as long as I drove the car around. I have not tried it today so I don't know if it will continue to work. Not sure where the front condenser relay is located but I do have a separate fuse on that component as recommended.
Lemmie check what you posted when I get home. Old habits die hard.
1981 911SC Targa |
Ya gotta love these AC threads:
iwhelan = missing in action llangston1 = keeping a hammer in glove box to bang the relay dave's= in the easy chair Rawknees'Turbo - wins the Pulitzer Corvus Corvax - go pound salt Bob - searches the bleachers for the moderator West - made parole but lost but lost his bifocals Mike - compos mentis Irhmsd & darrin - ran out for bagels sonett43 - tosses a hail mary, of course I fumble it dentist90 - time to turn up the N 2O.
Better toaster:
Amazing, where's the pressure switch!
Yes, "where"...
Not in my '88 971-4 chart indicates that the high pressure switch was NOT used '84-89..... Last edited by wwest; 04-27-2016 at 05:08 PM.. |
Immature Member
![]() Back to my huffin'....
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
BTW a static charge of 80 only says there is at least a little refrigerant in the system. It may be almost empty and show the same static charge depending on OAT. Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Damn..!
A big shout-out, KUDO's to Kuehl/Charlie. ![]() ![]() The relay in the smugglers box provides power to the front condenser blower, the evaporator blower, and the compressor clutch via the thermostatic switch. All known, to me, schematic diagrams are apparently wrong. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
I use the ignore list.....
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Mighty Meatlocker Turbo
Whoda' thunk that a tremendously experienced, bonafide expert in Porsche a/c (and mobile a/c in general) actually knows what he's talking about, right?!?!?!
Tags |
air conditioning |
